Completed this with dynamic LEDS ( 9005 HP48 LED Bulbs ) and harness with slight change to harness. First - verify your wiring. Measure dc volts from passenger side green wire to drivers side white w/ black wire. Engine will be running, I measured 13.9 volts.
Next , verify the pink wire does indeed run from the passenger side to drivers side. 2 ohms
Get a set of harness extenders. I used the same as mentioned above… the red and black were reversed on mine and my OCD made me fix it, red = +dc.
Here is the harness disassemble and jumped over to the drivers side.
Then reassembled for install.
The only change I made is instead of running a black common wire back to the drivers side light, I just caught chassis ground on the fender. This means you only modify the extension on the passenger side. You actually don’t need an extender on the drivers side if you use this method.
Black wire with red barrel below.
