Old 11-02-2021, 09:13 AM #1
jayw jayw is offline
jayw is on a distinguished road
Another raptor lights question
I know opinions are split on these, but I got a quality set cheap on Amazon and decided to try them....
I've seen most all the wiring vids etc. I'm hoping to do it a bit different. FYI, I have a 14 Limited. I am original owner.
I want to use the add-a-fuse to tap into the fog lights. That's a 15A fuse. Is this a good idea? Just wondering if anyone has done this. Thanks.
jayw is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 09:20 AM #2
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
the raptor lights take less then a watt.. for the most part, you should be more then fine, you could also get a h11 splitter and do it at the fog light.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 10:49 AM #3
Thanks I like the idea of the splitter, I need to research. The kit came with a 15A fuse pre-installed, IDK why that size fuse would be used.
Old 11-02-2021, 01:41 PM #4
Saker's Avatar
Saker Saker is offline
Saker's Avatar
You can see other threads on this.
You should only use the size fuse rated for the lights draw. A 15 amp fuse will offer you no protection.
I think I have a 1 or 2 amp fuse in mine.
Best Regards,
Saker
Old 11-03-2021, 02:54 PM #5
I used the INJ 10a under the hood, but the add-a-fuse comes with a 15. That's 25a in serial as I understand, this seems inappropriate. I've heard to just use the 15a and pull the 10a, is that correct? I want to get the fuse right. thanks
Old 11-03-2021, 08:43 PM #6
Saker's Avatar
Saker's Avatar
How much amp draw is on your grill lights?
That’s the size of the fuse you need to protect that circuit. If you go higher, you are not protecting the circuit if it shorts.
Tap into the the made circuit side of a switched circuit and then protect your light circuit with only the amp draw rated fuse for the lights you are installing.
Does that make any sense?
Best Regards,
Saker
add-a-fuse , lights , original , owner , tap
Those who have Raptor Lights... spyder918 5th gen T4Rs 3 08-20-2021 04:31 PM
Raptor lights losso 3rd gen T4Rs 2 01-27-2021 11:06 PM
Has Anyone Tried These Raptor Lights? zw470 5th gen T4Rs 120 11-13-2020 11:52 PM
Raptor lights!! Lets see them! Zeke588 4th Gen T4Rs 5 03-08-2019 02:34 PM
