Old 10-01-2021, 05:23 PM #1
Nate_Drives_Cars's Avatar
Nate_Drives_Cars Nate_Drives_Cars is offline
Real Name: Nate
Nate_Drives_Cars will become famous soon enough
Real Name: Nate
Long Travel Questions
What are you running? What do you wish you did differently?
I am circling around the suspension set-up for the Lun4R build and I am curious about what you guys who have the long travel think and what mistakes/companies to avoid.
Connect with me on IG - @TRDLun4r
2021 4Runner TRD Pro | Lunar 1 | 2JZ GTE
2021 4Runner TRD Pro | Lunar 2
www.youtube.com/natedrives_
Nate_Drives_Cars is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 09:20 PM #2
Real Name: Nate
Real Name: Nate
Fender flares
Has anyone tried to run the Fiberglass fender flares on a 20-21? I dont see any options available for the 20+ Is there a difference in fender design that I need to know?
Toyota 4-Runner 3" Flare 2" Rise Adv Fiber Body Kit- Fenders AFC 165
Old 10-03-2021, 04:31 AM #3
Offroading is lame Offroading is lame is offline
Offroading is lame is on a distinguished road
Just be ready to maintain it and do it right. Mid travel is honestly not a bad option for most people. I have it because I fly through sand but just make sure you don’t blow off maintenance. People don’t grease or blast the heims and lose it when bushings blow out. I would say for the most part everyone that builds them is pretty reputable. Also when it comes to putting it on, try and do it yourself. You can rent every tool you need and it will help you get to know the pieces and where they go/ how they should look. It’s fairly straightforward. I don’t have flares but they are being color matched as I type this so I’ll let you know but the ones you posted will work with current year. If you end up going that route you might want to order coilovers now rather than later. I had custom coils built in a shorter time frame than if I were to buy them and wait.
Offroading is lame is offline   Reply With QuoteReply With Quote
Old 10-03-2021, 10:31 AM #4
x2 on the 8" shock comment.
otherwise camburg is about to release a +2 kit that retains OEM stroke coilovers. it's going to leverage the shock a bit more but the upside is you dont need to re purchase shocks. they have some details on their site under the tacoma tab for "trail series long travel" or something like that.
Old 10-03-2021, 12:38 PM #5
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
I had no idea. I lazily took another look at TC options yesterday and was like "LOL, totally not worth the total cost."
If Camburg does pull this off nicely, then it could be an interesting option down the road.
I am still not sold on any LT on a DD/general purpose 4R due to the maintenance though and mine will be that for a while longer.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 10-03-2021, 02:27 PM #6
Can’t stress this enough man it’s like 56 weeks right now. I’m buying 4.5” to replace my 2” and it’s going to require a long wait
Old 10-03-2021, 05:10 PM #7
Real Name: Nate
Real Name: Nate
I love the input. Well thought out comment... thank you for that.
I have all of the tools and experience to do it myself. You answered my questions. The 4r is a daily driver only as often as I want it to be, the build is supposed to be over the top but I would really like to have the ability to travel at higher speeds in various off-road terrain sand being the primary target. Everything on the build requires some maintenance. The coils are almost a year out if I go with King's which seems pretty standard for the long travel set ups. I am thinking the 3.5+ expedition kit from total chaos.
How often are you regreasing?
Old 10-03-2021, 05:16 PM #8
Real Name: Nate
Real Name: Nate
I came across the camburg setup in my research. I would like to go 3.5+ LT with the longer coils, the maintenance isn't terrible in comparison to some of the other vehicle ventures I have found myself in. Practical went out the window a long time ago on this build anyway
Old 10-03-2021, 07:06 PM #9
Like once a month. It doesn’t require “a lot” of maintenance like some people always say it’s just normal looking after it stuff. Be ready to never stop spending money and time on it. Also when it comes to running you’re going to want a secondary shock up front I promise you that. So it make sense to buy it as a pair so you can have the tuned together. Accutune does a great job if you tell them exactly what you’re doing with it. The rear is where I spent a lot of time as opposed to the front and finally have it in a great setup that is “comparable”to my actual prerunner but it took a lot of time so I would be thinking about that as well. I’m adding a fuel cell into it this weekend because the lean and At this point why not. I think it’s definitely worth it and fun to mess around with if you’re into that kind of thing.
Old 10-03-2021, 07:35 PM #10
Real Name: Nate
Real Name: Nate
We made it to talking about the rear LT stuff... I love this.
I have not been able to find much talking about the rear suspension. What's your set up with that, also completely agree the 2nd shock with the hoop is a must.
Old 10-03-2021, 08:59 PM #11
I have a Fox tundra 2.5 shock tuned for desert running and fox IFP bumps made for the raptor that I had tuned for my 4Runner and we messed around with nitrogen fill on it for awhile but finally came to a good bump. I would say the most important thing we did was all the work that went into tuning everything. I think any setup can work if you get the right people to move it along. The bumps are relatively more expensive then normal bumps from fox/king but the technology in them is amazing and really helps with everything. They feel a lot smoother than my kings on my other vehicle. Icon links but I don’t think that makes a huge difference. The rear spring I have is just a metal tech. It’s still a work in progress but I am very happy with where it’s at. It currently handles jumps and really rough terrain at high 50+mph. I plan on cutting through the frame and welding a mount above the frame for another 1.5-2” of up travel without getting into the body but that’s getting into the weeds on small things you can do.
Old 10-03-2021, 09:46 PM #12
they are packaging it with an optional hydraulic bump stop using their "slapper arm" setup. they use it on other kits as well.
Old 10-03-2021, 09:48 PM #13
cant wait to see this build evolve.
Old 03-27-2023, 11:43 AM #14
FavoriteAwa FavoriteAwa is offline
FavoriteAwa is on a distinguished road
Hi there! Unfortunately, I don't have much knowledge about suspension set-ups for vehicles, but I'm sure there are many enthusiasts out there who can offer their advice and experience.
FavoriteAwa is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 11:54 AM #15
YandoRyne's Avatar
YandoRyne YandoRyne is offline
YandoRyne is on a distinguished road
YandoRyne's Avatar
As for me, I'm not running anything at the moment, but I wish I had started running earlier in life. How about you? And have you thought about taking a break from your Lun4R build to treat yourself to some business class flights and a vacation? Business Class Flights - Cheap Business Class Deals to Worldwide
YandoRyne is offline   Reply With QuoteReply With Quote
build , guys , long , mistakes/companies , travel
Cheapest Long IFS long travel Kits? Cap. Morgan General Discussions 19 05-05-2020 02:28 AM
Long travel Dezerts10 3rd gen T4Rs 22 09-10-2017 06:19 PM
Dirt King Long Travel System, 14" Travel - +3.5" Wider - Under 2700 Delivered!! TotalAutomotiveLV Total Automotive Performance 13 07-04-2017 02:32 PM
Long Travel set up HiluxSurfGuy 3rd gen T4Rs 15 06-19-2017 03:12 AM
3rd Gen Long Travel Questions liftedbrigade 3rd gen T4Rs 6 03-29-2013 11:08 PM
