Old 10-29-2021, 02:16 AM #31
mrkothegigolo's Avatar
mrkothegigolo mrkothegigolo is offline
mrkothegigolo is on a distinguished road
Originally Posted by q451990 View Post
It's tempting, but without understanding all of the variations available from Toyota, I'd be concerned about some kind of "unintended consequence" issue cropping up.
I'd be willing to risk it and test them. Worst case, it doesn't work and I toss them in a storage bin or donate them to a 22 Limited owner. I'm no stranger to buying parts that don't work and sit around afterwards. You should see my guns and gear hobby
98 Limited - SOLD
22 MGM ORP
If you're gonna be dumb, you gotta be tough
mrkothegigolo is offline   Reply With QuoteReply With Quote
Old 11-04-2021, 10:33 AM #32
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
I was a little vague on how to pick up the wiring, because Toyota seems to customize things between trim levels, and I would hate to be responsible for toasting someone's lighting system. But with the disclaimer that you should confirm everything with a multi-meter, and don't hunt me down if you fry something - here's what I did.
I bought an extension harness like this. Amazon.com: iJDMTOY (2) H11 H8 H9 Extension Wiring Harness Sockets Wires Compatible With Headlights or Fog Lights Use : Automotive
and modified them like this:
So the only wire I added is the black wire that takes ground back from the left side to the right side. I'll try to take some pictures of the harness at some point, but it may not look like much since the connections are covered in heat shrink and flexible tubing.
I will also mention that the aftermarket harness that I bought had the red and black wires reversed from the way Toyota does things, so I had to de-pin them and swap them. You could just use red for ground and black for hot if you didn't want to take the time to do that - or the one you buy may be set up correctly.
@q451990 ... cool mod.
You say you only added the black wire, but in your diagram you drew a red loop on the right plug that plugs into the existing harness. It looks like you added a red wire there that loops from black to red on the plug, or am I mis-interpreting things?
rageandlove is offline   Reply With QuoteReply With Quote
Old 11-04-2021, 03:12 PM #33
Saker's Avatar
Saker Saker is offline
Saker's Avatar
So this may be an opportunity for someone….
I understand all trims on the 22 T4R’s will have these led low/high beam setup.
Best Regards,
Saker
Old 11-04-2021, 08:22 PM #34
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
He literally *added* that one black wire. He repurposed the other wire to jumper it as shown in the diagram.
Old 12-19-2021, 09:55 PM #35
WildSockets WildSockets is offline
WildSockets will become famous soon enough
Must only apply to the US. I'm up in Canada and have a '22 TRD ORP and I used my high beams for the first time today and was surprised that they came out of the halogen housing.
The Canadian government introduced new lighting laws to curb people who drive "phantom" at night, so maybe this has something to do with it (but I don't really see why it would because don't US limiteds have auto Bi-LEDs?).
The law is that vehicles (as of Sept 2021) must have at least one of the following: automatic headlights; or daylight running taillights; or a dash that isn't illuminated during the day. Toyota elected to put auto headlights in all Canadian 4Runner trims. Not sure if this is the same in the USA.
WildSockets is offline   Reply With QuoteReply With Quote
Old 12-19-2021, 09:57 PM #36
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Or a dash that isn’t illuminated during the day? How does that fit into a list with the other two? Lol
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 12-19-2021, 10:03 PM #37
I dunno. Lawmakers, man...
Old 12-20-2021, 12:12 PM #38
lunar_t4r lunar_t4r is offline
lunar_t4r is on a distinguished road
for '21 pro/limited or '22+ models with bi-led projectors, i found this to be a cheap and effective pnp option. have been using it for about two weeks. no flickering, not piercing bright to annoy other drivers.
Amazon.com: Auxbeam 9005 9006 LED Fog Light Bulbs White, Plug and Play Design 4000 Lumens HB3 HB4 LED Fog Light Bulbs, H10 9145 LED Replacement Bulbs for Fog Light, Turn Signal Lights, 2 Pcs : Automotive
lunar_t4r is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 09:22 PM #39
farely30's Avatar
farely30 farely30 is offline
farely30 is on a distinguished road
farely30's Avatar
Just installed these this afternoon on my wife’s 22 trd sport. They look factory.
farely30 is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 11:06 AM #40
VmaxEngage's Avatar
VmaxEngage VmaxEngage is offline
VmaxEngage is on a distinguished road
VmaxEngage's Avatar
Factory in color?
22 Lime Rush Pro
VmaxEngage is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 11:07 PM #41
farely30's Avatar
farely30's Avatar
Originally Posted by VmaxEngage View Post
Factory in color?
They look like how it should come from the factory.
Old 12-23-2021, 04:39 PM #42
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
Idk why Toyota didn’t just use LED DRL for all the new 4 runner headlights. It would made our lives alot easier. Lol
Axix23 is offline   Reply With QuoteReply With Quote
Old 12-24-2021, 01:51 AM #43
atk411 atk411 is offline
atk411 is on a distinguished road
Nice, ordered a set in amber, thanks!
atk411 is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 01:17 PM #44
trovergraywilson's Avatar
trovergraywilson trovergraywilson is offline
trovergraywilson is on a distinguished road
Follow-up
Follow-up question: how are y'all finding these after a couple of mos? I'm taking delivery of a 2022 in the next couple of weeks (couldn't stay away from 4Rs) and am interested in the plug-n-play option in particular. If these LEDs can handle being wired in series long-term with no flickering or adverse effects, I'm down. TIA.
2022 Toyota 4Runner Limited 4x4, Blizzard Pearl, "Farrah"
1984 AMC Jeep Grand Wagoneer 4x4, Chestnut Brown, "Geena"
2017 Toyota Land Cruiser 4x4, Attitude Black, "Lou" [Sold]
2020 Toyota Tacoma Limited 4x4, Quicksand, "Tess" [Sold]
2002 Toyota 4Runner Limited 4x4, Dorado Gold, "Faith" [Sold]
trovergraywilson is offline   Reply With QuoteReply With Quote
Old 03-02-2022, 12:16 PM #45
m00nrockt4r m00nrockt4r is offline
m00nrockt4r is on a distinguished road
2022 trd pro here, ive been using the auxbeams they work fine although they are pretty dim, i would say even dimmer than stock halogens, tried to get the diode dynamics hp48 but they wouldn't even light up
m00nrockt4r is offline   Reply With QuoteReply With Quote
bulb , drls , high , led , left
FS: 3rd Gen Headlights & Factory Radio - AZ UncleOOPS For Sale: T4R Items 3 01-13-2018 08:24 PM
LED headlights and factory fog switch atalarico 3rd gen T4Rs 14 04-22-2015 04:08 PM
F/S 03-05 Factory OEM Headlights TRD4runner04 For Sale: T4R Items 7 03-16-2012 03:48 PM
factory oem headlights 03-05 TRD4runner04 For Sale: T4R Items 1 03-08-2012 01:00 PM
HID on factory 03 headlights? t65k3 4th Gen T4Rs 1 01-19-2007 02:39 PM
