Old 09-23-2021, 05:10 PM #1
orcking orcking is offline
orcking is on a distinguished road
limited 4LO
Hi Guys:
I have a limited All wheel drive.
today it was raining and I wanted to put it in 4HI and 4LO to test it.
I put it in 4HI and it was good.
stopped the truck, put in Neutral and put 4LO and then I put it in drive right away (I think I was suppose to wait for the lights to stop flashing) and I heard like a grinding sound and then I put it in Neutral right away.
The 4LO light stopped flashing and I was able to put it back in drive again.
I tested all configuration and they seem to be fine.
Could have I damaged something like transfer case teeth or tranny by doing this??
Thanks
orcking is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 05:18 PM #2
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
You have to wait till all the lights stop flashing to put it in gear. How many miles on the 4runner and when was the last time it was put into lo? You may not be exercising it enough. Mine made a grinding sound one time. That was when it was brand new and the first time it was ever put into lo. It has never done it again in almost 8 years. I do not think you damaged anything.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 05:28 PM #3
Buba1's Avatar
Buba1 Buba1 is offline
Buba1 will become famous soon enough
Buba1's Avatar
Same thing happened to me, got some grinding noises, and it was my first time ever going into 4Lo, it has roughly 400kms on it. Kinda scary to hear that, I hope that never happens again.
Buba1 is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 05:29 PM #4
Ya..
mine only has 20K on it. its a 2020
I think I put it in LO once before.
I need to put it in LO more often..
thanks for the input....
Old 09-23-2021, 06:02 PM #5
spartacus's Avatar
spartacus's Avatar
Originally Posted by orcking View Post
Ya..
I vé had that grinding noise once or twice. It should be fine. You have to be stopped or rolling just barely in neutral. Make sure the wheels are straight, Put it neutral and put it in 4lo wait for the light to go solid then give it slight bit of gas.
Edit: Important correction to the original post Just checked mine. The truck has to be completely stopped for the 4lo to engage and disengage.
Old 09-23-2021, 06:17 PM #6
Whippersnapper02's Avatar
Just don't make a habit of it but I'm sure it's fine. I've done it once myself in my Ranger but never had issues after.
Old 09-23-2021, 06:51 PM #7
Correct.
I was fully stopped in neutral.
I think I just put it in drive before the lights stopped flashing.
Even the manual is not very clear that if you should not put it in drive before the lights stop flashing.
One thing I don't understand. For the limited trim as it is all wheel drive all the time. Does the 4Lo and 4Hi change the power ration from rear to front? What is the ratio for each settings if anyone knows?
Old 09-23-2021, 07:02 PM #8
4Rums 4Rums is offline
4Rums will become famous soon enough
Correct.
L4L= Low 4wd with Locked Center Diff =fixed 50/50 front/rear distribution
H4L= High 4wd with Locked Center Diff = fixed 50/50 front/rear distribution
H4F= High 4wd with Free (unlocked) Center Diff = variable front/rear distribution
4Rums is offline   Reply With QuoteReply With Quote
4lo , drive , neutral , put , stopped
**Caleb's Limited build/repair thread - 98' Limited 4runner** calebb 3rd gen T4Rs 10 03-29-2021 05:38 PM
FS 5th gen OEM running boards for 2010-2013 SR5/limited and 2014-15 limited Dsgoat For Sale: T4R Items 1 10-31-2015 07:24 PM
2009 Limited V6 Muilti Mode 4wd Rear Diff not limited slip ? JCSTEW 4th Gen T4Rs 3 09-13-2015 10:00 PM
WTS 5th Gen Limited Running Boards & 20" Limited Wheels and Tires all new dannyair Want to Buy/Trade 4 07-07-2012 12:34 AM
2000 Limited W/Rear Locker and 18" Limited Wheels 4Runnin4 Classifieds - buy & sell (no commercial ads please) 6 03-04-2009 04:55 PM
