Old 09-27-2021, 03:59 AM #1
5th_gen_Porkchop 5th_gen_Porkchop is offline
5th_gen_Porkchop is on a distinguished road
KDSS max lift?
With KDSS is there a recommended max lift?
5th_gen_Porkchop is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 09:04 AM #2
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
I believe 2.5" is really the max before you start to see lean or need to do other corrections. You may have to dig, but there are a number of threads on lifting with KDSS.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 09:45 AM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
i have a 3 inch lift, and didn't experience any problems.
Old 09-27-2021, 12:58 PM #4
usdmej usdmej is offline
usdmej will become famous soon enough
more than 2.5" in front and you run into geometry problems with your suspension
more than 1" in the rear and you'll need to add the sway bay spacers to avoid creating contact and limiting down travel
usdmej is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 02:08 PM #5
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I've had my KDSS rig lifted 3" front and rear for 8 years without issue. Never had any lean or other issues for over 100,000 miles. I've run the Sonoran Steel KDSS sway bar for a couple years and recently added the rear spacer blocks. I don't run the front spacer due to contact issues with my skid plate. I have always had adjustable coil overs which can be used to compensate for the lean in many situations.
I don't think there's any concern going up to 3" front and rear with KDSS, more so I'd be concerned with my CV's.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 06:38 PM #6
mrblah's Avatar
mrblah's Avatar
For a mid travel setup, you can lift up to 3 inches in the front and 2 to 3 inches in the rear just like a non-kdss 4runner. Will require the same upgrades (aftermarket upper control arm) as a nonkdss 4runner. Any higher in the front, your CV angles may look out of wack.
The difference between non-kdss and kdss is the installation, which requires a few more steps and due to the leverage is a PITA if you working in your driveway.
Only time, kdss and non-kdss makes a difference is if you go long travel and that just means you will lose your KDSS system that you paid good money for as a option.
Recently, extended travel was also iffy, due to possible contact of the rear sway bar with the rear track bar, but thats no longer the case with kdss spacers. Also, not all vehicles are affected by this.
The KDSS lean also affects some people more than others. It can occur with or without a lift. Not all vehicles are affected by this.
kdss , lift , max , recommended
4” Lift w/ KDSS 4CrawlerORP 5th gen T4Rs 20 08-23-2020 10:49 PM
Lift w/ KDSS Niteghost 5th gen T4Rs 50 04-02-2017 03:23 PM
Help! Lift with KDSS? redkaz04 5th gen T4Rs 15 05-04-2014 10:46 AM
KDSS, can you lift it? USMCASA 5th gen T4Rs 2 01-16-2014 03:55 PM
KDSS and lift sullyman New Members 0 06-12-2012 09:31 PM
