Old 12-20-2021, 10:57 PM #16
2barevo 2barevo is offline
Real Name: Chris
2barevo is on a distinguished road
Real Name: Chris
Kings all the way. The TRDOR looks gangsta in black.
2barevo is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 09:08 AM #17
Blackwatch's Avatar
Blackwatch Blackwatch is offline
Blackwatch has a spectacular aura about Blackwatch has a spectacular aura about
Blackwatch's Avatar
Originally Posted by honda250xtitan View Post
Go bilstein 6112 or fox 2.0 coilover for the front
for the rear go fox 2.0 shocks and the bilstein 1.5" springs.
1.25" wheel spacers will get you flush with the fenders on stock trail/trd off road/whatever theyre calling them now. I believe 1" is the minimum spacer you can use before you gotta trim the wheel studs. with wheel spacers and 285/70-17's expect to buy sawzall blades for the body mount.
kings are great. if you wanna abuse it, go for the kings/fox 2.5's/radflos/icon's/ome/bilstein 8100 etc. if its forest service roads, the setup above will be fantastic.
Thanks, this might be the sweet spot. What do you guys think of this package?
Fox 2.0 Performance Series Coilovers & Shocks Set for 2010-2022 Toyota – Shock Surplus
Are wheel spacers necessary? How about UCA?
Thanks!
Blackwatch is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 10:25 AM #18
Thanks!
If you want a nicer stance like you mentioned, yes theyre needed. otherwise just buy wheels you like with the appropriate offset.
UCA arent necessary with the fox 2.0 or bilstein 6112's. itll be noticeable if you add them later though. the extra castor feels nice on the highway. Dirt King Fabrication sells ball joint upper control arms with bushing pivots that are quiet and low maintenance (loosen the through bolt and grease them once or twice a year)
Old 12-21-2021, 10:45 AM #19
Blackwatch's Avatar
Blackwatch's Avatar
I ordered a set of black TRD Pro rims. Was thinking of going with 275s. Most likely Geolandars but the Wild Peaks are nice. From the reviews the Geos seem to be the best highway tire. Where I live there are just potholes and beaches to drive on. Most trails will scratch the hell out of a side by side let alone a truck.
My plan is to level it, 2" in the front and 1 inch in the rear. I believe a TRD Pro sits 1.5" higher in front and .5" higher in back than an off-road?
Old 12-21-2021, 11:25 AM #20
thatll look nice. i think the pro's are just higher in the front.
Old 01-04-2022, 05:54 PM #21
Viperbyte Viperbyte is offline
Viperbyte is on a distinguished road
Thinking same thing.
Was thinking about the same thing. Had read somewhere anything over 2" in the front causes lean, correct?
Viperbyte is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 10:13 AM #22
its random. but yes it can. ours has slight lean i only notice in pictures from looking at the bumper and front tires.
treatyoak offroad sells kdss spacers to help the system
Old 02-17-2022, 09:29 PM #23
Homesteader Homesteader is offline
Homesteader is on a distinguished road
I'm seeing that King suspension is an 8-10 month backorder item right now. I would like to find something for the spring.
What is an equivalent (hopefully cheaper) alternative to the King set up with KDSS?
I have a 4Runner ordered with KDSS and I would like to make the off-road into a Pro clone so looking to have a similar lift and stance.
Speaking with Westcott designs, they say I can go with their lift that is 3" front and 1.5" rear and there are no KDSS issues. This seems to be contrary to what I've read.
Is there a cheaper option that is similar quality to the King that allows me to adjust the lift?
I’m doing the same with IMS Dobinsons. 3.5” front and 1.5” rears from Exit off road and Mike didn’t say I would run into issues with the KDSS. But I did get the spacer kit and diff drop
Homesteader is offline   Reply With QuoteReply With Quote
Old 02-18-2022, 12:35 AM #24
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
The TRD PRO sits 1 inch higher in the front and the same rear ride height using the same rear springs(which determine rear ride height) in the rear as the TRD OR.
Sounds like you are just going for looks to match the TRD PRO and not really offroading it or getting super big tires , so complete new suspension is over kill .......unless money is not an object. I'm sure the aftermarket suspension companies would love to sell you a whole new suspension though .
You can put a 1 inch spacer (1/2" spacer gives 1 inch lift) in the front and match the stance of the PRO exactly. Like these ...Toyota 4Runner 1" Front Aluminum Leveling Lift Kit 2003-2019
Even though it says to 2019 ,They fit 22's as the suspension is the same as I just put Icons on my 22 and have lifted many 4runners.
That's what I ran years ago when I bought my first 5th Gen and there was no ride difference from stock and it aligned easily with stock UCA's .
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 04-20-2022, 09:48 AM #25
Desperado Desperado is offline
Desperado is on a distinguished road
Originally Posted by Taco Supremo View Post
The Pro rims have a bit more offset than the ORP wheels so you might be happy with those without any spacers.
I run bilstein 5100's in mine. 1.75" with a 1" rear spring spacer. They're work fine. It's no King setup tho, that's for sure.
I'd suggest just waiting and getting whta you want (Kings) as opposed to doing something now and then replacing. Buy once, cry once. Defintely true with King.
Does your 4Runner have kdss also? I have kdss and looking to get bilstein lift and people are telling me it won’t work because of my kdss
Desperado is offline   Reply With QuoteReply With Quote
Old 04-20-2022, 11:30 AM #26
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Who are these "people?"
Lifts work fine with KDSS. Just don't go too high with it.
One thing I have learned is to go with a progressive dampening. I have digressive Eibachs with my KDSS and hate them. Very rough.
Build thread
mscot is offline   Reply With QuoteReply With Quote
lift , off-road , rims , trd , wheels
2022 4Runner build site is up at Toyota! jlficken 5th gen T4Rs 80 09-01-2021 10:20 PM
2022 6th Gen graysquirrel 6th gen T4Rs 4 07-28-2021 09:58 AM
Lunar rock and army green available on 2022 TRD off road Redsoxx1918 5th gen T4Rs 55 07-24-2021 02:36 PM
SEMA Opportunity for an Off-Road Build TRD4runnin 5th gen T4Rs 44 06-06-2019 07:41 AM
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
