Old 03-14-2023, 09:52 PM #76
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
So I finally finished up my upper and lower grille mods. Pics of grilles with mesh attached. I also painted the Toyota symbol to color-match the truck.
I made a bracket and installed Diode Dynamics lights in the lower grille area. I added two small red lights in the upper grille area.
And finally with the bumper back on:
Pretty happy with how it all turned out. Still need to wire up the lights.
Also, You'll notice that I have cut away the lower portion of the bumper. I am designing and will soon start building a winch bumper.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 03-16-2023, 12:20 PM #77
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
That looks great. I'm excited to see what you came up with for a bumper. I think your 3rd gen's was great.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 03-16-2023, 12:31 PM #78
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
How did you attached the mesh?
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 03-17-2023, 10:00 AM #79
I had to epoxy some chunks of plastic around the backside perimeter. Then used small screws to attach the mesh to those plastic pieces.
It was actually quite a bit of work making sure everything fit correctly.
Old 03-26-2023, 09:35 PM #80
Sejin Sejin is offline
Sejin is on a distinguished road
Looking good!
Sejin is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 08:47 PM #81
I finished the preliminary design for the front bumper. Here are a few CAD images:
Then I built a prototype from 3/16" thick foam board and a lot of hot melt glue.
Installed on the 4Runner:
Winch sitting in prototype:
Building the prototype was worth while, as I found a few things I want to change in the design. Mostly tweak some angles so the bumper better lines up with what's left of the stock bumper. Pretty happy with the overall look of the bumper though. I'll update the design in CAD, and start building the real thing soon.
Old 03-29-2023, 09:35 PM #82
JBurt's Avatar
Real Name: Jeff
JBurt's Avatar
Real Name: Jeff
I've gotta say that's the best 5th gen bumper I've seen. Well done man.
Build
Old 03-30-2023, 09:27 PM #83
Thank you sir! Much appreciated.
Old 04-28-2023, 05:08 PM #84
Jedrattle Jedrattle is offline
Jedrattle is on a distinguished road
Cool build!
I liked your 3rd gen. I’m copied your roof rack for my 3rd gen. I had to sell it a few yrs back. But I’m back with a ‘22 ORP in Barcelona. I dig the mods. How are you liking the light setup?
`73 Ford Courier-40’s all Toyota underneath
‘22 ORP-DD-mild build
`05 Cummins...tow pig
Sold-‘98 Runner 4Runner Build
Jedrattle is offline   Reply With QuoteReply With Quote
Old 05-08-2023, 09:42 PM #85
Originally Posted by Jedrattle View Post
Cool build!
Thanks. For the little bit I've played around with the lights, I like them so far. Will be doing some camping soon and hope to really put them to use and see how they do.
Old 05-09-2023, 09:27 PM #86
Making some progress on the front bumper:
Old 05-20-2023, 10:03 PM #87
A little more progress on the front bumper:
Center section is basically done, just need to clean up the side edges yet. Then move on to the side wings.
Old 05-21-2023, 01:35 PM #88
this is awesome.
Old 07-17-2023, 09:20 PM #89
Well I finally finished all the fabrication on the front bumper. It took way longer than I expected, but I think it turned out really nice.
I also made a small skid plate that bridges the gap between the bumper and the OEM skidplate:
I just need to clean up a few things, and then get it off to the powder coater. Can't wait to finally get this thing installed.
Old 07-17-2023, 10:22 PM #90
JBurt's Avatar
Real Name: Jeff
JBurt's Avatar
Real Name: Jeff
Let me be the first to say: hot damn! That's a good looking bumper!
Build
4runner , build , i’m , thing , truck
Bandit Runner's Build Thread Bandit Runner 3rd gen T4Rs 969 08-16-2021 01:08 AM
Bandit Runner's Roof Rack Build Bandit Runner 3rd gen T4Rs 176 10-29-2017 07:25 PM
Bandit Runner's Custom Snorkel Build Bandit Runner 3rd gen T4Rs 107 01-13-2017 03:19 PM
Bandit Runner's Projector Headlights Bandit Runner 3rd gen T4Rs 51 01-18-2013 12:57 PM
Bandit Runner's Rear Bumper Bandit Runner 3rd gen T4Rs 14 06-09-2011 11:46 PM
