Old 09-24-2021, 04:22 PM #16
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Frankly I would do it.
With a new vehicle, I would do it before 1000 miles.
And the engine no more than 500 miles.
There is a lot of break in material suspended in the oil while the newly machined metals wear in to each other.
I just received Amsoil synthetic 75W110 GL5 severe duty gear oil for the diffs and Royal Purple Syncromax synthetic GL4 for the transfer case.
Also received the Toyota WS tranny fluid for a complete change.
If worried do an oil analysis, but a change will always help.
seatia is offline   Reply With QuoteReply With Quote
Old 09-25-2021, 11:11 AM #17
Bonniem's Avatar
Bonniem Bonniem is offline
Bonniem is on a distinguished road
Bonniem's Avatar
Which one would you use between these two
differentials oil change question-e1d6796b-aecf-427b-abdf-60ba81707511-jpg  differentials oil change question-18532444-9487-4f82-923c-76320bfbcc15-jpg
Bonniem is offline   Reply With QuoteReply With Quote
Old 09-25-2021, 11:31 AM #18
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Redline is a fantastic product and highly recommend but I like the easy bags that Amsoil has. No need to pump the oil into the diff or transfer case using a hand pump. With the bag you just squeeze the fluid in and your done. Both are fantastic gear oils.
differentials oil change question-a6f83476-19b0-43cd-8ea6-d4047fb61655-jpg
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 09-25-2021, 11:34 AM #19
Bonniem's Avatar
Bonniem's Avatar
Yours says “severe gear” what’s the difference?
Old 09-25-2021, 11:36 AM #20
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
It’s just the name!
Old 09-25-2021, 11:38 AM #21
Bonniem's Avatar
Bonniem's Avatar
I see
Thanks
Old 09-25-2021, 11:40 AM #22
Bonniem's Avatar
Bonniem's Avatar
But what’s the difference between redline High performance and the other one
Old 09-25-2021, 11:51 AM #23
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
It might be different labels on an older product. The current product labels seem to be all oval. See the website:
Red Line Synthetic Oil. Gear Oil for Differentials
Old 09-25-2021, 11:53 AM #24
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
The front diff, rear diff and transfer case all have crush washers. Part numbers are:
Rear Diff drain and fill plug: 12157-10010
Front Diff fill plug: 12157-10010
Front Diff drain plug: 90430-24003
Transfer Case fill and drain plug: 90430-A0003
There super cheep, probably less than $10 bucks for all the crush washers.
Old 09-25-2021, 01:47 PM #25
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
The "NS" stands for 'Non-slip', that version lacks friction modifiers. It's intended to be more suitable for transmissions and transaxles, where the slipperiness of the standard 75w90, can cause issues with synchros or clutches in limited-slip diffs.
I'd use the 75w90 in your diffs. Although Redline does sell 75w85 which meets the current Toyota CAFE-inspired spec for the diffs.
Redline also sells this which meets the Toyota spec for the T-case: Red Line Synthetic Oil. MT-LV 70W/75W GL-4 Gear Oil
Although the Redline 75w90 would be just fine in your VF2A transfer case too.
02SE is offline   Reply With QuoteReply With Quote
Old 09-25-2021, 03:44 PM #26
Bonniem's Avatar
Bonniem's Avatar
I guess that would be my choice to cover rear and front if needed.
differentials oil change question-5041c735-4123-4d27-88e4-9b8cffe642e4-jpg
Old 09-25-2021, 08:06 PM #27
Just so I'm clear. I would NOT use the 75W90NS in the diffs. The standard 75W90 would be preferable.
We use lots of Redline products in a professional racing application.
Old 09-25-2021, 08:25 PM #28
Bonniem's Avatar
Bonniem's Avatar
I got it, thank you to be corrected
Old 09-26-2021, 07:52 AM #29
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
Originally Posted by Hammer0313 View Post
This is spot on info and exactly what I experienced. I did my rear diff at 2966 miles and I was shocked at how the fluid looked and the amount of metal shavings on the magnet. One thing I would add is swapping the transfer case fluid from factory fluid to a 75-90 weigh gear oil smooth out the overall function of the transfer case.
For the transfer case oil I would only recommend using Toyota Transfer Case oil. I don't believe there is anything on the market that matches there specification. Toyota Transfer Case oil is specific for our 5th gen 4runners, it's expense but use the correct oil for this transfer case.
2018 4Runner SR5
2002 4Runner Limited (low mileage, my dad purchased new)
2008 FJ with Off-Road Package (191k miles) Sold 6-19
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 02:58 PM #30
Nick B Nick B is online now
Nick B is on a distinguished road
I’ve never seen those . Who sells them ?
Nick B is online now   Reply With QuoteReply With Quote
change , differentials , oil , question , roading
differentials and transfer case fluid change James5354 5th gen T4Rs 8 08-18-2020 10:42 PM
How Long Do Differentials last? blackmax 4th Gen T4Rs 5 07-04-2011 02:28 AM
Differentials - Auto LSD question stockrunner Off-Roading 5 02-14-2011 11:29 AM
FLUID change in transfer case and both differentials buzzie0013 Classic T4Rs 11 07-30-2010 11:28 PM
