Old 09-22-2021, 08:25 PM #1
SnoRnR's Avatar
SnoRnR SnoRnR is offline
SnoRnR will become famous soon enough
SnoRnR's Avatar
Switch Pro 9100 WHITE Lights Connection
Hi,
I’ve fitted the Switch Pro 9100 using the SDHQ dash mount for the control panel. The only thing I haven’t connected is the WHITE light trigger wire. Needs to be connected to a parking light signal or side marker. Is there anywhere I can connect it under the dash that doesn’t use an add a fuse?
I’ve already got various other items on add a fuses in the fuse panel. Running out of space down there.
2019 TRD PRO
Gobi Stealth No-Rise / C4 Fab Sliders / Xenon Depot HID Low LED High / Goose Gear Drawer & Sleeping Platform / RAGO MSP / ARB Dual Compressor / Shrockworks Dual Battery / ARB Differential Breather /
SnoRnR is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 02:50 PM #2
SnoRnR's Avatar
SnoRnR's Avatar
Anyone? Just looking for a parking light wire under the dash that isn’t in the fuse panel.
2019 TRD PRO
Old 10-02-2021, 03:12 PM #3
Nate_Drives_Cars's Avatar
Nate_Drives_Cars Nate_Drives_Cars is offline
Real Name: Nate
Nate_Drives_Cars will become famous soon enough
Real Name: Nate
I am doing this wiring myself tonight on my rig. I will let you know what I find out while wiring it in.
Connect with me on IG - @TRDLun4r
2021 4Runner TRD Pro | Lunar 1 | 2JZ GTE
2021 4Runner TRD Pro | Lunar 2
www.youtube.com/natedrives_
Nate_Drives_Cars is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 05:50 PM #4
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Hi,
If you are looking for just a trigger, how much draw is there?
I would think minimal for a trigger.
I know for a relay, draw is very minimal.
Best Regards,
Saker
Old 10-03-2021, 12:36 AM #5
[email protected] Evan@B.I.B is offline
Evan@B.I.B has a spectacular aura about Evan@B.I.B has a spectacular aura about
Maybe look for some of thr Raptor light write-ups/instructions. See what they tap into for the parking lights.
I would just do the tap-a-fuse.. its so much easier that way.
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
Evan@B.I.B is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 01:15 PM #6
sigepbiker's Avatar
sigepbiker sigepbiker is offline
sigepbiker is on a distinguished road
sigepbiker's Avatar
I posted this for someone wiring up a 8100. Should be the same location of the wire...
2016 parking light wire location...
2016 Trail Premium Tires and sliders and some interior mods...
2005 SR5 Silver mod list
FOR SALE: Rear Diff Breather Fitting; 4th Gen Center Diff Switch w/ pigtails
sigepbiker is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 03:00 PM #7
SnoRnR's Avatar
SnoRnR's Avatar
Awesome thank you. Looking at the thread have two options the green parking light wire under the dash fuse panel or the green headlight assembly wire under the hood. I need to do this as the SP9100 is mounted on the SDHQ dash mount. It’s bright and distracting. Especially without all the stickers on the empty switches. You can’t dim the switches at all without this connection, even manually.
2019 TRD PRO
Old 01-19-2022, 09:36 AM #8
dakgildea dakgildea is offline
dakgildea will become famous soon enough
I don't have the white wire plugged into anything currently. I have all the wiring under the hood and not under the dash as that's where the control panel sits. First I had the white wire on an add-a-fuse to the trailer tail light fuse but the backlight would stay on even when the truck was off. Tried to then move the add-a-fuse to the Dome fuse. Same thing, backlight stays on. Is it possible to add-a-fuse for the white wire? It's already cut so I would need to extend it if I need to t-tap into something. As stated above, it's pretty darn bright.
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
dakgildea is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 11:50 AM #9
sigepbiker's Avatar
sigepbiker's Avatar
@dakgildea - Everything in the Engine Bay fuse box is always on from the battery, hence your issue. I found that out when adding a PowerTray and wanting some devices dependent on the Ignition.
You need to either run the wire to the inside of the 4Runner or tap the wire at Headlamp assembly for light dependence. Follow the link in this post that has more information:
Old 01-19-2022, 12:22 PM #10
You need to either run the wire to the inside of the 4Runner or tap the wire at Headlamp assembly for light dependence...
Go figure! I have the main light blue wire tapped into the 37 INJ fuel injecting system fuse and that only comes on when the key is in and on. Good to know about the white wire! I'll take a peek and see if I have enough wire to get it under the dash. Appreciate the insight.
Old 01-19-2022, 03:20 PM #11
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
What I did: add a fuse to connect the white wire with the “tail light” fuse, bottom on the left of the interior fuse box. The tail lights come on with both the parking lights and the headlights, so works perfectly for dimming when lights are on. I could not find anything in the engine fuse box that worked.
Note, I'm 2019. Not sure if the fuse box was changed in 2020+ but this works for previous years.
rageandlove is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 09:15 PM #12
Stembot Stembot is offline
Stembot will become famous soon enough
Did you have to change any settings on the switchpro using the Bluetooth app? I have used this fuse too but the dimming is still not working
Sent from my Pixel 2 using Tapatalk
My GearProject Page
Stembot is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 09:59 PM #13
I have blue to 5th fuse slot down on right side (blank ignition controlled spot) and white to the tail light fuse.
I'll take a picture of my S Pros setting in a bit and post it.
You have fuses (2A or so) in the add-a fuse? I sometimes forget that ;-)
Old 01-20-2022, 12:34 AM #14
Wires and two sliders. That's it. When you turn on the lights, it dims both.
Old 01-20-2022, 06:37 PM #15
You think its okay that I have the light blue wire on an add-a-fuse to the engine bay fusebox? Everything I've seen is in the cabin
add , fuse , panel , pro , switch
Switch Pro 9100 on 2020 SpaceBanana 5th gen T4Rs 22 09-11-2022 10:36 PM
Switch pro 9100 not connecting to app Flea7907 5th gen T4Rs 13 06-10-2022 10:02 PM
Switch-Pros SP-9100 Bluetooth App Bumbo Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-07-2022 10:13 PM
WTB: 9100 Switch Pro AMLOR For Sale: T4R Items 0 11-15-2020 04:02 PM
