Old 09-20-2021, 05:53 PM #1
usdmej usdmej is offline
usdmej will become famous soon enough
Icon 52700 rear spring stiffness and further research
after installing a lift kit for my 4runner (king shocks with stock front spring rate and icon 52700 rear springs) i've found the ride to be too stiff for day to day driving. my vehicle is stock weight with ~150 pounds of added gear (full length roof rack and sliders). when it's just me in the vehicle the ride is noticeably/annoyingly stiff. it only starts to get livable with at least 4 passengers total so i'm guessing ~400-500 pounds added weight. this is pretty consistent with Icon's recommended load range for the vehicle.
i'm currently considering either switching to a softer rear spring or adding some more full time weight to the vehicle. in the meantime, i've compiled a list of available rear springs and their spring rates that i've gotten either directly from the manufacturer or extrapolated through their claims.
if you have any more rates you'd like me to add that can be verified let me know and i'll add it to the list.
Rear springs
Stock - 174 lbs/in
Bilstein B12 - 186 lbs/in
Wheelers T12 - 195 lbs/in
Icon 52700 - 200 lbs/in
usdmej is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 11:07 AM #2
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
You might find a shorter coil to be the best fit.
ICON is a 2" Rear Coil (Medium Load). On 5th Gen, without
3rd row seat, some say they net a 2.25" lift at stock weight.
Maybe a 1 or 1.5" coil will be better.
Hope this helps.
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 12:08 PM #3
Hope this helps.
_
i did get a little more than the 2" lift advertised but not significantly more.
the height doesn't bother me, it's the stiff ride which is why im more focused on figuring out if the spring rate is the issue
Old 09-21-2021, 02:41 PM #4
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Rear springs
Stock - 174 lbs/in
You get the adjusters with your Kings in the rear? If so, try adjusting and seeing if that helps.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 03:07 PM #5
Offroading is lame Offroading is lame is offline
Offroading is lame is on a distinguished road
Icon big bad.
Offroading is lame is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 03:10 PM #6
i did and they are currently set to 1 click from full soft.
the damping isn't the issue, the springs with just 1 person in the car simply don't want to move over bumps. it takes a decent amount of weight in the rear before you can start absorbing large bumps
Old 09-21-2021, 04:47 PM #7
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
So the setting for kings for full soft is just regular kings without adjusters...lol. So you might want to set it to full soft, but don't expect a huge improvement or anything for that matter.
Either way, you have only 2 choices:
1. add more weight
2. choose a spring with a softer spring rate.
Suspension is all about compromises. You have to ask yourself what is more important, a nice daily soft suspension when its just you, or a bouncy, saggy suspension when your vehicle is weighed down. Prepare to spend money, if you looking for that "perfect" setup, and keep in mind, everyone's tolerance/comfort levels are different.
They do make "variable" rear springs now, but i haven't really researched them, but when i was shopping for rear springs, I remember them being marketed towards the heavier rigs.....
My experience is the exact opposite of yours. I went from a undersprung vehicle (all the time and 1 blown shock later) to a oversprung, stiff riding vehicle for daily commuting, but its nice and cushy when offroading or when vehicle loaded down.
Old 09-21-2021, 05:38 PM #8
yes i'm aware, the plan was always to do more high speed stuff later on where i could actually turn up the damping but one issue at a time i guess
i'm actually surprised that a small increase in spring rate (~10%) would make the ride so much harsh. maybe it's because the springs are located so far inboard so is more sensitive to any change in rate.
i'm currently leaning towards trying out the B12s to see how they ride, minus the labor it's a small cost to experiment with
Old 09-21-2021, 06:12 PM #9
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
I am not convinced that this is a spring issue. I've read about complaints that were very similar to yours: using a 2" spring that's 10% stiffer made the ride too harsh.
I still think it's damping. I'm running Toytech's superflex 2" spring, which is also about 10-13% stiffer and I don't have the issue. In fact, my rear 'softeness' feels about the same as the front according to my butt sensors. My setup is very similar to yours -- 550 lb front springs (OEM rating) with the exception of Toytech 2" spring in the back vs Icon. I am running adjustable Kings in the rear, usually about 4-6 clicks form the softest. If I turn them to the absolute softest, the ride is too mushy and soft.
The main difference is my rears were tuned by Accutune prior to shipping with their own flutter stack or whatever the term is.
Edit: my extra weight is as follows: RSG sliders, skids are aluminum save for the engine skid which is steel. NO other weight -- I have no bumpers, no racks, no spare parts with me when I'm driving to the store. I store zero gear in the back unless I'm heading out to wheel.
Kings, Icon UCAs, 285s, full armor, rear diff breather relocation, ECGS diff bushing, Rokmen trailing arms
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 06:35 PM #10
mrblah's Avatar
mrblah's Avatar
IMHO, any aftermarket suspension will be firmer than stock. A 4runner is a pickup truck with a camper on it. There is no way around it. I think social media sets us up for unrealistic expectations. We aint driving a highlander.
Once i realize that lifting our vehicles will decrease onroad comfort no matter what, i stopped caring about onroad comfort, and went nuts on improving offroading comfort, and did the following:
I had toytec superflex and went with dobinson's..which is even MOOOOO STIFF...
For me, I rather sacrifice on road/daily ride comfort for offroad and higher weight capacity because there is nothing worse than getting thrown about your vehicle when you are off the pavement. So i can live with my vehicle riding like a UHAUL truck on road to have a pleasant experience off road. Also, keep in mind, when you have your family and 2 dogs in the vehicle, they will comment on how lovely the ride is...just tell them you sacrifice driving a uhaul every day for them to have that lovely ride..rofl.
However, if you rarely go offroading..then yeah....pick the softest spring rate you want, but you still might not be happy. We are literally driving a pickup with a camper on it. (body on frame).
Old 09-22-2021, 10:55 AM #11
from my research, accutune's king shock revalve makes them stiffer as they claim the stock valving is too soft, so that would make my situation worse
Old 03-22-2022, 01:40 PM #12
kevwolford kevwolford is offline
Real Name: Kevin
kevwolford is on a distinguished road
Real Name: Kevin
Rear springs
Stock - 174 lbs/in
Just curious, where did you get stock and Icon numbers from?
kevwolford is offline   Reply With QuoteReply With Quote
Old 03-22-2022, 02:10 PM #13
icon spring rate was directly from them
stock spring rate is extrapolated from wheelers T12 claim that their spring is 12% stiffer than stock
lbs/in , rear , spring , vehicle , weight
Icon 52700 rear springs Localmotion 5th gen T4Rs 14 11-10-2022 02:15 PM
Icon 52700 rear springs- 2" lift 406 4runner For Sale: T4R Items 1 11-18-2020 07:18 PM
F/S 5th Gen Icon Rear Springs 2" Lift #52700 hearno For Sale: Suspension/Wheels/Tires 3 02-16-2016 10:17 AM
