Old 09-26-2021, 10:03 AM #1
Blackwatch's Avatar
Blackwatch Blackwatch is offline
Blackwatch has a spectacular aura about Blackwatch has a spectacular aura about
Blackwatch's Avatar
Lifting a 2022 TRD Off-Road with KDSS or King Suspension
Hi, I'm ordering a 2022 TRD Off-Road with KDSS. I would like a mild lift and to offset the wheels to bring them flush with the fender flares.
I like the way the Pro sits so I'm thinking a 1"-2" lift in the front and 0-1" in the back.
I will be replacing the stock rims with TRD Pro rims. Eventually I would like to upgrade to King shocks.
Any suggestions on the best option for that lift and offsetting the wheels?
Thanks...
Blackwatch is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 11:24 AM #2
Taco Supremo Taco Supremo is offline
Taco Supremo is on a distinguished road
The Pro rims have a bit more offset than the ORP wheels so you might be happy with those without any spacers.
I run bilstein 5100's in mine. 1.75" with a 1" rear spring spacer. They're work fine. It's no King setup tho, that's for sure.
I'd suggest just waiting and getting whta you want (Kings) as opposed to doing something now and then replacing. Buy once, cry once. Defintely true with King.
Taco Supremo is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 07:21 PM #3
Soulsurvives Soulsurvives is offline
Soulsurvives is on a distinguished road
Actually the Pro rims have less positive offset. The OffRoad wheels are +15 and the Pro wheels are +4 if memory serves me. The Pro wheels alone will not sit flush with the fender flares. The op will need spacers or something like a -10 to -15 offset to sit flush. I also agree that getting the King from the start is the way to go.
Soulsurvives is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 08:18 PM #4
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
What tires are you looking to run? Stock tires 265/70-17s or something else? Your rim offset/backspacing will impact if you rub along with upsizing tires.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 11:02 PM #5
Jp9075 Jp9075 is offline
Jp9075 is on a distinguished road
Following
Jp9075 is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 07:59 AM #6
Blackwatch's Avatar
Blackwatch's Avatar
265 or 275, I was thinking the 275 would help the offset look.
I have read a lot of technical reviews online about wheel spacers prematurely wearing out front end components. I'm thinking I only need a half or 3/4 inch spacer. Hopefully that's not a big deal.
Excuse my ignorance but will the King suspension kit raise the truck at all?
If not, what's the easiest way to raise it an inch or two? And will the slight rise draw the wheels back in requiring more spacing?
Old 09-27-2021, 11:31 AM #7
ttime4four ttime4four is offline
ttime4four will become famous soon enough
Have a look at Westcott Designs kit for the Pro...
2021 4Runner Fox TRD PRO Lift Kit - Westcott Designs
Retains all of the Pro suspension goodness but provides a mild lift.
2021 SuperWhite ORP
Ironman FCP / WildPeak 285/70R17 / Sherpa Crestone / Autohome Columbus / OVS 180 Awn / C4 Slider / WD Ladder / OEM Audio+ / Rago Aux Battery with Redarc Charger / Trigger 4 / Husky Mats / Sequential Turn Signals / DD Pro Fogs / Ridgid Ditch Lights / Raptor Lights / EVO Corse DakarZero / Rockblokz Mud Flaps / Blackout Kit / TRD Pro Grill / C4 LoPro Bumper / Superwinch / Anytime Backup Camera / Canvasback / Rago Molle and Shelf
ttime4four is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 03:34 PM #8
Blackwatch's Avatar
Blackwatch's Avatar
Thanks, that might be ideal. I'm assuming this is not raising an off-road as high as the TRD Pros in that videa as they started life off slightly higher? And the 285/70/17 might rub on an off-road with this lift?
Does this mild lift draw the wheels inward?
Old 12-20-2021, 01:18 PM #9
Blackwatch's Avatar
Blackwatch's Avatar
I'm seeing that King suspension is an 8-10 month backorder item right now. I would like to find something for the spring.
What is an equivalent (hopefully cheaper) alternative to the King set up with KDSS?
I have a 4Runner ordered with KDSS and I would like to make the off-road into a Pro clone so looking to have a similar lift and stance.
Speaking with Westcott designs, they say I can go with their lift that is 3" front and 1.5" rear and there are no KDSS issues. This seems to be contrary to what I've read.
Is there a cheaper option that is similar quality to the King that allows me to adjust the lift?
Old 12-20-2021, 02:27 PM #10
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Radflo might be an option worth looking at.
Similar valving, but more options...
- You can get Standard or Extended Travel.
- You can get with Reservoir or without.
- Coilovers come Standard with a 600lb coil, but can upgrade to 650 or 700lb as well.
Their production lead time is quicker right now.
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 03:16 PM #11
usdmej usdmej is offline
usdmej will become famous soon enough
there are equivalents to King but not necessarily cheaper from Fox, Icon, and Old Man Emu
if you're looking to go cheaper there are some simpler offerings from Eibach, Bilstein, and Old Man Emu that aren't as fancy
usdmej is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 04:41 PM #12
LeesWagon LeesWagon is offline
LeesWagon is on a distinguished road
Apart from this only works if you already have a TRD PRO truck.. OP has a TRD Off road..
LeesWagon is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 05:01 PM #13
missinglink's Avatar
missinglink missinglink is offline
missinglink is on a distinguished road
Hit up shock surplus, they seem to be pretty knowledgeable.
missinglink is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 07:10 PM #14
Blackwatch's Avatar
Blackwatch's Avatar
This isn't a King set up but should suffice.
Bilstein B8 5100 Monotube Gas Adjustable Strut & Shocks Set for 2010-2 – Shock Surplus
Are the 5100s a better shock than the stock 4runner offroad shocks?
Old 12-20-2021, 09:56 PM #15
honda250xtitan honda250xtitan is online now
Go bilstein 6112 or fox 2.0 coilover for the front
for the rear go fox 2.0 shocks and the bilstein 1.5" springs.
1.25" wheel spacers will get you flush with the fenders on stock trail/trd off road/whatever theyre calling them now. I believe 1" is the minimum spacer you can use before you gotta trim the wheel studs. with wheel spacers and 285/70-17's expect to buy sawzall blades for the body mount.
kings are great. if you wanna abuse it, go for the kings/fox 2.5's/radflos/icon's/ome/bilstein 8100 etc. if its forest service roads, the setup above will be fantastic.
honda250xtitan is online now   Reply With QuoteReply With Quote
lift , off-road , rims , trd , wheels
2022 4Runner build site is up at Toyota! jlficken 5th gen T4Rs 80 09-01-2021 10:20 PM
2022 6th Gen graysquirrel 6th gen T4Rs 4 07-28-2021 09:58 AM
Lunar rock and army green available on 2022 TRD off road Redsoxx1918 5th gen T4Rs 55 07-24-2021 02:36 PM
SEMA Opportunity for an Off-Road Build TRD4runnin 5th gen T4Rs 44 06-06-2019 07:41 AM
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
