Old 11-01-2021, 11:12 PM #1
Hydro556 Hydro556 is offline
Hydro556 is on a distinguished road
Lift/tire question to be clear
I have searched, and I read conflicting info.
I have a 22 ORP due in November. I have black trd wheels I can buy and I can put 275 or 285 70-17 tires on them.
If I buy the Bilstein 6112 shocks how high will I likely need to lift to clear each set? And should I just get 1 inch rear springs to keep it level?
I know it's a dead horse but if you read thru this forum and others you see one guy say one thing and others directly contradict.
Hydro556 is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 11:40 PM #2
srsrogerissrs's Avatar
srsrogerissrs srsrogerissrs is offline
srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice
Exactly, you get contradicting information because everyone's results will differ. Are you going to get aftermarket UCAs? Being able to adjust caster can have a drastic change on what "rubs" or not. However, pushing something forward might clear your body mount but not clear your bumper. Lifting won't change your scrub radius so don't think lifting will stop rubbing.
So no... you're not going to get a definitive answer on what will rub or what will not. This is the typical "your results will vary". Don't be afraid to trim your bumper or get a body mount chop. It's really not that bad.
2016 White TEP
srsrogerissrs is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 11:52 PM #3
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
It depends.
Forgetful is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 11:53 PM #4
I have zero issue working the fender liner etc.
Just wanting to keep lift to a minimum while clearing largest tire without major surgery.
Old 11-02-2021, 12:12 AM #5
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Lift does not help with clearing tires… suspension geometry, the arc the wheel travels and turns through, remains unchanged except for alignment… spring and shock doesn’t do that. Control arms etc can change wheel positioning through the range of motion or adjust bump stops etc, but lift doesn’t factor in to what you’re looking for.
Most people that have to do BMCs to fit “33s” go with aftermarket rims or spacers that screw with their scrub radius.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 09:19 AM #6
Humble Leader's Avatar
I think you will rub on stock with 275 70 17. I have read people have rubbing on stock height with 265 70 17 with the same TRD pro rims and running aggressive AT tires (wildpeaks). I have also read many don't have rubbing with the same set up but different tires. it will be difficult for anyone to comment on the lift set up that is needed to eliminate rub unless someone has ran your exact same set up. there are many variables as the previous posters have pointed out
to reduce the need for major surgery and the need for a lift you could just run 265 70 17 and the TRD rims. if you had a rub with that it would be very minor and very fixable with a heat gun. the reduced offset of the TRD rims will make the tires stick out more and increase the scrub radius and liklihood of rubbing - that is without even going up from stock tire size
edit: I know you are looking at getting a lift, but if the lift is solely to mitigate rubbing and not because you actually want to lift the truck for functionality I would stick to stock tire size and save a bunch of $$$
Old 11-03-2021, 09:28 AM #7
Metalsaber Metalsaber is offline
Metalsaber is on a distinguished road
I'm running factory suspension and TRD Pro wheels on my ORP. I got the 265 70 17 Falken Wildpeak AT3Ws and they fit perfectly. As you said, I've seen some people get away with 275 and a rare few 285s. I do want to run 285s at some point but i need a lift/chop...etc before I invest the money into 285s.
Metalsaber is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 11:43 AM #8
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
I ran 285 with no lift. I only had to grind down the welds on the body mount (not a chop, just grind a tiny bit) and push the inner fenders forward. No rub at all even with articulation.
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 12:05 PM #9
I'm going with the 275s and will modify as needed I guess.
I think it'll be early next year before I can get my hands on the lift with the way things are going.
Old 11-03-2021, 12:11 PM #10
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
The ORP comes with TRD OR wheels that are arguably better than Pro wheels. The OR wheels are wider and have better valve stem protection.
As others have written, a lift by itself will not affect what fits up front, because the range of motion is the same, and a larger tire will rub in the same places.
The many contradictory answers you see are due to varying offsets and UCAs, as well as varying context as to what "does it rub?" means. Articulation may not be needed to drive to the grocery store, so a diminished range of motion may be acceptable.
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 09:58 PM #11
Copy. I'll figure out what's needed to make them fit once I get it here.
Buying the TRD black wheels with Falken 275/75-17s Saturday. Once I get the truck I'll sort it out. Likely going back to Moab and Teton next fall so I'll have time to sort.
Old 11-04-2021, 10:15 PM #12
Pistol Pietro Pistol Pietro is offline
Pistol Pietro is on a distinguished road
I wasn't aware that Falken made that size. I've heard good things about the Falken AT3W tires. I was concerned about the increase in unsprung rolling weight, so I wanted to keep the tires on the lighter side. Bfgoodrich KO2s in 285/70 17 c rated are actually lighter (51lbs.) than the smaller 275/70 17 e rated (56lbs.) I was considering going with 285/75 17s (34inch diameter) but that would push the weight past 60lbs per tire and made having to re-gear a possibility. I'm pretty happy with the 285/70 17s. I think it's kind of a sweet spot size for the 4runner. I still have a stock (265) size spare, but I understand that the 285s are about the largest that will fit in the stock spare location.
2020 TRD ORP with KDSS. 285/70 17 BFG KO2s. Bilstein 5100s w/ stock springs on top perch in front, and Bilstein lift springs in rear. SPC UCAs. RCI rock sliders. C4 Fab Low Profile front bumper with Smittybilt H20 12k winch. Factor 55 Flatlink E. RCI roof rack, Baja Designs and cheap Amazon led lights, Switchpro 9100, BeyondWraps hood scoop stamp.
Pistol Pietro is offline   Reply With QuoteReply With Quote
Old 11-06-2021, 11:02 PM #13
They're 275/70 not 75. My mistake.
buy , clear , read , rear , springs
Tire question (just to be clear) Kyle Reese 3rd gen T4Rs 60 12-16-2015 07:16 PM
Another Lift Tire/Rim Question bomluuk 4th Gen T4Rs 2 04-03-2015 07:23 PM
Lift and Tire question 285/75/16 NitehawkVTEC 4th Gen T4Rs 1 11-28-2011 03:22 PM
Lift & Tire question GX4SEVEND 3rd gen T4Rs 11 04-16-2010 08:32 PM
Lift/Tire Question FireEngineer 4th Gen T4Rs 2 11-12-2009 04:20 PM
