View Poll Results: What gear oil you running ???
75w90 mineral
1 |
7.69% |
75w90 synthetic
7 |
53.85% |
80w140 mineral
4 |
30.77% |
80w140 Synthetic
1 |
7.69% |
09-28-2021, 10:50 PM
Real Name: Justin
Real Name: Justin
Poll !!! For Elocker & regeared owners
Ive been running my front harrop elocker for almoat 2 yrs ... Ive recently stumbled on a gear fluid issue since I started doing my own gear fluid change.
I would like to poll people using elockers owners whether its factory or aftermarket or front and rear or rear only.
Ive been running Redline 75w90
But my gear manufacturer is stating 80w140 mineral oil versus Harrop suggest staying with the 75w90 synthetic but if I have too go 80w140 Synthetic becuse the mineral oil in colder climates will have issues with the magnet.
What gear fluid are you running ??? Please post your gear manufacturer and gear oil manufacturer your running...
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
09-28-2021, 11:37 PM
Although, your poll probably doesn't apply to me since i've only been regeared for a few days (in break-in period), but the shop insists 80/140 non synthetic as per Nitro. I didn't over think it, i just went what they suggested.
I do have a ton of 75w/85 synthetic sitting in my garage, so i'll probably ask if i can switch to that once im out of the break in period, or at least synthetic gear oil at a minimum.
I'm a belieber of synthetics man...
09-29-2021, 12:06 AM
Real Name: Justin
Real Name: Justin
Do you have a elocker ???
My Build Thread
09-29-2021, 12:19 AM
ARB airlock in the front, and OEM e locker in the rear.
09-29-2021, 08:24 AM
Nitro brand gears with elocker, been using same Toyota branded gear oil since day one. When I called Nitro prior to ordering there recommendation to me was to stick with what I have been using. Shop who installed it said to stick with that or an equivalent to what Toyota uses. I selected 75w80 mineral on the list/poll as I believe this is mineral oil, correct?
This spring the shop had to reopen the back to adjust the backspacing and found there was no damage of any kind at about 10k miles.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
09-29-2021, 09:46 AM
I run Lucas non synthetic 85w140 per ECGS. Maybe add that to your poll since that's their recommendation and will void their warranty. No issues with that for about 60,000 miles in Colorado weather. I'm factory e-locker rear only
09-29-2021, 01:27 PM
I run an Eaton E-Locker in the rear which is pretty much the same as your Harrop and was told 75w90 by their customer support. Im using stock ring & pinion gears
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
09-29-2021, 08:51 PM
Real Name: Kirk
Real Name: Kirk
Running 4.88's with the stock rear e-locker on a 2019 Pro. No locker on the front. With what I do it just would be an expensive bragging point.
Oil is Mobil 1 Delvac 75w-90 full synthetic - both pumpkins.
Synthetic 75w-90 was the manufacturers recommended lube for the 4.88's.
Locker works like stock - no issues.
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
