Old 09-29-2021, 03:45 PM #16
Originally Posted by Jetboy View Post
Reservoirs can help with cooling in some situations. I just don't think that it's a primary function to use the reservoir body as a liquid/air heat transfer radiator. Smooth body reservoir would be a really terrible design if that's the goal. The cooling is ancillary to the primary functions.
I think the rough math on maximum possible cooling from the reservoirs in this case would be something like 15% or so. The res probably increases oil capacity in the shock main body by about 20% and maybe another 15% in the res body. But then we'd probably reduce by some factor - due to the relatively small pumping volume transfer - not much oil is exchanging between the main body and the reservoir unless they're running a double hose setup with a check valve like some newer Fox setups or they are a piggyback where there's a significant fluid exchange. In our case there's just not much transfer of fluid or thermal energy. And the longer the hose the less thermal transfer. The hose its self probably has more cooling effect than the reservoir. The lion's share of cooling benefit in our case is from having more oil in the main shock body and lower internal pressure spikes.
I'd put the reservoir anywhere you want and not think twice about the cooling value.
nobody is mounting them on the frame rail for cooling issues, it looks cool ;)
Old 09-29-2021, 06:42 PM #17
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
Here is my setup
Show me your rear shock reservoirs-b46204be-14b7-4d8d-a872-f59b6241b406-jpg
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 09-29-2021, 06:45 PM #18
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by TRDHULK View Post
My 35s hit my reservoirs when flexing. Show me your set up so I can get some ideas please
is it both sides or just the driver side or passenger side?
Old 09-30-2021, 11:39 AM #19
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
Mine hit on both sides when I flexed.
I think I fixed it.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 01:42 PM #20
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I think I fixed it.
Pics please of fixed resi’s!
Best Regards,
Saker
Old 10-01-2021, 11:07 AM #21
TRDHULK's Avatar
TRDHULK's Avatar
Before
After
I used billet roll cage clamps and stainless hardware. Moved the reservoirs up just a bit and turned the knobs upwards since that's where they made contact with the tire
Old 10-01-2021, 11:14 AM #22
Saker's Avatar
Saker's Avatar
Before
After
That looks good!
Hopefully when the tire is stuffed, they will be clear of contact!
Best Regards,
Saker
Old 10-01-2021, 12:10 PM #23
mrblah's Avatar
mrblah's Avatar
Before
After
Hopefully, the fix works out for you.
Old 10-01-2021, 12:17 PM #24
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Definitely a cleaner setup as well.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 04:25 PM #25
x2 looks better anyways.
flexing , ideas , reservoirs , set , show
FS: Icon 2.5 Remote Reservoirs with Adjusters. NorCal shmabs For Sale: Suspension/Wheels/Tires 3 08-04-2020 11:24 AM
FS: 5th Gen Icon V.S. 2.5 Extended Travel CDCV w/ External Reservoirs Front and Rear Toda R For Sale: Suspension/Wheels/Tires 0 05-22-2020 10:27 PM
Fox remote reservoirs rubbing on KDSS lines? klk87 5th gen T4Rs 3 01-16-2020 10:44 PM
