Old 09-23-2021, 02:14 PM #1
Bonniem's Avatar
Bonniem Bonniem is offline
Bonniem is on a distinguished road
Bonniem's Avatar
differentials oil change question
Hi, question about front and rear differentials oil changes. My truck is 3.5 years old with only 25k miles on it. Minimum off roading and a few water crossings. Is it time to change?
Thanks
Bonniem is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 02:41 PM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Well, I like to get the factory fill out after a couple thousand miles, after the ring and pinion have been run in.
I would certainly check the diffs, and T-case for the presence of water, after any water crossing which was deep enough to have those components under water. If running through deep water is frequent, I would extend the diff, and T-case vents.
That said, lots of vehicles go to the scrap yard with the factory-fill still in the diffs, etc.
02SE is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 02:45 PM #3
Bonniem's Avatar
Bonniem's Avatar
How do I check them for water presence?
Old 09-23-2021, 02:50 PM #4
Whippersnapper02's Avatar
Pull the fill plug and check to see if the fluid is milky. Generally I change my gear and transfer case oil at 30K. However I may just wait until 50K and do it at the same time as the transmission fluid.
Old 09-23-2021, 02:59 PM #5
Bonniem's Avatar
Bonniem's Avatar
Thanks
Old 09-23-2021, 05:59 PM #6
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
this!!!
Old 09-23-2021, 06:20 PM #7
spartacus's Avatar
spartacus's Avatar
If you are thinking about it then it might be good to change it. I drove in a rain storm in Michigan from Detroit to Dearborn on m39 through some really deep stuff under the over passes where the road dips down to accommodate the streets above and it bugged me until I drained and filled the front, rear and transfer case. The old fluid was fine but now I can sleep better.
Old 09-23-2021, 06:24 PM #8
josephp732 josephp732 is offline
Real Name: Joe
josephp732 is on a distinguished road
Real Name: Joe
I do the same thing. Get a few thousand miles on a new vehicle then change the front, rear diffs and transfer case fluid. I am always a bit amazed by what's on the magnets after only a few thousand miles. Plus these are easy fluid changes on our 4Runners - cheap insurance.
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
josephp732 is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 08:11 PM #9
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
Thanks
I have changed front/rear axle, transfer case and transmission fluids all at 15k miles and this is my what I saw and recommend.
- Rear axle oil needed to be changed
- Front axle oil was like new
- Transfer case oil was like new
- Transmission oil was light brown
So with all that I would only do the rear axle and transmission pan drain/fill at every 25k mile and the front axle and transfer case at every 50k miles.
Only my 2 cents.
2018 4Runner SR5
2002 4Runner Limited (low mileage, my dad purchased new)
2008 FJ with Off-Road Package (191k miles) Sold 6-19
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 08:20 PM #10
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
Thanks. This is very useful and much appreciated.
BorotHex is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 08:33 PM #11
orcking orcking is offline
orcking is on a distinguished road
I am sorry but that line "How do I check them for water presence?" beside your profile picture was really funny......
good luck
orcking is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 09:46 PM #12
Bonniem's Avatar
Bonniem's Avatar
Smile
I knew someone would mention that:thum
Old 09-23-2021, 09:47 PM #13
Bonniem's Avatar
Bonniem's Avatar
Old 09-23-2021, 10:40 PM #14
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Only my 2 cents.
Totally agree with this. Your rear diff will be very dirty and needs to be changed.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 03:44 PM #15
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Only my 2 cents.
This is spot on info and exactly what I experienced. I did my rear diff at 2966 miles and I was shocked at how the fluid looked and the amount of metal shavings on the magnet. One thing I would add is swapping the transfer case fluid from factory fluid to a 75-90 weigh gear oil smooth out the overall function of the transfer case.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
change , differentials , oil , question , roading
differentials and transfer case fluid change James5354 5th gen T4Rs 8 08-18-2020 10:42 PM
How Long Do Differentials last? blackmax 4th Gen T4Rs 5 07-04-2011 02:28 AM
Differentials - Auto LSD question stockrunner Off-Roading 5 02-14-2011 11:29 AM
FLUID change in transfer case and both differentials buzzie0013 Classic T4Rs 11 07-30-2010 11:28 PM
