Old 10-01-2021, 02:23 PM #1
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
Supercharger/Turbo fuel Starvation
While preparing to install my URD Supercharger I noted there was a recommendation to not run the fuel tank below 1/4. It appears the container the pump sits in may restrict flow to the pump (the pump can empty the container faster than it can flow in).
This may be a problem with many forced induction cars as they tend to use fuel faster than what the manufacturer had initially designed for.
A possible solution is using a Fuel Surge Tank like the one here:
http://http://www.radiumauto.com/FST...dard-P515.aspx
Is anyone running something like this and what are your experiences?
Where did you mount it
How did you power it
Did you have any fuel starvation issues while screwing around at WOT?
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 05:56 PM #2
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
I run a Magnuson and usually fill up around the 70 miles to empty range. I’ve never noticed an issue running below 1/4 of a tank but then again I’m really WOT.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 06:13 PM #3
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Does one not upgrade injectors and fuel pump when adding forced induction on a Toyota?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 06:32 PM #4
osugsxr osugsxr is offline
What is turbo fuel??
Old 10-01-2021, 08:44 PM #5
jdm-v35 jdm-v35 is online now
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Maybe it could be a problem if you are flooring it while climbing a very steep hill. Other than that I think it is overcautious in this application because the fuel demand in the 4runner is really not going to be that much more than OEM.
A fuel surge tank would be way overkill for such a small amount of boost and low fuel demand.
jdm-v35 is online now   Reply With QuoteReply With Quote
Old 10-01-2021, 08:49 PM #6
a47chuck's Avatar
a47chuck a47chuck is offline
a47chuck will become famous soon enough a47chuck will become famous soon enough
a47chuck's Avatar
Originally Posted by Charlievee View Post
Does on not upgrade injectors and fuel pump when adding forced induction on a Toyota?
Magnuson has a rather mild, albeit, satisfactory tune which doesn't require any recommended upgrades to the fuel system. That said, if yer gonna push it, you'd definitely want to upgrade.
‘19 Limited Nightshade, Midnight Black Met, front leaving kit, 265/60R20 BFG KO2’s, fronts tinted to 20%, moonroof to 5%, Magnuson Supercharger
'03 Harley Dyna Superglide Sport
a47chuck is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 09:08 PM #7
a47chuck's Avatar
a47chuck's Avatar
Smart ass answer ... fuel for a turbocharged engine. HEH! To be honest, I've not heard of it. Takin' a WAG, I'd say it has more octane to reduce the chance of detonation under boost.
Old 10-04-2021, 10:03 AM #8
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
so i have the URD for i think 3+ years now.
I've gotten low below 50 miles range, but once i get to about 75 mile range, i drive a bit more gentle with no WOT. URD recommends not going below 1/4 tank for safety reasons. I think you are fine going below 1/4 as long as you aren't going crazy on the throttle.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
container , faster , fuel , pump , tank
4th Gen V6 Turbo/ supercharger info (Need Help!) Johns06yota 4th Gen T4Rs 17 01-02-2019 10:10 PM
Fuel mods for turbo? Bigmd 3rd gen T4Rs 12 08-24-2015 12:04 AM
Fuel Starvation / 1994 4R 3.0L FI / Need help rockinhorse77 Classic T4Rs 3 08-01-2013 08:26 PM
2005 Runner - Turbo or Supercharger?? RunnerJeff 4th Gen T4Rs 25 06-10-2012 11:09 PM
