10-20-2021, 06:18 AM
Rust on tailgate door jam
Curious if you think this would be covered by the rust warranty? Seems like there is a spot rusting from the inside out and the lock is rusting.
10-20-2021, 07:38 AM
Pictures?
10-20-2021, 08:53 AM
Sorry I thought I posted it from my phone but had to transfer to computer and resize it.
10-20-2021, 10:44 AM
You need new lock for sure. It is easy to replace. Mine had some rust and I replaced it before it got bad while was installing OEM+ speakers back there.
10-20-2021, 12:21 PM
I would think that should be covered. But with today’s times and challenges I could see them saying no to save a dollar.
Good luck!
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
10-20-2021, 12:35 PM
What year is it? How many kms on it? I tried to do a rust claim on a previous Lexus RX350, and it got denied because they said the rust has to be through the metal, basically a hole for them to fix it. Surface rust like that wouldn't be covered under the corrosion warranty, so hopefully you have better luck getting it fixed through warranty.
10-20-2021, 04:20 PM
Unless it rusts completely through, Toyota won't cover it.
The only way to fix this effectively and cheaply is to replace the back hatch door with a high quality used one.
Given that you're in IL and they use a lot of salt during the winter months, I strongly suggest washing the truck, including the door jams, at least once a month. Salty slush sitting in the rear hatch door jam for a long period of time was the likely culprit here....or the rear hatch had been repainted and the repair facility did a poor job and the salty winters took care of the rest.
10-20-2021, 04:53 PM
That is due mostly to the roll down window. Which is highly over rated. Salted roads are a crime against humanity.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
10-20-2021, 05:32 PM
Thanks. I will see what Toyota says. It’s washed weekly
10-20-2021, 09:02 PM
If you can get them to check it out without a ticket might be best, if you want to go to another dealer/shop for a 2nd opinion?
01-21-2022, 09:28 AM
Does anyone know what brand the tailgate door lock is? I know the other ones are aisin. Is the rear one aisin too?
