Originally Posted by DriftingOverland
Saker-
I’m working with an AOB switch for my ARB on my 2020… all wired close to what your diagram helped out with for the OP. However, when I go to dim my dash lights, the AOB light works in reverse… it brightens!
And yea, positaps are the bomb.
Thoughts?
Hmmmmm,
Does the switch perform properly to control the ARB?
Double check your connections from your power & to make sure the AOB switch wiring pin location is correct.
I would disconnect the ARB and just try the switch with no load.
It should be something simple… is your ground good?
