Originally Posted by Hydro556
I have searched, and I read conflicting info.
I have a 22 ORP due in November. I have black trd wheels I can buy and I can put 275 or 285 70-17 tires on them.
If I buy the Bilstein 6112 shocks how high will I likely need to lift to clear each set? And should I just get 1 inch rear springs to keep it level?
I know it's a dead horse but if you read thru this forum and others you see one guy say one thing and others directly contradict.
The ORP comes with TRD OR wheels that are arguably better than Pro wheels. The OR wheels are wider and have better valve stem protection.
As others have written, a lift by itself will not affect what fits up front, because the range of motion is the same, and a larger tire will rub in the same places.
The many contradictory answers you see are due to varying offsets and UCAs, as well as varying context as to what "does it rub?" means. Articulation may not be needed to drive to the grocery store, so a diminished range of motion may be acceptable.
