Old 11-25-2021, 05:17 AM #106
Jrunr Jrunr is offline
Jrunr will become famous soon enough
Originally Posted by Taco04 View Post
I have had a set of S2 Pros up front on my runner I installed them a couple of months after buying it. They have great output with the clear lenses but the yellow cuts it down a bit. I cut the grill a tad bit smaller than the face of the front light that way I can install them from the front and not see where the grill is cut. Not the greatest picture but you can get the idea...
That looks pretty good from the angle
You posted. Can you please send me another pic to get a better idea as to how you had it done? Just a little more detail would be awesome! Thank you! I really like that idea!!
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 09:51 AM #107
Originally Posted by mynameistory View Post
Yes, I would love to have a 4000K bar as well. However, the difference between the LumiLED chips (5700K) and the Cree XP chips (6500K) is pretty noticable.
I would love for Diode Dynamics to revisit their bars and add 4000K/selective yellow options, rather than their current 6000K and dark amber lens options.
Do you know if the Diode Dynamics SS2 Pro has the same 4000K emitter in their amber lights? I feel like I could really simplify things by using an SS2 Pro as an aux high beam, but only if I can get it in that 4000K range.
The next best thing would be the Baja S2 in 5000K…
2021 TRD Pro, MGM
Old 11-25-2021, 10:01 AM #108
you think those are gonna have enough output for aux high beams? I have a feeling itll be underwhelming simply cause its such a small light.
*my experience with S2's are the sports so its a definite downgrade.
Old 11-25-2021, 10:35 AM #109
Taco04's Avatar
Taco04 Taco04 is offline
Taco04 is on a distinguished road
Taco04's Avatar
Here ya Go, these are the older Pro's circa 2014 lol... They are actually mounted upside down with a longer bolts and spacers screwed into the upper core support. I was worried about them being upside down but zero issues. I even have a trio of XL80's on my Baja mounted upside down and have never had any issues. Also placing them slightly forward of the grill allows me to adjust them so I can get the light where I need it. With the clear lenses they throw out a ton of light but I put ambers on them for dust where I work. I also have a set of S2 sports and they do not seem near as bright as the pro's Hope this helps
Current Pack of 4x4 yotas...
2022 TRD LWB 4x4 Taco
2012 DC LT Baja Taco 4x4
2014 4Runner 4x4
Taco04 is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 01:09 PM #110
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Yes, they do. You can order selective yellow lights and swap clear lenses in for 4000K white. The specs for 6000K and 4000K white lights are the same, because they are the same emitter with just different color temperatures.
Here are the datasheets for the SSC2 Pro:
http://images.diodedynamics.com/docs..._Datasheet.pdf
And here are the datasheets for the SS3 pro:
They're actually not as far off as you'd think in terms of output. The limiting factor on the SS3 is the heatsinking capacity, so the SSC2 is actually tuned for more than 50% intensity despite having only half the emitters. The pattern itself (driving) is a bit smaller though, in addition to slightly reduced intensity. I might have used them myself if I hadn't already had the SS3s mounted. They certainly would be easier to fit.
Lux at 10 meters. Remember this is the peak intensity. Pattern size and dispersion will vary a bit between all lights:
SS6 bar in white driving- 550 lux
SSC2 pro in white driving- 590 lux
SS3 pro in white driving- 665 lux
SS3 max in white driving- 980 lux (for fun, too intense for SAE compliance. Also no 4000K option for max)
SS5 pro in white driving- 1700 lux (for fun. It won't fit in the upper grill and it is WAY not street legal)
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 03:23 PM #111
looks good! what i love about BD is you can just rotate the bezel and nobody would ever know
Old 11-28-2021, 08:28 AM #112
Well I was instructed to give "Santa" a Christmas wish list, so I put the Baja Designs 20" bar on it for the upper grill... So lets see if "Santa" brings me that gift or not... lol
Also, I think i can fit the 20" S8 bar AND 2 separate S1's on each side as the actual high beam augmentation that I wouldn't be affraid to use on the road in my daily travels... (the light bar would be strictly for off road only)...
2021 TRD Pro, MGM
Old 11-28-2021, 03:24 PM #113
do s1 lasers.
Old 11-28-2021, 05:08 PM #114
Originally Posted by honda250xtitan View Post
do s1 lasers.
