Old 09-15-2021, 04:23 PM #1
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Did the dealer place my spare upside down?
Went in for my 5,000 mile service (add oil change) which would otherwise consist of a tire rotation, inspecting a few items, and checking fluid levels. Noticed that my spare is now “pretty side up” so when I look from under the back bumper, I am looking at the inside (open end) of the spare’s rim.
Is this the typical way for 4Runners to carry the spare? It seems tightly mounted and secure, but quite odd and I’ve never had a vehicle which carried the spare in such a way.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 04:32 PM #2
usdmej usdmej is offline
usdmej will become famous soon enough
the spare wheel/tire is pointed "pretty side up" from factory.
it's also a steelie (on non-AWD 4runners). generally 5 tire rotations aren't done unless you request for them specifically
usdmej is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 04:32 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
My 2013 SR5 is like that too. It has a steel rim so it's not to protect it. It also means the valve stem is up and tire pressure can't be checked without lowering it. A good reason for a matching rim and TPMS! I haven't tried turning it over. Lowering the wheel is good practice for when you have to change a tire on a dark rainy night.
Old 09-15-2021, 04:39 PM #4
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Almost all 4x4s that are meant for off road use will have the spare mounted that way. First - the spare tire hanger bracket has a big spring in the middle that would stick down a lot if the wheel was face down. Also you'd risk both damaging the pretty side of the wheel and ripping off the valve stem when you drag the spare across rocks and dirt - that happens a fair bit off road. Having it face up is the way to go. And how they come from the factory.
FWIW - if you do go off road in more difficult terrain you'll drag on the spare. It's normal. It usually won't hurt it. I've never punctured a spare or broken the wheel on a spare tire by sliding on it, but it's probably possible. I don't really worry about it.
Old 09-15-2021, 11:50 PM #5
MJKL02 MJKL02 is offline
MJKL02 is on a distinguished road
If you have a Limited Nightshade then you have a matching spare wheel and it should be mounted upside down to protect the face. Limited models are AWD and should have 5 tire rotations.
MJKL02 is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 10:36 AM #6
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
As others have said, that's the way it comes from the factory.
I doubt the dealer even lowered it to check the tire pressure. I sure can't get my dealer to check the pressure in the spare even though I ask them to every time I take it in for service.
fkheath is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 02:00 PM #7
DEUS-MACH1NA DEUS-MACH1NA is offline
DEUS-MACH1NA will become famous soon enough DEUS-MACH1NA will become famous soon enough
PSA: Only Limiteds have the capability for a 5th TPMS from the factory; it's not possible to add a 5th TPMS to other trims via Techstream, et al.
DEUS-MACH1NA is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 02:02 PM #8
Confirmed. I see 5 values for TPMS. They actually did inflate the spare (it was at 32 now it’s 47 Did the dealer place my spare upside down? but didn’t rotate it.
So weird. Also it threw me off being that rim is silver on the back and not black, but appears to be the same spoke pattern and size as the others.
Old 09-16-2021, 11:45 PM #9
On a true 4x4 you must have the spare the same size as the rest of the tires, i.e no "doughnut" spare, because there is no center differential. With an AWD vehicle you can get away with a doughnut spare.
Old 09-16-2021, 11:59 PM #10
flyrv9's Avatar
flyrv9's Avatar
The point is - if any tire should have TPMS - it's the spare since it can't be easily checked. Toyota screwed the pooch on this one.
Old 09-17-2021, 11:51 AM #11
wow good to know, i'll edit my post to correct it
4runners , open , rim , spare , typical
Spare tire carrier removal. Dealer keeping car overnight. DanielW 4th Gen T4Rs 20 11-20-2022 08:33 PM
Why Are My Photos Upside Down? 5thGen16 General Discussions 1 12-07-2016 03:26 AM
Upside down photos GRIMACE Software Related Questions & Answers 0 04-29-2015 01:48 AM
pictures upside down? rakorakozy General Discussions 5 02-05-2014 10:19 PM
Dealer Warranties - Best place to get them CApilot78 5th gen T4Rs 6 11-28-2010 11:37 AM
