Old 07-19-2022, 01:10 PM #1
paczowski123 paczowski123 is offline
paczowski123 is on a distinguished road
Horrible Headlight Cutoff/Brightness
Hello all,
I recently purchased a new (to me) T4R TRD off Road Premium. I am the second owner and it has about 7K miles. I have noticed at night the headlights have a HORRIBLE cutoff and are super dim. There is no defined straight cutoff, in fact, there is a dark V right in the middle of the beam starting about 10 feet in front of the vehicle and extends indefinitely outwards. Surely this cannot be correct? I attached a picture for reference, but it does not do them justice as my Iphone brightened the image considerably. It is so bad, that if it were not for the LED fog lights, the vehicle would be unable to be driven at night safely.
Only thing I noticed is when I popped the headlight dust covers of, it looks like someone has tried to put H9 bulbs in place of the H11 and perhaps they are not positioned correctly, they both sitting at different positions inside the housing? Could this be the issue in you all's opinion? I did not fool with it much as I discovered it late last night after getting home and noticing the dim headlights. But being the bulb is round I was worried something else may be wrong as there are no defined areas to where if the bulb was spun it would emit light differently inside the projector?
I am only asking this as a precaution before I fool with it being it is still under full warranty from my Toyota dealer, so do not want to screw anything up and have them blame me for it rather than letting them remedy the situation.
Horrible Headlight Cutoff/Brightness-headlights-jpg
paczowski123 is offline   Reply With QuoteReply With Quote
Old 07-19-2022, 01:23 PM #2
osugsxr osugsxr is offline
Originally Posted by paczowski123 View Post
Hello all,
check position of lights and its simple to adjust the headlights. There is a star screw near the top of the headlight area. Can use a large phillips head to adjust the height of the cut off line.
Old 07-19-2022, 01:27 PM #3
Thanks! I did see the adjuster down in that hole, I just use a phillips to turn the toothed wheel? I did not notice any phillips head screw down in there.
Old 07-19-2022, 01:34 PM #4
yes a large phillips head does work . Search for proper procedure on how to set cut off height.
Old 07-19-2022, 03:07 PM #5
chrisridebike8 chrisridebike8 is offline
chrisridebike8 will become famous soon enough
what year 4runner? that looks like someone threw some LED bulbs in and has them oriented wrong.
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
chrisridebike8 is offline   Reply With QuoteReply With Quote
Old 07-19-2022, 04:02 PM #6
John in NC John in NC is offline
Real Name: John
John in NC will become famous soon enough John in NC will become famous soon enough
Real Name: John
Only 7,000 miles I'd figure it to be a 2020-2022.
I'd be tempted to go back to stock as a baseline, or do the OEM LED retrofit if you can find some new take-out factory headlights.
There's a thread on here about it.
Here it is: 2021 4Runner OEM LED Headlights/Lights Performance and Retrofit
John in NC is offline   Reply With QuoteReply With Quote
Old 07-19-2022, 06:24 PM #7
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
we bought our 2019 with 8k miles on the clock, last year.
I'd say our 2019's headlights definitely leave something to be desired compared to our Honda Civic and newer F150.
Still not sure which path to take to improve night vision, though we did drive through Nevada and Utah on some very dark nights on our Moab trip, and it was "just ok".
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 07:18 AM #8
NoSoupForYou's Avatar
NoSoupForYou NoSoupForYou is offline
NoSoupForYou is on a distinguished road
I have to ask, but are you sure the headlights are actually 'on' and you aren't driving around with just your fog lights on? Like have you gotten out and verified there is light coming through the projector lens of the upper housing?
NoSoupForYou is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 07:21 AM #9
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Headlights are definitely aimed way too low. Start by readjusting them and go from there.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 12:51 PM #10
So I discovered they tried to put in the Hella H9 bulbs but did not trim the tab down to they were sitting in there all cock eyed, I have remedied the situation yesterday by trimming the oversized tab and locking them correctly into place and am waiting for another night (where I have time) to get it out and test. If they do not change I will go about the adjustment route. I just have no idea why they would have been adjusted all the way down in the first place, but who knows. It does seem the vehicle was briefly owned by someone familiar with the mods as it has some of the Carista features modified on it and LEDs in some of the turn signals.
My guess is perhaps they had some other form of bulbs like HID or similar and before trading in or whatever they did, they just crudely stuck these bulbs in it or had no idea what they were doing. I am hoping it was just the crooked bulbs, though, as adjusting headlights is a PITA.
Old 07-20-2022, 05:24 PM #11
mattj150 mattj150 is offline
mattj150 is on a distinguished road
Adjusting the headlights isn't actually that bad! You just need a larger phillips head screwdriver and you can reach down and adjust the gears. The first time I did it was on a roadtrip because people kept flashing me at night.
mattj150 is offline   Reply With QuoteReply With Quote
Old 07-21-2022, 01:07 PM #12
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
If the cutoff still isn’t to your satisfaction after adjusting, I’ve been seeing people selling practically brand new Bi-LED takeoffs for about $350. Just check your local Facebook Marketplace.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 07-22-2022, 12:25 AM #13
WOLFN8TR's Avatar
WOLFN8TR WOLFN8TR is offline
WOLFN8TR is on a distinguished road
WOLFN8TR's Avatar
I have some Diode Dynamics LED’s in the Lows and Highs. These work really good in the stock headlights. The DTR lights have no flickering. Light output is way better than stock! I originally ran these in my Cheverolet Silverado 2500HD stock headlights and they worked great in them as well.
Here’s some photos of the low beams.
2015 Toyota 4Runner Trail
WOLFN8TR is offline   Reply With QuoteReply With Quote
Old 07-22-2022, 01:08 AM #14
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
I love the old-school nature of my 4R EXCEPT for the headlights. Worthless and dangerous, they are.
I changed the headlights with the best available regular/legal bulbs I could find and that helped a little.
Then I added SS3 LED Fog Light Kit for 2014-2022 Toyota 4Runner
in white which helped a great deal but still left the issue of distance.
Finally, I added the top under the front grill small light bars that match perfectly the fogs. I am closing on 500 offroad runs (on 3 vehicles total), never needed a bar. But I bought these specifically for out-of-town on pavement driving and they made a huge difference. They are supposed to be street legal.
I aim them lower than I could just to make sure they bother nobody and in fact nobody has flashed me, yet.
No longer living on a prayer when driving at night.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 07-22-2022, 01:24 AM #15
The cutoffs now look amazing
cutoff , defined , headlight , night , vehicle
4runner thumbwheel brightness yoyomonkey 5th gen T4Rs 2 12-05-2020 09:35 PM
06+ Headlight Conversion - Headlight Cutoff Gen4SR5 4th Gen T4Rs 5 05-24-2019 01:24 PM
Gen 5 Clock Brightness Pastor passum 5th gen T4Rs 14 11-13-2018 11:36 AM
A/C High/Low PSI cutoff ghs215 4th Gen T4Rs 4 06-02-2015 09:05 PM
XB Halo Brightness Issue TiN Engines / Suspension / Wheels / Tires / Audio / Accessories 3 04-19-2015 05:56 PM
