Old 09-23-2021, 04:03 AM #1
5th_gen_Porkchop 5th_gen_Porkchop is offline
5th_gen_Porkchop is on a distinguished road
Durable suspension lift kit
I want to install a durable lift kit, after some search my choice lean toward Eibach Pro-Truck and Bilstein 6112/5160. I'm I on the right way? Better alternative? Which one will last longer and perform better?
Thanks for your help.
5th_gen_Porkchop is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 10:11 AM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
How much lift do you want? If only a small amount, then the leveling kits that only use spacers are the most durable -- there is nothing to wear out. I got the Rough County leveling kit which gives 2.5" front and 1" rear.
fkheath is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 10:33 AM #3
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
Agreed on the “the simpler is better” “KISS” approach.
Another thought was that for your suspension to be durable you need to match it to the actual activity.
Carrying 300lbs of tools to the job-site via a gravel road? Carrying a winch up front? Go with a Dobinson's uprated strut, shock,spring kit. (This is what i have, 200+ up front, 500+ in the rear)
Doing whoops and dunes each weekend at Oceano or Glamis? Dobinsons/King/Fox bypasses to keep your shocks cooler over many, many cycles.
Mostly daily driver and some light weekend wheeling, carrying very little extra weight (no skids, sliders, tent, etc)? Quality spacer kit for sure.
One thing i have not mentioned is budget. I would council you NOT make your choice based on budget. Consider saving up if you need to, to get what you need. This “Buy once, cry once” mantra has served me well on my last two 4x4 builds.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 10:40 AM #4
I considered both of those kits. I couldnt find enough user feedback to sway me towards the Eibach kit. The Bilstein kit with their national backorders simply couldnt be found in my timeline. (Good kit, though)
I went Dobinson’s for several reasons:
1. Mike at exit offroad is awesome. Great customer service- answered all my questions
2. Kit is highly recommended and well reviewed on this site
3. Kits allow you to choose from many options at purchase for your specific use, including KDSS/non-KDSS ( some kits dont even mention if they’re KDSS compatible)
4. My kit was in stock and available. Bought and shipped within a couple weeks.
Old 09-23-2021, 11:29 AM #5
AggieOE's Avatar
AggieOE AggieOE is offline
AggieOE will become famous soon enough
AggieOE's Avatar
I've read enough rough reviews on the 5160s due to leaking that lead me to the Bilstein 5100 set up with a spacer in the rear. Bilsteins are known for good shocks so I felt like this was a durable, reliable option.
That being said, my use is DD, long-distance road trips, family around town travel, and some challenging dirt trails here and there. Also, this is my wife's DD.
So, I wanted a slightly more stiff ride than stock (more stable), a noticeable lift, and nothing crazy cost or component involvement-wise.
Bilsteins 5100s, set at 1.75" up front with Cornfed 1.5" rear spacers was perfect for me. When I tow or load the car up completely, I air up the AirLift 1000 airbags in the rear to maintain rake and ride comfort.
My one other friend with a 4Runner says ours drives leagues better than his stock set up and I completely agree.
For durability, the less you have to modify, the better. Small lift = no CV compromises or UCA issues.
2015 4Runner SR5 4x4, Bilstein 5100s at 1.75-F with 1.5" Cornfed-R, AirLift 1000 Airbags, 265/70 BFG KO2s, Shrockworks Sliders
2016 Jeep Wrangler Unlimited Rubicon
AggieOE is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 12:02 PM #6
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
BP51 very reliable and corrosion resistant plus extremely adjustable very pleased 2 years so far
Mudballz is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 12:13 PM #7
4runr4eva's Avatar
4runr4eva 4runr4eva is offline
4runr4eva will become famous soon enough 4runr4eva will become famous soon enough
4runr4eva's Avatar
Thumbs up
I had a TRD Pro Suspension kit installed 2 years ago and broke both coilover springs up front this Summer after less that 10,000 miles. No abuse, I think the Toyota coils had defective metal. I didn't want to deal with a warranty claim that could have taken months to resolve so I just swapped it out for this and could not be happier. Its a great kit.
TTHA-CK-RCC - 3" Lift W/ Bilstein 5100 Front Coilovers (FJ/4Runner/GX)
4runr4eva is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 02:19 PM #8
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Durable? Only one brand comes to mind OME
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 02:06 AM #9
Interesting, for some reason I completely overlooked Dobinson.
Old 09-24-2021, 11:17 AM #10
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
+1 to Dobinsons and specifically buying from Mike at exitoffroad.com, hands down best customer service and he will help you understand all the options and make sure you're happy. Check his thread for info: Dobinsons 5th Gen T4R Suspension options - lots of choices
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 08:14 PM #11
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I've had Eibach springs, 5100's, and JBA uppers with a .75 cornfed spacer in the rear for about 30k miles. I have rokmen rear arms and a lot of poly bushings too but the basic suspension setup has been bulletproof and it's my DD and sees some dirt too. It also handles SO much better than stock.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 11:47 PM #12
hallcs hallcs is offline
Banned
hallcs will become famous soon enough
Banned
More votes for Exitoffroad
Another vote for Mike at ExitOffRoad and Dobinsons, Mike is great and Dobinsons IMS are butter smooth after a 2 week settle in period. Easy install and couldn't be happier. My suspension twice as nice as factory, don't feel like its gonna jump lanes if I look away for a second and braking is amazing now. Do yourself a favor and get new UCA's and if you have KDSS get the Treaty Oak spacers, super easy install.
hallcs is offline   Reply With QuoteReply With Quote
Old 09-25-2021, 06:51 PM #13
Definitely looking at Dobinson, I also want to install UCA's just didn't make a choice for now and yes I will get KDSS spacers, I start taking info on Panhard rod extension brackets too.
* Went with Eibach pro truck lift with Dobinson UCA
alternative , durable , kit , lift , longer
Durable Paint Recommendation? MrSeth 4th Gen T4Rs 4 09-10-2019 09:24 PM
How durable is the SR5 cloth interior jrm 4th Gen T4Rs 17 02-20-2016 12:35 PM
Best durable suspension swap with 3-6" lift tennis974runner 3rd gen T4Rs 10 02-18-2014 01:31 PM
Extereme durable configuration from the factory lightbulb 4th Gen T4Rs 7 01-21-2012 09:23 AM
