Old 10-24-2021, 07:08 PM #1
Rastamind's Avatar
Rastamind Rastamind is offline
Rastamind is on a distinguished road
Rastamind's Avatar
21 ORP window de-icer switch revised wiring diagram?
Howzit All!
Was wondering if anyone knew about revised wiring info for the Windshield de-icer switch on the dash. I believe it might have been changed somewhere in the 20/21 Gen 5's but not finding to much info regarding the pinouts. Got a green that reads like a ground on my MM and no grey.
I'm wanting to isolate the 12v + ground to tap in to the dimmer circuit for some new OEM type dash switches I am installing.
Appreciate any insight!
21 TRD ORP -Mag Grey|
3in Toytec BOSS ALUMA 2.0 + JGA uca + BFG KO2 275/70R17 |
Pioneer NEX4500/maestro rr2+ infinity kappas + kicker hideaway sub+ NVX Silicon baffles+80/50 mil Kill Mat |
TRD skid plate + Heritage grill+ Rhino Rack X-Tray basket+ ABS Nerf bars+bull bar+ 20” led + DD amber fogs + BD+CL Ditch Lights
Rastamind is offline   Reply With QuoteReply With Quote
Old 10-25-2021, 03:54 AM #2
Saker's Avatar
Saker Saker is online now
Saker's Avatar
Originally Posted by Rastamind View Post
Howzit All!
See if my diagram helps.
21 ORP window de-icer switch revised wiring diagram?-af151f17-c254-476a-8cf1-eb4c7f05f95e-jpg
Best Regards,
Saker
Saker is online now   Reply With QuoteReply With Quote
Old 10-25-2021, 02:16 PM #3
Rastamind's Avatar
Rastamind's Avatar
Awesome! Thank you Saker!! Appreciate it! will make connections today.
Old 10-28-2021, 03:47 PM #4
Rastamind's Avatar
Rastamind's Avatar
Well I tried the connections this AM, but did not get it to work. I have been reticent about removing the driver kick panel to get full access which I surmise is the issue. I am using the removable type taps so Im not totally sure that I tapped the (WHITE) 12v connection wire properly. led switch works still just no illumination. I will test asap + relay results as I have 3 more switches to add.
I been getting reports of my images not showing up, please let me know if that is the case for this post.
Old 10-28-2021, 10:05 PM #5
Rastamind's Avatar
Rastamind's Avatar
Got it. Twas a bad connection on the 12v tap. Thanks again! Now I have both wires ready for all my sweet sweet switches!
Old 10-28-2021, 11:00 PM #6
Saker's Avatar
Saker's Avatar
Glad you found the bad connection.
Positaps are the best route even though they take up more room!
Post your pics when you get all switches in place.
Best Regards,
Saker
Old 10-29-2021, 10:50 AM #7
DriftingOverland DriftingOverland is offline
DriftingOverland will become famous soon enough
Saker-
I’m working with an AOB switch for my ARB on my 2020… all wired close to what your diagram helped out with for the OP. However, when I go to dim my dash lights, the AOB light works in reverse… it brightens!
And yea, positaps are the bomb.
Thoughts?
DriftingOverland is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 11:54 AM #8
Saker's Avatar
Saker's Avatar
Originally Posted by DriftingOverland View Post
Saker-
Thoughts?
Hmmmmm,
Does the switch perform properly to control the ARB?
Double check your connections from your power & to make sure the AOB switch wiring pin location is correct.
I would disconnect the ARB and just try the switch with no load.
It should be something simple… is your ground good?
Best Regards,
Saker
Old 10-29-2021, 04:32 PM #9
Originally Posted by Saker View Post
Hmmmmm,
Yes switch operations are normal except for the reversal of light dimming. And I’ll double check the ground/wiring this weekend.
dash , de-icer , info , revised , switch
Looking for Wiring Diagram for Rear Lift Gate Lock & Window Controls jtice 5th gen T4Rs 2 02-13-2019 10:34 PM
Wiring Diagram for 4 Rigid 6" Light Bars to one switch MNT4R 5th gen T4Rs 0 10-07-2016 12:38 PM
revised diagram Iron Clad Lou Engines / Suspension / Wheels / Tires / Audio / Accessories 28 04-28-2013 07:59 PM
rear window switch wiring foonanas Classic T4Rs 8 09-13-2011 05:12 PM
Stock Rear Fog Light Switch Wiring Diagram cpguy33 Engines / Suspension / Wheels / Tires / Audio / Accessories 18 11-11-2006 07:43 PM
