Old 10-12-2021, 08:38 AM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
Bilstein 5100 Adjustable 0-2.5″ for limited
Hi everyone,
I just ordered the BILSTEIN 5100 ADJUSTABLE 0-2.5″ LIFT to replace my leaky Xreas. They are leaking.
I have couple questions
1- Do I really have to remove xreas tubes and pumps to install the Bilsteins?
2- Wil 5100 work with my current front and rear strut or I need to replace those as well?
Thank you
amir_gh is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 10:16 AM #2
josephp732 josephp732 is offline
Real Name: Joe
josephp732 is on a distinguished road
Real Name: Joe
This shouldn't be that huge of a issue - you can just cut lines and leave some components like brackets, if you like. If it was me I would just remove the complete system. Most of the job is just like replacing shocks. The biggest possible issue will be how much the bolts might be rusted on. Doing this on a 5th Gen should be the same or easier then this video on a 4th Gen. Bilstein 5100 Shock Installation on a 4th Gen 4Runner - XREAS Delete/Removal - FULL Installation!! - YouTube
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
josephp732 is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 12:26 PM #3
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Originally Posted by amir_gh View Post
Hi everyone,
Thank you
Dang, my old thread really needs to be made a sticky, because this gets asked so often.
Don't cut the lines. Removal is seriously simple. There are 6 check valves that you simply loosen and they separate with maybe a drip, then pull the components off. It is super easy and doesn't make a mess.
This video is the best out there so far and shows how to do it without a mess: X-REAS Suspension Delete From 4th Gen Toyota 4Runner - YouTube
dezertbomber is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 12:32 PM #4
Here are the 6 check valves' locations:
Bilstein 5100 Adjustable  0-2.5″ for limited-xreas-check-valves-jpg
Old 10-12-2021, 12:44 PM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
With regard to your 5100 compatibility question, your front "strut" is shock/spring/tophat, you can just replace the shock with the 5100 and I would suggest using the "no spring compressor" method. In the rear you are replacing shock for shock. When I did mine on a 4th gen I replaced the springs too, with new FJ springs, but that's up to you.
0-2.5″ , adjustable , bilstein , replace , xreas
WTB Bilstein 5100 Adjustable KingGeorge For Sale: Suspension/Wheels/Tires 8 12-03-2014 07:19 PM
Bilstein 5100 (adjustable) Coils to go with Jmartins 3rd gen T4Rs 10 09-14-2014 08:52 PM
FS: AL] Bilstein 5100 adjustable cj80cruiser For Sale: Suspension/Wheels/Tires 1 09-30-2011 01:46 PM
