Old 09-14-2021, 03:47 PM #1
BorotHex BorotHex is offline
BorotHex will become famous soon enough BorotHex will become famous soon enough
Front passenger wheel rattle on washboard
Anyone figured out a fairly loud rattle from the front passenger wheel area on bad bumps like washboard? Iím starting to wonder if my steering vibration has anything to do with it, but seriously doubting it.
I only know about it because I rode shotgun with the windows all down and was a bit perturbed hitting rough stuff off-road. I figure some crack head here figured it out and wanted to ask.
Truck has 8,000 miles. SR5. Not relevant to 4WD. Heard it in 2WD. Sounds like something simple, but I donít have a lift to pound around with a rubber mallet.
BorotHex is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 10:55 AM #2
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
I donít think this is a common problem. If it is a reproducible problem then take it into the dealer as 8,000 miles your should still be warrantied.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4í Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 10:56 AM #3
jp.vegas jp.vegas is offline
jp.vegas is a jewel in the rough jp.vegas is a jewel in the rough jp.vegas is a jewel in the rough
This isnít an endemic problem. You have something loose.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 06:20 PM #4
Turfboy Turfboy is offline
Turfboy is on a distinguished road
Could a rock have gotten in the hub cap?
2016 trail premium,KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod, Rear Differential Breather Mod To be installed: URD Supercharger
Turfboy is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 07:57 PM #5
Got under the truck and banged around with a rubber mallet. All I hear that isnít solid is the front skid plate. Rattly sounding. Itís going in to the dealer tomorrow for the never ending steering wheel vibration debacle, so Iíll have them look for it. I still get the squeak on compression from the front that sounds like a slight tire skid.
This is my first Toyota and I have to say it is definitely going to my wife and will likely be my last. Iíve never had a vehicle with so many interior and exterior noises. Iím not even trying on the horrible sunroof rattles. I just donít have the energy after week after week of trying to find the dash popping. I did figure out the sunglasses holder rattles badly, but I donít have a fix. Tried several things and got nowhere. I just turn the music up until I can get another car and give this to my wife.
Old 09-15-2021, 10:21 PM #6
CSM4runner's Avatar
CSM4runner CSM4runner is offline
CSM4runner is on a distinguished road
CSM4runner's Avatar
BorotHex, I had a rattle on my front driver side that was driving me nuts and I finally figured it out. My front brake cable bracket/holder was loose. I believe it was a 10mm bolt.
2016 4Runner Trail w/KDSS / Dobinsons 3/2" / Camburg UCAs/ KO2 275/7017 / Light Bar / Raptor Lights / Rockford Fosgate amp/ Rockford Fosgate P3 subwoofer / Thule 60" Aerobars
CSM4runner is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 10:35 PM #7
dipNrip dipNrip is offline
dipNrip is on a distinguished road
Itís most likely the wheel liner, splash guard for the engine bay. The grommets work themselves loose and the rubber flaps causing almost a metal sound like skid guard or something loose. Thereís a couple threads but not sure what the subject was.
So check that and add two sided tape as quick fix on the backside of the rubber the middle between the grommets. Push into the wheel well. My hasnít worked loose after a year that Iíve heard. Havenít check though.
Also check that the bolts on the skid plat are all there and tight. Another good bet if you had oil changes at the dealership.
dipNrip is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 12:00 AM #8
GT0neX GT0neX is offline
GT0neX is on a distinguished road
I had something similar happen while coming down a winding mountain road. I had been hitting a bunch of dirt roads in the days prior. Anyway, I pulled over and searched and searched until I randomly decided to tap on the wheel center cap and heard the rattle. I popped it off and out came the front hub grease cap. I smacked it back in with a rock. I guess just give it a check. Takes about 5 seconds to pop off the center cap with the tool in the trunk. Worth a shot.
Sent from my SM-N975U1 using Tapatalk
GT0neX is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 01:39 PM #9
Any luck? Now I'm just curious.
Old 09-17-2021, 04:27 PM #10
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I think its the splash guard too.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 01:42 PM #11
gringo8251's Avatar
gringo8251 gringo8251 is offline
Real Name: Zach
gringo8251 is on a distinguished road
gringo8251's Avatar
Real Name: Zach
@BorotHex what'd you or the dealer find?
2017 ORP, 3" lift, Icon UCA, 34s, NTK Fab body mount, angle grinder bumper cuts, RSG sliders, 4.56 gears, Front & Rear E-lockers
1985 CJ-7, 4" lift, 35s, fully locked, fun to drive offroad
gringo8251 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 01:51 PM #12
Well the dealer ignored my recommendation to use a mallet and find the rattle. Instead, ďdrove on a bumpy roadĒ, paved of course, and ďheard nothingĒ.
So I have a suspension rattle, a strange barking chirping sound on bumps the dealer heard and said they canít find what it is, and a vibrating steering wheel they claim they didnít feel.
So my dealer is completely useless and thereís not another for hundreds of miles. Iím screwed until I move and can get rid of it.
Old 09-19-2021, 01:52 PM #13
I have addressed that, so thatís not it. I wish it was.
Iíll check the skid plate bolts!
Old 09-19-2021, 01:53 PM #14
I will check! Thanks!
Old 09-19-2021, 04:09 PM #15
02SE 02SE is online now
02SE is just really nice 02SE is just really nice 02SE is just really nice 02SE is just really nice 02SE is just really nice
Didn't you announce you were trading in your 4Runner on a Frontier?
02SE is online now   Reply With QuoteReply With Quote
figured , front , passenger , washboard , wheel
Front passenger side window rattle JeffMerr 4th Gen T4Rs 7 09-25-2017 04:35 PM
Passenger Front wheel seizing up in reverse tstx92 3rd gen T4Rs 2 07-13-2014 03:56 PM
New Sound from Passenger Front Wheel mistersnowman97 Classic T4Rs 2 02-13-2014 04:01 AM
Rattle on Right Front Wheel? dbsoundman 3rd gen T4Rs 1 11-29-2012 12:59 PM
WTB '08 T4R Front Bumper, Passenger Sideview Mirror, Passenger Rear Wheel Trim brianhoberg For Sale: T4R Items 0 02-28-2012 12:23 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
