Old 09-10-2021, 11:29 PM #1
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
Unhappy Front leak
Hi all,
I was just doing some maintenance while looking under the truck when I noticed a dark are on the front skid and after closed inspection I believe I found the source of the leak, see attachment.
This is happening on the front passenger, the driver side looks fine. Can anyone help me identify what could cause this and which is the part leaking?
Thanks!
Front leak-3a622846-d403-44c4-ac22-388bd6fc0efa-jpg
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 09-11-2021, 01:19 AM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Make sure the front differential vent is venting. Otherwise as the gear oil heats up, pressure builds, and seals leak. It could also be the seal is leaking, even with the vent not plugged. It's a relatively easy seal to replace for a mechanic or skilled DIYer.
02SE is offline   Reply With QuoteReply With Quote
Old 09-11-2021, 03:57 AM #3
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
Should be this one. It'll be your front diff fluid leaking past the seal.
Had the same dripping experience a month or so later after I swapped my driver axle a year ago. Guess I damaged the seal putting the new one in. Had a shop change both seals for me since I needed other work at the time. No more leaking since.
Yours may just be wear and tear. All part of the maintenance.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 09-11-2021, 09:08 AM #4
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
Thank you! Can you point out where I can find the front diff vent?
Old 09-11-2021, 09:11 AM #5
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
Thanks this helps. Do you remember approximately how much they charged for replacing both seals?
Old 09-11-2021, 12:13 PM #6
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Vent tube bolts to the top of the front differential carrier assembly. The tube terminates with a vent as shown in this image. Go to YouTube and search "clean check differential breather Toyota". Front differential breather check or clean is similar to servicing a rear differential breather.
Front leak-c217926e02-png
DougR is offline   Reply With QuoteReply With Quote
Old 09-12-2021, 04:35 PM #7
I don't, sorry. Majority of the work was to weld on the total chaos alignment tab gussets. The shop had to remove the LCAs and axles anyway so while I bought the seals on my own, I just had them swap it out.
YouTube
Old 09-14-2021, 11:40 AM #8
DougR's Avatar
DougR's Avatar
I suspect the seal should be replaced because only one side is leaking. If that doesn't fix it, then replace the breather plug per this TSB for 2010-2015 4Runners. (However, I would try cleaning it first.)
https://static.nhtsa.gov/odi/tsbs/20...42475-9999.pdf
Old 09-14-2021, 01:07 PM #9
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Can someone provide the part numbers for the front diff breather vent/tube and the axle seals? Please!
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 01:51 PM #10
DougR's Avatar
DougR's Avatar
Seal part numbers are "LH Front Axle Seal P# 90311-47027 or P# 90311-47013 for RH Seal" as published here in this DIY 5th Gen 2010-2018 Front Axle Seal DIY
A search for "front differential breather tube", "breather" or "differential breather vent" doesn't yield anything for my 2011 Trail on the Camelback Toyota website.
Toyota 4Runner Plug, breather (for front differential) - 9093003136 - Genuine Toyota Part shows a breather and tube assemblies. I found it using this Google search "2011 4Runner front differential breather vent".
Old 09-15-2021, 08:54 AM #11
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Thank you Sir
Old 09-15-2021, 11:16 AM #12
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Do your rear diff breather too while you're at it, it's a good idea to use a coupler, fuel hose and zip ties to extend it up behind the fuel filler so it's protected. Since it's the driver side you could replace the needle bearings with the ECGS teflon bushing sleeve as some preventative maintenance while doing that oil seal.
EDIT: nevermind about needle bearing I see it's the passenger side leaking.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 11:22 AM #13
And if you don't already, after you get it fixed remember to run 4H for a few miles on straight or dirt road every month to keep the diff nice and lubed.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 09-16-2021, 03:06 PM #14
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
If you mean to add a breather line to read diff, I have done that already!
Old 09-17-2021, 12:16 AM #15
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Good timing? Timmy the Tooolman just posted a vid on front diff axle seal replacement on a Lexus GX470. Should be similar, the part numbers look the same at quick glance.
Front Differential Axle Seal Replacement (Lexus GX470) - YouTube
1000MPH is offline   Reply With QuoteReply With Quote
attachment , front , happening , leak , passenger
Air Leak Up Front sport2004 4th Gen T4Rs 12 01-22-2020 05:16 PM
Leak near front right wherl UURunner 4th Gen T4Rs 5 05-19-2018 03:26 PM
front driveshaft leak Toythom 3rd gen T4Rs 14 01-14-2018 03:26 PM
ATF leak at front of car KingSuper 3rd gen T4Rs 24 08-16-2015 08:43 PM
Front dif leak... uh oh ellner357 3rd gen T4Rs 6 04-28-2013 10:09 PM
