10-08-2021, 07:33 AM
Real Name: Patrick
Real Name: Patrick
Blown running lights
Hi all,
Was towing to Virginia the other night, and lost the truck and trailer running lights. I stopped at Malloy Toyota, and they gave me a price of $250 for the fuse...is there a chance it's something simpler?
Thanks
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
10-08-2021, 07:45 AM
Originally Posted by Titanpat57
Hi all,
Thanks
What fuse and where is the fuse located?
Best Regards,
Saker
10-08-2021, 10:13 AM
Hi all,
Thanks
Check under hood fuse box, green 30amp fuse labeled towing tail fuse.
10-08-2021, 12:03 PM
This is very likely the cause, but you need to look into WHY the fuse blew. I had a bare wire in the circuit of by trailer that took me a couple of hours to find.
10-08-2021, 01:18 PM
Real Name: Patrick
Real Name: Patrick
I'm going to guess this is 100% the issue..I was going to start at the truck place and work my way back...is this like 30 amp Fuse you can pick up at Autozone??
10-10-2021, 08:54 PM
Yes, it's nothing special!
10-10-2021, 09:10 PM
Originally Posted by titanpat57
i'm going to guess this is 100% the issue..i was going to start at the truck place and work my way back...is this like 30 amp fuse you can pick up at autozone??
you have to inspect the trailer wiring .. Rodents now get food in the trailer wiring area...
Put a 12volt lamp in the blown out fuse socket.. Use a volt meter on the trailer wiring ..
10-11-2021, 01:52 PM
Real Name: Patrick
Real Name: Patrick
Thanks all...
Checked the 30 amp fuse...no sign of it being blown.
Bigger problem now is still no running lights, and it this point the trailer isn't even in the picture, I just have get my running lights back
10-11-2021, 06:24 PM
Thanks all...
Did you check it with a multimeter/ ohm meter?
Best Regards,
Saker
10-11-2021, 07:47 PM
Thanks all...
Check the 10amp stop'fuse'in the engine bay fuse box.
10-11-2021, 09:18 PM
Real Name: Patrick
Real Name: Patrick
I checked all the fuses in engine bay...everything is working...after talking to my service writer...he's insistent it's under the dash...we'll find out in the morning...thanks pal
I have stap and turn...just not running lights(and fogs, but it's under the dash too)..thanks
10-12-2021, 09:22 AM
Real Name: Patrick
Real Name: Patrick
Update...
They put new fuses in the spots that were blown...the fuse blew again...they're going to have to dive deeper...fml
10-12-2021, 12:26 PM
Real Name: Patrick
Real Name: Patrick
Ok, time to put
@ Antman
brain to work!
I called him...he's f'in useless...lol
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
