Old 09-14-2021, 07:47 AM #1
Endle55_5earch's Avatar
Endle55_5earch Endle55_5earch is offline
Endle55_5earch will become famous soon enough
How will Positive Caster effect ride quality? (2" lift w/ UCA's)
I will be installing heavier springs on my front TRD PRO shocks (FJ Pro Front Springs 14" and 600lbs) and using JBA UCA's. This is temporary while waiting for my Eibach coil-overs to come in...
SCS F5's 17x9-38 with 285/70/17 Falken Wildpeaks is the wheel and tire combo.
I expect a 2" lift with my winch and steel lo-pro bumper.
I understand I'll need +3 to +4 caster in order to fit the wheels and tires (I have a BMC already)
The question: What should I expect the extra positive caster do to affect my ride quality? Will I notice a huge difference?
Thanks for your help!
"HANZO" 2015 TRD PRO: SSO Front Bumper w/ Stage 2, SCS F5's (17x9-38), 285/70/17 Falken Wildpeaks, 2" all-around Dobinsons IMS, JBA UCAs, Slee Sliders, BMC, Warn Winch, LED High/Low, DD SS3 Fogs, Rigid Lightbars (Amber/White light), Nise Rack, Extended Diff Breather. Road Trip 2021 - YouTube
Endle55_5earch is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 10:39 AM #2
less wandering on the highway. wont feel as twitchy.
Old 09-14-2021, 11:37 AM #3
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
It’ll drive how 4Runners should have felt from the beginning. Night and day positive improvement.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 04:41 PM #4
Cool, thanks guys. Just trying to get a heads up on the changes I will feel (both positive or negative) on road or off.
Appreciate ya.
Old 09-15-2021, 01:54 PM #5
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I like it. Feels more heavy and planted. Personal preference I suppose, I don't like the vague stock steering that much.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 02:04 PM #6
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
In the 1.5-2" lift range there's a little bit of trickyness in alignments. The problem is that the UCAs add about 4 degrees of caster. At 3" of lift that's what you want. Half way in the middle, it's maybe too much - and by that I mean you can get great alignment, but at 4* caster you won't be maxing out the caster available on the lower control arm tabs - so you won't be pushing the tires as far forward away from the body mount as you would with stock arms.
I recently lowered my suspension back to around 1.5" lift and put the stock UCAs back on. (I have some JBA arms I used at higher lift). The reason was what I explained above. At 1.5" lift front I had to either run 6-7* caster to max the body clearance or pull it back to 4*. Not a problem with 33" tires, but with 34" tires it can rub a little. So I swapped back to stock UCAs and set around 3* caster, but better body clearance. The stock UCA locates the upper ball joint further forward as well. So the net of the lower height is that - oddly - at the lower height I think I might even be able to squeeze 35's. If I had a set I'd bolt em on and see if they fit.
I'm doing a lot of highway miles lately that prompted the lowering. The ride is noticeably better at 1.5" than 3" lift on long road trips.
Overall though - I'd say no question the higher caster is nicer all around for driving. Once you get below about 2* the steering wheel feedback sucks and it doesn't want to track very well. After messing around a lot with mine - I think 3* is okay, but around 4-4.5* is close to ideal.
Old 09-15-2021, 02:37 PM #7
So, If I'm understanding correctly, at a 2" lift (and higher) I'm good to put on the JBA UCA's but if its under 2" lift I should keep the stock UCA's?
The FJ PRO Springs (14" long @ 600lbs) is supposed to give a 5th Gen T4R a 2.5" lift stock front and a 2" lift with Lo-Pro bumper + Winch. I've gathered this info from the forum and have the FJ PRO Springs and JBA UCAs in the garage waiting for install.
I daily drive my T4R but travel to the mountains (Just recently did Alpine Loop in the San Juan Mountans, CO) so I wanted a "modest" lift that's good for highway driving and the week-long off-roading vacation.
I appreciate the nuance in your response. Thank you for your help!
Old 09-15-2021, 04:31 PM #8
Jetboy's Avatar
Jetboy's Avatar
I would probably put them on. You'll want them if you go any higher for sure. Just be aware that you won't probably end up with quite as much body mount clearance, but you'll have better alignment than the stock UCAs. For 285/70/17's (32.6ish height) it should clear jus fine on the mount and you'll like the driving experience a lot better with better alignment.
I didn't have the clearance issues until I jumped up to 285/75/17 (34" height). At 3" lift up front I definitely wanted the JBA UCAs. Overall they worked great. At stock height you'd move the LCA back far enough you might have body mount clearance issues, so I wouldn't want the JBA arms at stock or near stock height.
I'm keeping them in case I end up keeping the 4R and lifting it higher again. I mess around with it a lot - it only takes me a maybe 2-3 hrs to re-adjust the front to 3", swap UCAs, swap rear springs to some 2.5" lift Dobinson ones I have, and then re-adjust alignment pretty close to where I want it. Keep track of your alignment cam locations at each height and it's an easy re-adjust back to proper alignment when you want to switch around. For now with a 2yr old - my trips are more Yellowstone and Glacier with my camper, and less Moab and Rubicon.
Old 09-15-2021, 05:37 PM #9
Everything makes sense. I used to want to go 34's but I decided I'm not going to re-gear. The 33's do what I need them to do.
I miss the "terrible 2's" but I certainly didn't feel that way when I was going through it! Thanks again for your time.
Old 10-04-2021, 03:57 AM #10
Mo's TE Mo's TE is offline
Mo's TE is on a distinguished road
Question to guru's, should the caster be equal on both sides? Some shops told me that there should a degree or so difference between right and left (right being higher).... I'm not convinced this is actually correct, what do you guys think?
Mo's TE is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 05:14 AM #11
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Compensate for the crown of the road.
When I was doing alignments I would go ½ to ¾°.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 09:41 AM #12
If your vehicle supports barely any positive caster from factory, I could see how one would want a compensated alignment. If you can get 4 degrees positive caster, you shouldn’t need to compensate for road crown.
Keep in mind, if you do mostly highway driving and you camp out in the left lane most of the time, the compensated alignment may not produce the desired results. Interstate highways sometimes crown in the middle of each direction’s lanes, not just in the median.
expect , front , pro , springs , ucas
Will Raising Ride Height 1" - 1.5" Effect Alignment Significantly? JimJr15 5th gen T4Rs 15 01-22-2018 02:08 PM
Will I get 4" of lift outta this setup. How will ride quality be?? AUKiller 4th Gen T4Rs 12 08-01-2012 07:17 PM
Do Wheel Spacers Counteract Positive Camber Effect of Lifts? keitht253 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 06-24-2011 05:14 PM
Lift and Ride Quality SCRunner12 3rd gen T4Rs 8 12-02-2010 11:53 PM
4Runner Sport Ride Quality vs Limited Ride Quality ckhkjh 4th Gen T4Rs 10 02-20-2007 02:36 PM
