Old 03-25-2024, 03:05 PM #1
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
100k Maintenance Decisions...What Did I Miss?
My '18 TRDP just turned 100k and I took it in for a full maintenance update. Let me know if I missed anything you would recommend be done as well
Oil Change
Filters
Power Steering
Coolant
Transmission
Differential
Brake
Spark Plugs
Grease Zerks
Evaluate all ball joints and bushings
*all the systems above are fluid flush/swap
Grape Ape is offline   Reply With QuoteReply With Quote
Old 03-25-2024, 04:43 PM #2
///AIRDAM's Avatar
///AIRDAM ///AIRDAM is offline
Real Name: Adam
///AIRDAM will become famous soon enough
///AIRDAM's Avatar
Real Name: Adam
Oil Change
Filters
Power Steering
Coolant
Transmission
Differential
Brake
Spark Plugs
Grease Zerks
You did more than 98% of vehicle owners will do to their vehicles at 100,000 miles. Main reason is, because of the list you listed, i suspect this was a $3500 ticket you had to cough up. Very few people do preventative maintenance, and on Toyotas they do less than anyone else because they are so reliable they just keep driving them. Friend of mine drove his 2003 4runner to like 330,000 before he had an issue that caused him to finally do some maintenance to it. Otherwise he drove the wheels off it, replaced tires and did oil changes and never touched it otherwise. Toyota is known for reliability and it shows, all the things you did honestly is great for peace of mind but truthfully not necessary.
Our plugs are known to get around 200,000 miles before they start going bad. Most drivers can get around 150,000 miles out of brakes if they dont drive like a woman in a hurry. Power steering fluid flush and change..... Meh i've never done that on any vehicle.... Our transmissions are "no maintenance transmissions" for a reason and you are not supposed to touch them. I drove my 1GR-FE tacoma to 275,000 miles before selling it and never touched the trans, diff, or power steering. Same with my now 230,000 mile 1GR-FE 4runner. I havent touched the trans, diff, or power steering fluids. You should be golden.... You changed things nobody does, i dont think you are going to hurt anything.
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
///AIRDAM is offline   Reply With QuoteReply With Quote
Old 03-25-2024, 06:18 PM #3
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
Oil Change
Filters
Power Steering
Coolant
Transmission
Differential
Brake
Spark Plugs
Grease Zerks
Maybe clean the MAF and throttle body if you haven't done so recently. Easy to do yourself especially the MAF, like 5 minutes. I found you tube videos on these.
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 03-25-2024, 06:58 PM #4
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
This.
I assume you changed out TC as you listed diffs, but I also placed my front hub/wheel bearings. I planned to change out my CVs, but I pushed that out a bit as mine still look good.
blksubykid is offline   Reply With QuoteReply With Quote
Old 03-25-2024, 09:22 PM #5
Great information to know! Fortunately, my mechanic is a an awesome shop owner and the tab came to $1700 OTD. I felt that was pretty fair. I haven't had a car payment in two years and have never paid for more than an oil change, a set of tires and brake pads.
Old 03-26-2024, 06:58 AM #6
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
PCV maybe.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 10:00 AM #7
I do trust what this guy recommends for the most part. He has several informative videos some bucking standard Toyota schedules.
The Car Care Nut - YouTube
Old 03-27-2024, 10:21 PM #8
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Serpentine belt is cheap and easy
1000MPH is offline   Reply With QuoteReply With Quote
Old 03-29-2024, 10:46 AM #9
That sounds extremely fair. And you didnt even need to get under the car
100k , change , maintenance , oil , spark
decisions decisions, air compressor garage vs portable hinmo24t 4th Gen T4Rs 8 11-09-2019 04:33 PM
2001 T4R 100K Miles maintenance Saeborne 3rd gen T4Rs 6 11-03-2014 08:24 PM
Looking at 100k miles '03 need help with maintenance HokieMan18 4th Gen T4Rs 17 07-23-2012 02:38 PM
100k mile maintenance? mikeleup 4th Gen T4Rs 1 05-08-2011 11:23 PM
100K Maintenance Q's from the new guy Aaron Fitch Maintenance/Detailing 2 02-26-2005 07:49 PM
