Old 09-07-2021, 09:48 PM #16
somenoise somenoise is offline
somenoise is on a distinguished road
Originally Posted by Saker View Post
Then you change out P rated tires for LT or non P rated tires, the load rating is different so you can throw the placard on the door column out the window as far as this psi inflation guidelines.
Personally I run 44 psi in my BFG All-Terrain T/A KO2 to meet my load needs.
This. If you went with E-loads then your pressure needs to go up to around 44. There's a link on multiple threads here that explains/does the correct psi for changing load and/or size.
somenoise is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 10:29 AM #17
bzizzi's Avatar
bzizzi bzizzi is offline
bzizzi is on a distinguished road
bzizzi's Avatar
This forum is awesome ! So much helpful information, my 20 ORP is going to Toyota dealer tomorrow for inspection, Toyota care service and a correct wheel balance using the correct method described in this thread from first reply. Dealer is familiar with this issue and has a remedy.
bzizzi is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 11:48 AM #18
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Toyota trucks are just sensitive to wheel balance. The only way I've been able to reliably get rid of steering wheel shimmy is to have the tires RoadForce balanced and ask the tech what the RoadForce numbers are on each tire. These numbers describe how out of round the tire is. Less than 10 is good, 10-20 is ok, over 20 is garbage. If you just bought the tire and its over 20, I'd ask them to remount it, to see if that helps. If it doesn't help, ask for a new tire. Once you've got your Roadforce numbers for each tire, request that the lowest numbers go on the front and the highest numbers go in the rear. Now the only time I get a bit of shimmy is in the mornings when the tire has been sitting on the same spot and is cold. It goes away as soon as the tire warms up.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 12:38 PM #19
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Originally Posted by BorotHex View Post
55 psig? lol, that’s higher than the tire is rated at, right?
55 PSI is the right at the max limit for the tire. The Toyota factory over inflates the tires so they won't get flat spotted during transit. Dealers are supposed to lower the pressure back to 32 PSI during PDI but most never do. Many people on this forum have complained they found their tires at 55 PSI.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
pressure , steering , tires , wheel , wheels
Steering wheel shakes on highway Gouranga 5th gen T4Rs 26 04-23-2021 12:41 AM
Steering Wheel Shakes and Pulling to the right. Ogbassist182 4th Gen T4Rs 5 04-06-2016 10:16 AM
Rotated tires-now pulls to side and steering wheel shakes MidwestJ 5th gen T4Rs 2 09-21-2015 02:48 PM
Braking shakes steering wheel II JCDM 4th Gen T4Rs 2 09-01-2014 02:37 PM
Braking shakes steering wheel? Silvergrowler 4th Gen T4Rs 16 08-30-2014 03:42 PM
