09-14-2021, 03:47 PM
Front passenger wheel rattle on washboard
Anyone figured out a fairly loud rattle from the front passenger wheel area on bad bumps like washboard? I’m starting to wonder if my steering vibration has anything to do with it, but seriously doubting it.
I only know about it because I rode shotgun with the windows all down and was a bit perturbed hitting rough stuff off-road. I figure some crack head here figured it out and wanted to ask.
Truck has 8,000 miles. SR5. Not relevant to 4WD. Heard it in 2WD. Sounds like something simple, but I don’t have a lift to pound around with a rubber mallet.
09-15-2021, 10:55 AM
I don’t think this is a common problem. If it is a reproducible problem then take it into the dealer as 8,000 miles your should still be warrantied.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
09-15-2021, 10:56 AM
This isn’t an endemic problem. You have something loose.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
09-15-2021, 06:20 PM
Could a rock have gotten in the hub cap?
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
09-15-2021, 07:57 PM
Got under the truck and banged around with a rubber mallet. All I hear that isn’t solid is the front skid plate. Rattly sounding. It’s going in to the dealer tomorrow for the never ending steering wheel vibration debacle, so I’ll have them look for it. I still get the squeak on compression from the front that sounds like a slight tire skid.
This is my first Toyota and I have to say it is definitely going to my wife and will likely be my last. I’ve never had a vehicle with so many interior and exterior noises. I’m not even trying on the horrible sunroof rattles. I just don’t have the energy after week after week of trying to find the dash popping. I did figure out the sunglasses holder rattles badly, but I don’t have a fix. Tried several things and got nowhere. I just turn the music up until I can get another car and give this to my wife.
09-15-2021, 10:21 PM
BorotHex, I had a rattle on my front driver side that was driving me nuts and I finally figured it out. My front brake cable bracket/holder was loose. I believe it was a 10mm bolt.
2016 4Runner Trail w/KDSS / Dobinsons 3/2" / Camburg UCAs/ KO2 275/7017 / Light Bar / Raptor Lights / Rockford Fosgate amp/ Rockford Fosgate P3 subwoofer / Thule 60" Aerobars
09-15-2021, 10:35 PM
It’s most likely the wheel liner, splash guard for the engine bay. The grommets work themselves loose and the rubber flaps causing almost a metal sound like skid guard or something loose. There’s a couple threads but not sure what the subject was.
So check that and add two sided tape as quick fix on the backside of the rubber the middle between the grommets. Push into the wheel well. My hasn’t worked loose after a year that I’ve heard. Haven’t check though.
Also check that the bolts on the skid plat are all there and tight. Another good bet if you had oil changes at the dealership.
09-16-2021, 12:00 AM
I had something similar happen while coming down a winding mountain road. I had been hitting a bunch of dirt roads in the days prior. Anyway, I pulled over and searched and searched until I randomly decided to tap on the wheel center cap and heard the rattle. I popped it off and out came the front hub grease cap. I smacked it back in with a rock. I guess just give it a check. Takes about 5 seconds to pop off the center cap with the tool in the trunk. Worth a shot.
Sent from my SM-N975U1 using Tapatalk
09-17-2021, 01:39 PM
Any luck? Now I'm just curious.
09-17-2021, 04:27 PM
I think its the splash guard too.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
09-19-2021, 01:42 PM
Real Name: Zach
Real Name: Zach
@ BorotHex
what'd you or the dealer find?
2017 ORP, 3" lift, Icon UCA, 34s, NTK Fab body mount, angle grinder bumper cuts, RSG sliders, 4.56 gears, Front & Rear E-lockers
1985 CJ-7, 4" lift, 35s, fully locked, fun to drive offroad
09-19-2021, 01:51 PM
Well the dealer ignored my recommendation to use a mallet and find the rattle. Instead, “drove on a bumpy road”, paved of course, and “heard nothing”.
So I have a suspension rattle, a strange barking chirping sound on bumps the dealer heard and said they can’t find what it is, and a vibrating steering wheel they claim they didn’t feel.
So my dealer is completely useless and there’s not another for hundreds of miles. I’m screwed until I move and can get rid of it.
09-19-2021, 01:52 PM
I have addressed that, so that’s not it. I wish it was.
I’ll check the skid plate bolts!
09-19-2021, 01:53 PM
I will check! Thanks!
09-19-2021, 04:09 PM
Didn't you announce you were trading in your 4Runner on a Frontier?
