12-30-2021, 04:13 AM
Getting out of a jam check list
Hello All
I wanted to create a check list should I ever get stuck in snow or mud with my 4Runner. I occasionally travel up to the Sierra Mountains and been in the mud and snow but I’ve never been stuck. But I’ve been watching some video and thought it would be helpful making a check list should it ever happen.
I’m particularly interested in when’s the best time to uses Crawl and A-Trac as I have not used these features very much. Anyway, any helpful comments are appreciated.
Here’s what I’ve created.
If stuck do the following.
1. Turn off Traction Control
2. Engage 4 Low
3. If Steps 1 & 2 are unsuccessful engage A-Trac and Crawl control.
4. If Steps 3 fails engage differential lock
5. Use traction board if available
6. Deflate tires to 20 psi
7. Use winch
If anyone has used A-Trac or crawl in mud or snow, which setting did you find most useful?
Thanks
12-30-2021, 12:46 PM
Originally Posted by Lexington
Hello All
2. Engage 4 Low
7. Use winch
Thanks
Thanks. Good list. I have an SR5 so it does not have differential locks.
The A-Trac acts like a differential lock. It is most useful (mandatory?) when opposite corner wheels are hanging over deep ruts; I call it the teeter-totter mode. I've had to use it at times during off roading on the Alpine Loop in western Colorado.
12-30-2021, 01:37 PM
This combo has always worked for me in the city:
1. face mask
2. gloves
3. duck tape
4. glock 19
5. body glitter and baby powder.
On the trail:
0. Air down (always)
1. 4hi
2. 4lo
3. 4lo + atrac
4. 4lo + rear locker
5. 4lo + twin locked...(easy button)
12-30-2021, 04:40 PM
1. face mask
2. gloves
3. duck tape
4. glock 19
On the trail:
1. 4hi
2. 4lo
3. 4lo + atrac
1. face mask
2. gloves
3. duck tape
4. glock 19
1. 4hi
2. 4lo
3. 4lo + atrac
Thanks
12-30-2021, 05:46 PM
1. face mask
2. gloves
3. duck tape
4. glock 19
On the trail:
1. 4hi
2. 4lo
3. 4lo + atrac
MrBlah
What do you mean by 4lo + twin locked? I know you can lock your rear diff but I didn’t know there is a option to lock your front or center diff.
12-30-2021, 05:53 PM
MrBlah
Im running ARB front lockers.
12-30-2021, 05:56 PM
And remember your winch won't help you if there's nothing to pull from. I got mine high centered in snow once and the atrac nor locker nor crawl control helped of course. And it was before I had a winch. I just did what I have always done and dug it out with a shovel. I always carry a recovery bag with two 20 foot tow straps, a tree strap, receiver shackle, and 2 extra shackles.
It could just be me but I will typically use the locker and Atrac off road if I feel they may be advantageous. Not for when I get stuck. When I got hung up in the snow I was on my own property so it's not like I was worried. You kind of just get a feel for the capabilities of your vehicle over time and what it can and can't do. That day I learned it really needed a lift and larger tires.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
12-30-2021, 06:17 PM
you could throw traction boards, hi lift and land anchors into the mix
edit: hitting the trails with another rig is a strong suggestion as well
12-30-2021, 09:22 PM
Ok thanks for the clarification! Out of curiosity do you lock the ARB manually or does it come with a electronic switch?
12-30-2021, 11:38 PM
MrBlah
Only the Limited, with full time 4WD, has a center differential.
12-31-2021, 12:20 AM
It sounds like maybe you are planning to do these things sequentially? Don't do that - as you spin your wheels, you'll dig yourself in deeper and be less likely to get out.
You should use all of your equipment to avoid getting stuck in the first place. It is much easier to NOT get stuck with momentum and all of your traction aids on your side. If you do get stuck, stop. Get out and assess the situation. Make a plan A, B and maybe C. If things don't work out, don't keep digging with your tires.
ARB is an air locker which is powered by compressed air via a solenoid that is electrically actuated (switch in the cab).
12-31-2021, 01:19 AM
Hello All
2. Engage 4 Low
7. Use winch
Thanks
Is there an open diff 2WD version of this check list?
EDIT: I'm not serious, just a joke.
12-31-2021, 02:56 AM
Not ideal but you can always use the spare and dig a hole to make a makeshift land anchor.
21 ORP- Victory4x4 strike front bumper, Dobinsons IMS extended travel with 302/675, RCI sliders and skids. Method 701's 17x9 305/70/17 maxxis razr MT's, 4.88's, Brute force rear bumper, sherpa roof rack.
12-31-2021, 04:15 AM
just serious amounts of throttle, and a buddy with a snatch strap...lol
12-31-2021, 04:54 AM
To a certain extent yes but you’re suggesting to use as much as you can the first time around is better?
What motivated me to create this list is I have several neighbors who own 4Runner and Tacoma TRD Pros or Off Trail. None of us has had a lot of opportunities to use our A-Trac, Crawl or MTS function. So we thought it might be best to create a laminated card to keep in our vehicles as a quick reference card that explains each function and a get out of a jam check list. We understand that each situation will be different and dependent on the tools we have on hand. Everyone has a winch and some have a traction board. That’s why I listed those tools. I’m sure it would also be helpful to have a tow straps and kinetic rope as well.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Check Out My Shopping List
tyler.lewis |
3rd gen T4Rs |
33 |
04-26-2021 07:50 PM |
lift check list
highcj5 |
3rd gen T4Rs |
13 |
05-17-2016 10:48 PM |
Check my CB parts list
swapmeet |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
12 |
11-20-2014 04:19 PM |
check list
(4)runnin'it |
3rd gen T4Rs |
0 |
10-22-2009 11:19 AM |
