Old 05-18-2022, 10:06 PM #46
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
I got the roof rack back from the powdercoater and it turned out really good. I've been busy mounting all the lights and running the wires through the tubing.
Just some of the wire I ordered:
Wires run to all the light locations:
Lights installed and all wired up. The wires all exit at the rear legs:
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 05-18-2022, 10:07 PM #47
Originally Posted by JBurt View Post
That looks so good! Maybe I missed it, but how are you mounting the front feet?
Sorry, I missed this. The front feet will just set on the roof, no bolts.
Old 05-19-2022, 09:27 PM #48
Finally got the roof rack installed. A few pics:
A good shot of the T-Slot aluminum extrusions:
And it just barely fits under the garage door. Just over an inch clearance!
I still need to wire the lights to my SwitchPros RCR Force 12 switch panel.
Old 05-19-2022, 09:48 PM #49
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Well color me impressed. Nice job!
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 10:41 AM #50
awesome work.
Old 05-20-2022, 10:47 AM #51
Lucas TRD Pro Lucas TRD Pro is offline
Lucas TRD Pro is on a distinguished road
Man, this is impressive!
Lucas TRD Pro is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 10:01 PM #52
Good day today. Got all the roof rack lights working. Also these arrived:
4.56 gears being installed soon!
Old 05-22-2022, 12:29 AM #53
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Just curious if you wired up the front roof rack lights yet and if so, have you tried it out and what do you think? Are they useful and is the glare very bad? I have an SSO rack and have been debating how useful or hurtful it would be to add a 40" bar on the rack.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 09:48 PM #54
I got the lights all wired up and working. However, I haven't had a chance to try them out at night yet, or aim them. Depending on the beam pattern, I don't think the glare should be that bad.
Old 05-24-2022, 07:28 PM #55
all about the optics. even if its a "spot" pattern, if the optics arent focused itll glare. then if you add rain to the mix it could get silly
Old 05-25-2022, 07:55 AM #56
Makes sense. So I wonder if Baja Designs S8 lenses have the correct focus for this? Since you can buy different beam pattern lenses, but not really more focused lenses.
Old 05-25-2022, 04:42 PM #57
I believe Diode Dynamics currently has the best optics right now. Baja are more race oriented so they do have some spill even in the spots, but maybe thats just splitting hairs lol....my XL pro's in the spot pattern are pretty tight but theyre in front of the bumper.
tacoma world has some great threads discussing this stuff in detail.
Old 05-28-2022, 06:39 PM #58
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
Hey Bandit, was the risk of denting the roof with the front feet on your radar? After seeing your pics it reminded me of this Baja rack thread where the front feet were wider than the channel and ended up with damage. Baja apparently later updated their foot design to accommodate it, but not until some pretty gnarly damage was done.
I love the rack, I'm just lookin' out!
grizzlypath is offline   Reply With QuoteReply With Quote
Old 05-28-2022, 09:19 PM #59
After looking at the pics in that thread, I don't think it will be an issue for me. Mine mounts a little differently - more flat to the surface. I also have a 1/4" thick closed cell foam under the feet. Thanks for looking out though! I'll keep an eye on them.
Old 06-06-2022, 09:44 PM #60
4.56 gears are installed, and I'm about half way through the break-in period. Loving them so far.
Also, I installed the SwitchPros RCR Force 12 switch panel. I like having it at just below eye level and within easy reach of my right hand. So I mounted it between the speedometer and center dash vent. I had to make a custom mount for it, in order to put it in the location I wanted.
3D Printed mount test fitting:
Switch panel mounted:
And finally with everything wired up:
4runner , build , i’m , thing , truck
Bandit Runner's Build Thread Bandit Runner 3rd gen T4Rs 969 08-16-2021 01:08 AM
Bandit Runner's Roof Rack Build Bandit Runner 3rd gen T4Rs 176 10-29-2017 07:25 PM
Bandit Runner's Custom Snorkel Build Bandit Runner 3rd gen T4Rs 107 01-13-2017 03:19 PM
Bandit Runner's Projector Headlights Bandit Runner 3rd gen T4Rs 51 01-18-2013 12:57 PM
Bandit Runner's Rear Bumper Bandit Runner 3rd gen T4Rs 14 06-09-2011 11:46 PM