Lasers sound exotic but these will shine further for a fifth of the price. And have a 50,000+ hour lifespan instead of 2000.
-Tory
Old 11-28-2021, 05:54 PM #115
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
OK you guys inspired me to get more light up front.
I just came across a used 30" S8 BD wide/driving light.
I think I'll stick that in the bottom part of my grille, and swap out the 20" BD S8 wide/driving light I have in the top with a 20" BD S8 spot light bar.
That should get me almost infinite light up front.
Question is - how do you aim the two of them? I'll need to do some research.
rageandlove is offline   Reply With QuoteReply With Quote
Old 12-01-2021, 11:27 PM #116
Taco04's Avatar
Taco04's Avatar
Sorry but those probably won't shine 1/10 the distance of a BD laser light but they will put out more useable light. If you have ever seen the BD laser lights you will know LED's are currently no match when it comes to distance.....
2014 4Runner 4x4
Old 12-02-2021, 01:15 AM #117
LEDs in reflectors are currently no match.
You are aware that lasers do not shine out of these lights, correct? The lasers are used to excite a chunk of phosphor, and that is what emits the light (out of a forward facing reflector). I'm not saying they're bad lights by any means, but the reflector optics they use are the same as their LED lights.
Diode doesn't win with raw power, it wins with focus. TIR optics control the light to such an extreme degree that there is hardly any glare produced outside of the main pattern. Take a look here, you'll see what I mean- notice that the sport lights have a higher candela rating despite being half the wattage of the pro lights. This is due to the extreme focus of the tiny emitter matched with the optic designed around it (the pro has a larger, more powerful emitter that creates a larger pattern but is not as focused). If anything, it's Baja with the more "usable" light due to spill.
How much difference does focus make? Consider that the SS3 sport spot light ($90)
throws light further than the BD XL80 laser ($1K).
The SS3 Max ($250) has 50% more intensity than the sport and can shine light (¼ lux) a kilometer away. Out of a 3 inch pod!
And if you need more than that, the SS5 sport (a 5 inch pod, $220) shines light a mile away with over 400,000 candela in the spot pattern.
All of these measurements are taken on a goniometer, and you can download the spec sheets on Diode's website. Baja Designs doesn't provide any specifications other than raw lumens.
I'm not saying some lights are better than others- all of them are purpose built for a given task. Baja Designs validates their lights by winning a lot of off-road races, and they've decided that spill/peripheral lighting from open reflectors is an important part of that formula. But if you're asking for ultimate distance in spot lighting, it's not even a contest. The TIR optics have them handily beat - for a lot cheaper, too.
-Tory
Old 12-02-2021, 01:37 AM #118
mrblah's Avatar
mrblah mrblah is online now
mrblah's Avatar
sorry to hijack..but what are those square doohickies on your hood?
mrblah is online now   Reply With QuoteReply With Quote
Old 12-03-2021, 11:46 PM #119
This sounds awesome! Please post pics when you get the chance!!
2021 TRD Pro, MGM
Old 12-04-2021, 02:18 AM #120
SurfToy's Avatar
SurfToy SurfToy is offline
SurfToy will become famous soon enough
SurfToy's Avatar
Originally Posted by Mudballz View Post
A bit different but effective
Pardon the hijack, but what bumper is that? It looks very functional while retaining most of the stock front fascia.
2014 Trail Premium | White | KDSS | Moonroof | Sliding Cargo Tray | Bilstein/Wheeler 2.5" lift with airbags | Ironman Offroad UCAs | BFG K02 255/75R17 | Sprint Booster
Previous: 2019 TRD OffRoad Premium, 2006 SR5 V6 2WD
SurfToy is offline   Reply With QuoteReply With Quote
kit , light , lights , options , upper
FS in NC: Upper Grille for 5th Gen luke27617 For Sale: T4R Items 1 01-02-2020 03:11 AM
Upper grille with no lower grille The_Green_Wang 5th gen T4Rs 0 03-08-2019 10:20 PM
FS: 5th gen Upper grille - Austin TX ScottR For Sale: T4R Items 6 01-26-2018 10:20 AM
FS - 5th gen, Upper grille section, $100, Redding, CA jasweb8 For Sale: T4R Items 1 11-03-2015 05:55 PM
