10-13-2021, 04:45 PM
Real Name: Bryan
Real Name: Bryan
A Cautionary Tale w/ Weathertech
Hey everyone, figured I should pass this down. My wife and I bought a new 2021 T4R, our first ever new vehicle. We have about 3,300 miles on her and it was time for an interior detail. Took out the very nice weathertech floor mats to clean them up, installed them back properly (or so it seemed) using the proper two floor clips. All looked well. Went to turn on the vehicle and unbeknownst to me, the mat had caught the accelerator and pinned it all the way down. Hit the push start and the motor went straight to max throttle. I was able to shut her off after about 4-5 seconds of maximum throttle, to say it scared the living daylights out of me is an understatement. I’m praying it didn’t cause any damage to the motor, considering it was a cold motor. I pulled it into the garage about an hour earlier to clean it, but other then that it was cold. Garage temp 50-60 degrees. Motor sounds fine, nothing abnormal. But it’s hard not to be paranoid after an event like that.
This was my own fault and by NO means a Weathertech issue. I didn’t fully check up there in the corner to make sure all was well. I figured it would be pertinent information to pass along for all you to learn from my stupid mistake. We have owned Weathertechs in all of our vehicles for about 10 years. They are phenomenal. This post is a cautionary tale to always check your floor mats after reinstallation.
10-13-2021, 04:53 PM
The engine is more than likely fine.
When I built engines for a living (industrial diesel & natural gas), we ran them long enough to identify any leaks, immediately went to WOT for 2-3 minutes, ran for about 30mins while fine tuning it, then moved it to the dyno for power verification and final tweaking.
Why? Because if it was going to come apart, it was going to do it at our shop and not the customer's site.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
10-13-2021, 07:06 PM
Lol....I have done these same thing. Years ago I had just purchased a new MV Agusta F4 Agostini....(a limited production model). Anyways I had it strapped down the trailer and stared it up, with the throttle wide open. (misroute of strap)...anyways it went straight to 12k plus redline. I was freaked out for while about your same concerns. Never had an issue and ran the crap out of it on race tracks. Lasted till I high sided it at Barber and totaled it. Point is, forget about it, otherwise it will drive you crazy.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
10-13-2021, 07:13 PM
Your engine will be just fine.
With my Tacoma, I left my weathertech on the pedal as well but it was only slightly depressed after I had already started moving. So starting and backing up was fine but I basically did a reverse to drive drop. It peeled out a little but but that's it. It kept on going to 145K miles without issues until a careless driver ran a red and totaled it.
10-13-2021, 11:04 PM
You turned it off while bouncing on the rev limiter? Or managed to get the mat out and allow it to come back to idle first?
Cause there would have been some fuel washing past the piston rings likely while the motor was spinning back down without ignition. Change the oil if that was the case for peace of mind maybe…
2017 TRD OR / KDSS / Canuckistan Edition
10-13-2021, 11:13 PM
Real Name: Bryan
Real Name: Bryan
I first tried to tap the accelerator to see what was going on, felt what was going on and then turned it off. After I caught my breathe I turned it back on, let it idle calmly and then proceeded to pull out. I’ll change the oil for piece of mind. Thanks for the words of encouragement guys!
10-14-2021, 12:44 AM
Just drive it. No need to change the oil an sooner than normal.
10-14-2021, 09:27 AM
you're going to have to try harder than that to break a 4runner
10-14-2021, 09:34 AM
That’s weird. I thought Toyota’s “unintended acceleration” fix prevented this from happening. My gf did the same thing in her rav4 but the engine never went above idle. I thought this was in every Toyota but I admit I’ve never tested it in the 4R.
Oh also, full brake pressure is supposed to cut out the throttle as well.
10-14-2021, 09:44 AM
Real Name: Chris
Real Name: Chris
Had this happen once with my Huskys, it's just the design of the floorboards and the way the mats follow it. Scared the crap out of me when it happened and I'm definitely OCD about making sure it doesn't happen again. Thankfully it's a lesson and you'll be more careful in the future I hope
10-14-2021, 09:46 AM
Wow, Ill have to double check next time I reinstall mine. Never had this happen after 8 years, love the mats! But it could happen to anyone!
2012 Trail Edition (No KDSS, Fox 2.5's front, OME rear, 34" KO2's and 33" STT PRO's, Camburg UCA's, Total Chaos LCA's, Custom bumpers and sliders, Baja Utility Rack)
Build Thread
Instagram
Overland Bound Member #2992
10-14-2021, 10:27 AM
Everything you mention may be in place, I think the difference here is it was in park not actually going down the road at the time.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
10-14-2021, 04:54 PM
happen to me to when i owned my old vehicle. After that, I am extremely careful when i put the matts back in, even running my hand under the gas pedal to make sure I can feel it.
10-14-2021, 09:45 PM
I have the OEM TRD all-weather mats. 2 years in with a lot of abuse they are still doing great. Is there a reason people opt for Weathertech or Husky over these? Price?
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
10-14-2021, 11:34 PM
More coverage.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
