Old 11-28-2021, 10:05 PM #1
Xeu38kdsey Xeu38kdsey is offline
Xeu38kdsey is on a distinguished road
Rust Problems? Illinois -> Washington State Gen 5
Hello, I got a new-to-me Gen 5 - 2010 4Runner SR5 from my father (~170k miles). It comes from Illinois where salt is used on the roads a lot. Is the rust on the bottom problematic and/or is there something I should do to to fix it (if problematic)? I'm unsure if the amount of rust is common.
FWIW: My father has taken what I consider meticulous care of the car and has maintenance logs going back to the purchase date.
Pictures here: Dropbox - 4_runner - Simplify your life
Xeu38kdsey is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 09:22 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Doesn't look too bad for an 11 year old Illinois Runner, but yes, start addressing what rust is there to keep it under control. I guess in Washington state you don't get a lot of salt/chemicals used on the road, so that's good.
I have an '03 that has spent it's life in rust belt and it shows! Much worse than yours.
Old 11-29-2021, 11:09 AM #3
Humble Leader's Avatar
I would say that amount of rust is normal for that age of car. Keep in mind a good number of those pictures posted are of the skid plates, which can be replaced for not too much $$$ if you want to go OEM. that fuel tank skid plate has seen better days, replace with a full gas tank skid if you plan on doing some trails (I used an OEM trail trim skid on my limited, spent a couple hrs cleaning out the unused bolt holes though because I too live where road salt and brine is used all the time)
poke around with a screw driver on some of the more rusty spots, does it go through? I'd also check the spare tire and make sure the chains haven't rusted together rendering its use inoperable. I just replaced my spare tire pulley assembly for that exact reason - they don't use the chain anymore, at least the new assembly I have doesn't use a chain
Old 11-29-2021, 11:56 AM #4
ravens_wood ravens_wood is offline
ravens_wood will become famous soon enough ravens_wood will become famous soon enough
For a 10 year old car from IL that undercarriage is in great condition. While IL (and I'm assuming you're referring to Chicagoland) salts their roads we don't get the snow quantities like the Region, Cleveland or Buffalo.
ravens_wood is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 12:31 PM #5
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS will become famous soon enough
JPOVS's Avatar
Towards the bottom front of the radiator there is about a 2’-3’ long strip of foam that runs horizontally left to right. Check around or behind that.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
JPOVS is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 02:31 PM #6
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
It looks great for age and locale. The skids and maybe the spare are the only things that look somewhat haggard and they are easily replaceable.
5thToy is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 03:52 PM #7
FiReBReTHa FiReBReTHa is offline
FiReBReTHa will become famous soon enough
I'd see about getting it fluid filmed to try to inhibit any further rust.
living in IL we try to do it yearly for such cheap insurance.
Check out my Build here
2014 Trail Premium - 285Dura - 5100/5160 2.5"F/2"R
FiReBReTHa is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 09:47 AM #8
dtbingle dtbingle is offline
dtbingle is on a distinguished road
Doesn't look like anything would be problematic due to that amount of rust. Worst case would likely be having a bolt here or there being seized up somewhere along the undercarriage.
If you poke around and all of the metal is still solid, I've read good things about por-15 to neutralize and make it visually appealing, but it's rather labor intensive and time consuming to do it right. Basically you wire brush all of the loose rust off, clean/degrease and rinse, use their metal prep spray, then with a brush, you paint on the por-15.
If you're looking for a quicker solution to slow the rust down, look at Fluid Film or Krown sprays. Used Fluid Film on my last vehicle (wrangler JKU) and it seemed to work very well in halting any further major surface rust development. I just got my 4runner a couple months ago and had it Krown'd, so we'll see how this works in comparison. Cost was ~$160 IIRC and took an hour for them to do. They spray entire underbody, inside frame rails, drill a few holes and spray inside door panels and tailgate, rockers, etc. There's a lot of these types of products and they never dry. Work great, but they do wear off and require annual re-applications.
dtbingle is offline   Reply With QuoteReply With Quote
father , gen , illinois , problematic , rust
Hello from Washington State eichhorn33 New Members 4 06-01-2017 06:25 PM
Hello from Washington State! Road Bull New Members 0 01-27-2015 12:55 AM
FNG from Washington State Rokynutz New Members 7 07-19-2014 03:53 AM
After the Storm; Washington, Illinois EHNWI Off Topic 3 12-09-2013 03:17 AM
Where to have fun in washington state? myT4RisGREEN General Discussions 3 07-11-2011 05:03 PM
