09-23-2021, 02:36 PM
UCA's hitting spring at full droop
At full droop when on stands my Ironman 4x4 UCA's are hitting my spring.
If I switch to a tubular design from Dobinsons, Dirt King, or Camburg, do you think this will help with my clearance in this area?
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
09-23-2021, 03:16 PM
So, I went out & jacked mine up so it was fully off the ground in the front. The driver's side UCA does not make contact. The passenger's side just does touch right at full droop.
Dobinsons IMS & UCAs with about the same lift as you (3.5in F / 3in R).
ETA: I was on an uneven surface, so I'm not sure if that is a factor or not.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
09-23-2021, 04:28 PM
move the spring coil a little bit left or right (as in twist it left or right)...sometimes the UCA will find a empty spot between the coils for clearance
09-23-2021, 08:11 PM
I dont think thatll do the trick; its hitting pretty good
09-23-2021, 08:26 PM
limit straps. your ball joints will thank you.
09-23-2021, 09:30 PM
Care to share a link?
09-23-2021, 09:41 PM
Do you have a lot of preload?
09-23-2021, 11:21 PM
custom welding. its not difficult. and not necessary, for most setups.
09-23-2021, 11:22 PM
i was wondering about this actually. but preload changes ride height, not overall length of the assembly so it shouldnt matter right? he's just gonna have less droop travel from ride height but tons of bump travel
I kinda think it's the iron man uppers not playing nice with his extended travel shocks
09-24-2021, 12:01 AM
So unless he wants be Mr. Desert Runner, should he be fine on trails, etc?
09-24-2021, 11:06 AM
No it wont be fine on trails. Hitting a medium bump with any type of speed above 5 mph it will touch the spring.
I think (hope) switching to tubular UCA's will help.
I guess we will see.
I'm surprised more people havent ran into this problem.
09-24-2021, 11:10 AM
When you installed the UCA's do you torque down the long bolt while the vehicle was in the air or when the vehicle was on the ground with the wheels on? (You are supposed to do the latter)
Not sure if this would solve you problem entirely but it will help keep the UCA from dropping down so far at full droop and will put less wear on the bushings.
[ Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
09-24-2021, 01:16 PM
I bolted them on while in the air. So you are saying loosen them with the truck on the ground and re torque?
09-24-2021, 01:31 PM
Wouldn't that depend on the type of bushing the upper control arm has ? OEM type fixed bushing would make sense to do this since the bushing twists as the arm moves up, or down. Aftermarket polyurathane floating type wouldn't matter because the bushing doesn't twist, it rotates in the arm, right ?
Just looked up the Ironman4x4 upper control arms. Looks like these have OEM style rubber bushings on the body mount side, so like smeerun mentioned, the control arm bolt should be tightened and torque with the full weight of the truck though I'm not sure if this would prevent your issue of the arm hitting the springs
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
09-24-2021, 02:12 PM
See below:
You are correct, the OEM type fixed bushings require torque to happen with the full weight of the vehicle is present and not while in the air at full droop. I assumed the Ironman4x4 UCA's use OEM (I have Dobinsons which also use OEM bushings) though so thank you for verifying that.
Like I said, I dunno if this would solve your issue but I do recommend it. Please report back with your findings!
