Old 12-04-2021, 03:04 AM #121
Jrunr Jrunr is offline
Jrunr is on a distinguished road
Originally Posted by SurfToy View Post
Pardon the hijack, but what bumper is that? It looks very functional while retaining most of the stock front fascia.
Couldnít you just pm him about that?
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 12-04-2021, 09:49 AM #122
honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold honda250xtitan is a splendid one to behold
no, couldnt YOU just pm him about that??????
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe
2017 F250 6.7: Carli, Fox, Raceline, BajaDesigns, DIY Retrofit headlights
Old 12-04-2021, 02:04 PM #123
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Looks like Hefty Fab.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 12-07-2021, 04:53 AM #124
I am heading home on leave late next week (much, much needed) and I am looking forward and messing with this a bit! if I can figure it all out and how to tap into the factory high beam stalk to get the factory Halogens to work in the high beam capacity they were designed for, I think that itself will make a HUGE difference!
Adding a lightbar will definitely be icing on the cake - and will be hooked up independently for off road/ long, dark, empty stretches of highway.
2021 TRD Pro, MGM
Old 12-07-2021, 07:12 AM #125
mrblah mrblah is online now
mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future
i would just do a separate switch. If you got the s8's, you also get the running lights also. I tend to try not to hack into my factory wiring harness if i don't have to (sometimes you have to but something i avoid). Its not a bad idea to get a lighting trigger accessory (spot, trigger, etc) since they don't hack into your wiring harness, are fused, less wiring into cab, and can add additional accessories (winches, lights, rock lights, disco lights, etc).
anyways, post pics when done mang....thank you for your service!!!
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of sponsored brolanding stickers. faking it with the IG crowd since 2016. Lets go brandon..FJB!!!!
mrblah is online now   Reply With QuoteReply With Quote
Old 12-07-2021, 08:31 AM #126
If you're lucky, you might be able to use the high-beam fuse in the engine bay as a relay trigger. With an add-a-fuse, it can be implemented with no wiring hacks. Then just add the 9005 (or upgraded 9011) bulbs on a +12V harness connected to the relay (which taps straight from the battery). You will lose the DRL function this way though, as it will no longer be a series connection (6V to each bulb when DRL activated) hooked up to factory wiring.
I did something similar with my driving light setup - if you're interested, a light bar could be Incorporated the same way so that you can have it on anytime, or on with the high beam toggle.
Using this dual-throw switch from anytimebackupcamera.com, I wired the relay trigger so that HIGH activates with the high beam toggle, and LOW turns on anytime the key is in. The high beam fuse tap (along with the trigger wire to relay) have to pass through the firewall. The accessory +12V is on a fuse tap on the interior fuse box (cigarette charger circuit).
This way I can turn on the driving lights anytime, like in an off road scenario, when I switch LOW. When I switch HIGH, the lights only turn on with the high beam toggle. This has the added benefit of being street legal (fogs automatically turn off like factory etc), as well as easy to activate without any new muscle memory. You simply dip the lights like normal when there's oncoming traffic, instead of fumbling around for the right switch and blinding them.
More discussion about various things like the dash illumination circuit etc are here: The SAE J581 Aux High Beam Thread | Page 24 | Tacoma World
-Tory
kit , light , lights , options , upper
FS in NC: Upper Grille for 5th Gen luke27617 For Sale: T4R Items 1 01-02-2020 03:11 AM
Upper grille with no lower grille The_Green_Wang 5th gen T4Rs 0 03-08-2019 10:20 PM
FS: 5th gen Upper grille - Austin TX ScottR For Sale: T4R Items 6 01-26-2018 10:20 AM
FS - 5th gen, Upper grille section, $100, Redding, CA jasweb8 For Sale: T4R Items 1 11-03-2015 05:55 PM
