Old 09-17-2021, 01:32 AM #16
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
Originally Posted by 1000MPH View Post
Good timing? Timmy the Tooolman just posted a vid on front diff axle seal replacement on a Lexus GX470. Should be similar, the part numbers look the same at quick glance.
Front Differential Axle Seal Replacement (Lexus GX470) - YouTube
That is good timing! It doesn't seem too difficult. Sadly I don't have tools/space/time needed for this, I will end up going to a shop.
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 01:13 PM #17
HighOnRice HighOnRice is offline
HighOnRice is on a distinguished road
I just recently had that exact seal replaced. Same leak. 43k miles.
First I took it to the dealership to get it diagnosed to make sure I wasn't missing an obvious but they confirmed it was the front passenger seal. They then quoted me 1k for the job lol and I said no thanks.
I don't have the knowledge to do it myself so I found a shop with a certified Toyota tech and it costed me 250 in total.
Hope that helps.
HighOnRice is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 01:19 PM #18
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
DougR is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 01:29 PM #19
gringo8251's Avatar
gringo8251 gringo8251 is offline
Real Name: Zach
gringo8251 is on a distinguished road
gringo8251's Avatar
Real Name: Zach
I say this as someone that has been working on things since I was kid. Also, I'm an aircraft mechanic and love tinkering. That said, working on your 4R is very straight forward. You don't need a lot of tools and there is info everywhere online. If you don't have much mechanical experience, find a friend that does, buy him a case of beer, and fix something. Replacing a front diff seal seems hard because of all the stuff in the way. It's not! You have a bunch of simple tasks in front of another simple task. It might take you all day but you'll learn so much about your truck and gain confidence in it and your abilities.
I'm not dense. I get it's daunting the first time you consider disassembling yor $40k truck. My recommendation comes from years of watching people learn how to fix things and the satisfaction it brings. Either way - happy wheeling!
Rant over
2017 ORP, 3" lift, Icon UCA, 34s, NTK Fab body mount, angle grinder bumper cuts, RSG sliders, 4.56 gears, Front & Rear E-lockers
1985 CJ-7, 4" lift, 35s, fully locked, fun to drive offroad
gringo8251 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 02:06 PM #20
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Hope that helps.
It should be covered under the 5 year, 60k mile powertrain warranty. If your 4Runner still falls within that range.
02SE is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 08:00 PM #21
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
Hope that helps.
I thought to give a call to the dealership as well to ask for a quote, I told what was the issue and what work I wanted to be done but they told me that they would need to do an inspection first, for only $149 and I said no thanks.
I found another shop nearby, quoted me $125-$150 per side (in case I want to replace both) so I'm going to go there instead.
Old 09-19-2021, 08:08 PM #22
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
Rant over
I totally agree with you, I also like to mess with things and I prefer to be the one to do a job so I know what exactly I am doing to the vehicle.
I watched some videos on the work that should be done to replace a seal and yes it doesn't look that difficult. Having said that, I currently don't have my own garage, I know few people that could help me but I would also need to buy/rent additional tools, find a time that work for both etc.
Going with the shop this time is fine, I can get it done quickly and be back on the trails by next weekend to enjoy last weeks before if gets too cold, also I can go back to the shop in case there is an issue with the replacement !
Old 09-19-2021, 09:13 PM #23
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
if you gonna take it to a shop to fix..might as well upgrade something while they have your whole front end torn apart.
I would recommend cam gussets.
Old 09-20-2021, 11:51 AM #24
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
I'm not sure what they are. Can you elaborate?
Old 09-20-2021, 12:29 PM #25
DougR's Avatar
DougR's Avatar
See Total Chaos Weld-On LCA Cam Tab Gussets: Install For 5th Gen 4Runner for a detailed description. Consider having them installed on a 4Runner that is often taken off-road and as a result needs frequent alignments.
Old 09-22-2021, 07:07 PM #26
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
Got it, thanks. That seems to be a bit overkill for me, I haven't had any alignment issues so far! But I will keep it in mind.
Anyway, i just got back my truck today. For who's interested, It was total of $125 plus parts, not bad. I hope the leak is gone!
attachment , front , happening , leak , passenger
Air Leak Up Front sport2004 4th Gen T4Rs 12 01-22-2020 05:16 PM
Leak near front right wherl UURunner 4th Gen T4Rs 5 05-19-2018 03:26 PM
front driveshaft leak Toythom 3rd gen T4Rs 14 01-14-2018 03:26 PM
ATF leak at front of car KingSuper 3rd gen T4Rs 24 08-16-2015 08:43 PM
Front dif leak... uh oh ellner357 3rd gen T4Rs 6 04-28-2013 10:09 PM
