10-06-2021, 12:34 PM
lifted KDSS front swaybar interfering with oil change
had my 2020 KDSS lifted ~2.5" in front on jack stands this past weekend to do an oil change and i noticed that the sway bar was pivoted to the rear of the car so that it prevented my oil filter housing from being removed
it was blocking it by only a few mm, but i still had to grab a small prybar to pivot the swaybar out of the way to get my oil filter housing removed
anyone else run into this problem? could it be alignment related? i'm on SPC upper control arms using the recommended caster adjustment.
i should have taken a picture but i was in a hurry to complete the job
10-06-2021, 04:49 PM
I dont remember it being an issue. but maybe the beers clouded my memory? i'm on 2.5" or so of lift as well.
10-06-2021, 06:08 PM
"had my 2020 KDSS lifted ~2.5" in front on jack stands this past weekend to do an oil change"
I have a 2.5" lift too... I don't need to jack up the car to get under it and never have this problem.
Crawl under there and see if it's still blocked when not jacked up.
Granted I have a 2016 so maybe somethings changed.
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
10-06-2021, 06:56 PM
I've never had issues either, but your comment reminded me- I don't jack the vehicle up I just crawl under it so the sway bar is likely out of the way. Good to know and OP should give that a shot maybe. Or don't jack it up as high and leave the wheels touching the ground a bit to keep the swaybar out of the way a few mm.
10-06-2021, 09:35 PM
this is true, i didnt have it on jacks either.
10-06-2021, 09:51 PM
never had a problem with kdss/sway bars getting in the way during a oil change, but then again, i'm too peasant or lazy, or too efficient to jack up my vehicle if i don't have to.
OP try to do your oil change on the ground next time, if you can.
10-07-2021, 03:06 AM
I have 4x4 “ramps” at each corner as a quick, safe and level way to get it a bit higher for things like oil changes. Works great.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
10-08-2021, 04:33 PM
Found that problem at first oil change nine years ago. I guess Toyota still hasn't addressed that articular issue. You need to have the weight on the front tires to move the sway bar out of the way. Use ramps if you don't room to work underneath.
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
11-29-2021, 03:07 PM
hmm, my first oil change when the car was new (and stock height) i left the car on the ground and noticed that i couldn't hinge down the skid plate enough to get it off before it touched the ground. maybe that's different when the car is lifted?
ill give it a shot next time
11-29-2021, 03:47 PM
It's the tabs on the front of the skid plate. The tab has an extra "kink" in it that makes you have to wiggle it to get it out, if the truck isn't up on jacks. On my second oil change, I got out my angle grinder (Dremel would work too) and trimmed the kink off the tabs. Way easier to take the skid off and on now.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
11-29-2021, 06:22 PM
x2 cut those tabs
11-30-2021, 11:26 AM
Either grind the skid plate tabs off or just build a set of wheel blocks out of some 2x6 or 2x8 or 4.5 or 6.0 inches high
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
11-30-2021, 11:41 AM
you know in your case if the sway bar is in the way, you can always loosen the bolt for the sway bar that's attaching it to the frame. it should give you more room by removing that i guess.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
