Old 10-06-2021, 12:34 PM #1
usdmej usdmej is offline
usdmej will become famous soon enough
lifted KDSS front swaybar interfering with oil change
had my 2020 KDSS lifted ~2.5" in front on jack stands this past weekend to do an oil change and i noticed that the sway bar was pivoted to the rear of the car so that it prevented my oil filter housing from being removed
it was blocking it by only a few mm, but i still had to grab a small prybar to pivot the swaybar out of the way to get my oil filter housing removed
anyone else run into this problem? could it be alignment related? i'm on SPC upper control arms using the recommended caster adjustment.
i should have taken a picture but i was in a hurry to complete the job
usdmej is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 04:49 PM #2
honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold
I dont remember it being an issue. but maybe the beers clouded my memory? i'm on 2.5" or so of lift as well.
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe, RCI skids, Marlin Crawler gussets, DRKDSS sway bar controller
Old 10-06-2021, 06:08 PM #3
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
"had my 2020 KDSS lifted ~2.5" in front on jack stands this past weekend to do an oil change"
I have a 2.5" lift too... I don't need to jack up the car to get under it and never have this problem.
Crawl under there and see if it's still blocked when not jacked up.
Granted I have a 2016 so maybe somethings changed.
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 06:56 PM #4
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
I've never had issues either, but your comment reminded me- I don't jack the vehicle up I just crawl under it so the sway bar is likely out of the way. Good to know and OP should give that a shot maybe. Or don't jack it up as high and leave the wheels touching the ground a bit to keep the swaybar out of the way a few mm.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 09:35 PM #5
this is true, i didnt have it on jacks either.
Old 10-06-2021, 09:51 PM #6
mrblah mrblah is offline
mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future
never had a problem with kdss/sway bars getting in the way during a oil change, but then again, i'm too peasant or lazy, or too efficient to jack up my vehicle if i don't have to.
OP try to do your oil change on the ground next time, if you can.
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of sponsored brolanding stickers. faking it with the IG crowd since 2016. Lets go brandon..FJB!!!!
Old 10-07-2021, 03:06 AM #7
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
I have 4x4 “ramps” at each corner as a quick, safe and level way to get it a bit higher for things like oil changes. Works great.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 10-08-2021, 04:33 PM #8
STLDAVE's Avatar
STLDAVE STLDAVE is offline
STLDAVE is on a distinguished road
STLDAVE's Avatar
Found that problem at first oil change nine years ago. I guess Toyota still hasn't addressed that articular issue. You need to have the weight on the front tires to move the sway bar out of the way. Use ramps if you don't room to work underneath.
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
STLDAVE is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 03:07 PM #9
hmm, my first oil change when the car was new (and stock height) i left the car on the ground and noticed that i couldn't hinge down the skid plate enough to get it off before it touched the ground. maybe that's different when the car is lifted?
ill give it a shot next time
Old 11-29-2021, 03:47 PM #10
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a jewel in the rough baldrik78 is a jewel in the rough baldrik78 is a jewel in the rough baldrik78 is a jewel in the rough
baldrik78's Avatar
It's the tabs on the front of the skid plate. The tab has an extra "kink" in it that makes you have to wiggle it to get it out, if the truck isn't up on jacks. On my second oil change, I got out my angle grinder (Dremel would work too) and trimmed the kink off the tabs. Way easier to take the skid off and on now.
2017 TRD ORP KDSS (w/ disconnect & Treaty Oak Spacers)
Bilstein 5100s - Dobinsons Coils - JBA UCAs - Durobumps - Cooper Discoverer AT3 XLT
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
baldrik78 is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 06:22 PM #11
x2 cut those tabs
Old 11-30-2021, 11:26 AM #12
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Either grind the skid plate tabs off or just build a set of wheel blocks out of some 2x6 or 2x8 or 4.5 or 6.0 inches high
lifted KDSS front swaybar interfering with oil change-wheelblocks-png
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 11:41 AM #13
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
you know in your case if the sway bar is in the way, you can always loosen the bolt for the sway bar that's attaching it to the frame. it should give you more room by removing that i guess.
4r-4ever is offline   Reply With QuoteReply With Quote
filter , housing , kdss , lifted , oil
Show us your 5th Gen KDSS lifted! Angonemoto 5th gen T4Rs 99 11-26-2021 07:44 PM
swaybar thicker on Limited than SR5/Trail(non-KDSS)? 4RBob 5th gen T4Rs 3 10-06-2021 05:50 PM
255/80 under CBI bumper touches KDSS swaybar Javelin 5th gen T4Rs 10 04-16-2015 09:11 PM
Stupid question, but will front swaybar links work in on the rear swaybar? BlackCat914 3rd gen T4Rs 10 11-15-2012 08:22 PM
