Old 10-21-2021, 06:19 PM #1
creib creib is offline
creib is on a distinguished road
help ID this switch connector
looking to relocated the "view" button (360 birds eye camera) on my 2022 ORP
would be nice to have a 2-3' extension cable to avoid hacking into the oem wiring harness
does anyone know the what this connector is? ideally both male and females sides
proficient in cable making with the correct crimps but also would be able to buy one premade if it exists
thanks!
creib is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 08:37 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
You can find the part numbers for most Toyota/Lexus connectors in the Toyota wire harness repair manual: https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
That will also show the part numbers for repair wires with the wire pins attached. Most of the connector housings, repair wires with connectors, and other miscellaneous wiring parts are readily available from your Toyota dealer. The parts department at your Toyota dealer can also look up wire harness repair parts and instruction in the TIS, but many don't want to spend the time doing that.
Each of the connectors on your vehicle has a connector designation number which is shown on the wiring diagram for the vehicle, but most dealers don't like to share that info with customers. Knowing the connector designation number, you can cross reference to the part numbers.
fkheath is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 08:57 PM #3
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Look over the connector itself, I find that that most Toyota connectors have the part # molded in the connector.
Look under those wires........is that just the wire orientation?
Best Regards,
Saker
cable , connector , correct , crimps , making
AOB Switch Illumination Issue QUESTION/Trouble With Switch Fully Engaging FIX mbumpus11 5th gen T4Rs 11 10-23-2021 03:51 PM
LED Light bar install - unused connector to tap switch into cheeser 5th gen T4Rs 8 04-22-2016 10:27 PM
2014 4runner 4x4 switch and rear window switch doesn't light up? slee05 5th gen T4Rs 5 06-28-2014 05:10 PM
Back-up switch connector housing part number brocktice Classic T4Rs 1 11-11-2013 08:04 PM
