Old 11-15-2021, 06:13 AM #16
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
I think a lot of you are overthinking this whole supercharger modification. We’re not build 1/4 mile or time attack engines here. Doubt there’s a chance you’ll ever starve the engine of fuel and cause an issue. To be fair a normal running engine is always knocking. That’s why it was once called vacuum advance timing and now it’s ECM controlled. During normal driving the ECM is constantly advancing timing until it starts knocking and then it’ll retard the timing, then it’ll do it again as soon as you start moving again.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 05:53 PM #17
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
My scenario here in Idaho would be going up White Bird Hill. It is a 7 mile 7% grade that climbs 2700 ft. During the summer it will easily be in the 90s there. I typically fill up in Boise which is about 200 miles away. Not sure what my gas mileage will be with the supercharger but at 10+- mpg I would be close to the qtr tank. I think it would bug the heck out of me to find a gas station just to make it up the hill.
Besides White Bird, there are many smaller, more remote areas I go into during the summer where I am running at less than a qtr tank when I am coming back. Those trips also have some nasty grades and NO ability to fill up. My overall average MPG is 20 so I will definitely have an adjustment between fill ups once I get the supercharger on but for me the surge tank is a belt to the suspenders approach so I don't have to use the Garmin for a rescue. If I am pulling a camper, I may have to start bringing gas cans. Time will tell.
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 10:17 AM #18
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
I drive pretty horribly, i had 13.7 mpg before supercharging and with 32" tires
i'm now at 12 mpg with URD and 34" tires. i got the feeling you will fare much better, i've never seen 20 before, even on my 800 mile drive home from picking up my 4runner new. i think i hit 16.5 mpg then.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 02:48 PM #19
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
you'll just have to invest in a reserve tank I guess
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 10:32 PM #20
Turfboy's Avatar
Turfboy's Avatar
There is a nice write up here:
Auxiliary Fuel Tank
I would then have to figure out where to put the spare and I fall further down the rabbit hole. I did look for a bigger tank but did not see anything specific to the 5th gen and I would loose some armor to boot. Lets get this thing in and running and see what happens. I am finding it is getting quite cold on the garage floor here.
Still waiting on the relay, I think I will trigger the fuel relay from the power to the Supercharger cooling pump. URD has the cooling pump relay triggered by the Number one Spark plug coil. The relay for the cooling pump sits behind the fuse box and is accessible to my tap for the fuel pump relay. Both will run on separate circuits on the BlueSea 5045. I have an 8ga supply wire running to the BlueSea which should be able to handle the 100A the box can run. One thing I noticed with the BlueSea was that the post to the battery really hangs out there when the cover is off.
Old 11-17-2021, 09:31 AM #21
comtn4x4's Avatar
comtn4x4's Avatar
Auxiliary Fuel Tank
Don't avoid the rabbit hole, just jump right on down it! I'm way down here already and I've got the beer. It's really unavoidable and causes more work and expense to do everything twice.
See auxiliary tank here:
TL460GXA24G-US - Long Range America
Get yourself a rear bumper and you're good to go!
Old 11-17-2021, 07:45 PM #22
Turfboy's Avatar
Turfboy's Avatar
While searching the repair manual (thanks to Doug) TOYOTA 2016-2019 4Runner Repair Manual RM27F0U I came across this page.
It appears the ECU is doing some management of the fuel pump. I may have to switch the lead for the relay. I do not want the surge tank pump pumping when the main tank is not pumping. Although, any excess fuel will just be returned to the surge tank. URD has their included pump installed in the fuel tank and it is managed by the ECU. With my modified I have an always on situation. Hmm, gotta think about this one.
Old 11-18-2021, 12:35 AM #23
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
I've had the URD kit installed for a couple years now. I don't run the tank low when I'm doing grades like you mention, but I do plan my fuel stops so that it's not an issue. I have run the 4Runner on mostly level ground below the 1/4 tank mark and not had any issues with the SC or lack of power. Up/down grades is of course a different story. I know fuel stations are more remote, especially high octane out in the country.
If you're going to do the aux pump, I'd use a relay to trigger it so that it's only on when the main pump is on. Either that or put a switch on the dash you can turn it on before grades/terrain. Most small airplanes have an engine driven pump and an electric pump. The latter is only run (by switch) for aerobatics, or take-off/landing.
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 11-18-2021, 02:01 AM #24
we had to manually lean out the mixture on our cessnas lol
Old 11-18-2021, 10:20 AM #25
Turfboy's Avatar
Turfboy's Avatar
I am leaning towards having the aux pump trigger off the main pump. Internet research shows Toyota using 4 different methods of regulating the main pump. My guess from my limited ability of reading circuits is that ours is an on/off because there are no resistors in the circuit. I can not tell what the ECU is using as a data source.
Old 11-20-2021, 03:06 PM #26
Turfboy's Avatar
Turfboy's Avatar
If I don't want to drop the fuel tank, I could tap the number 1 wire here as this is the Fuel Pump Control ECU. It is not my favorite solution as it is so exposed. It may be worth dropping the tank enough to access the pump wire.
URD Supercharger 5th gen-pb202884-jpg
Old 11-20-2021, 03:19 PM #27
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
I believe you need to drop the tank anyway with the URD kit to install the new fuel pump inside the tank, unless you already completed that part.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 11-21-2021, 08:38 PM #28
Turfboy's Avatar
Turfboy's Avatar
So with the fuel pump stalled due to my uncertainty as to the trigger wire, I thought I would fool around with other parts of the install.
Today it was the front bumper area. Now the instructions do not tell you to remove the front bumper. Any mechanic who can install the inter-cooler, pump and hoses with the front bumper on is a person with super amazing talent. After a failed attempt to put just the pump on and failing, I took the bumper off. I YouTubed it and found taking it off VERY easy (Except for the passenger Fog light. WTF would you put a shroud over it?) I took the electrical supply off the driver side and gently laid the bumper down. Then removed the shroud on the passenger side and disconnected the passenger side fog light. The bumper then came free.
Various bits were removed so I had clear access to where the inter-cooler went. The instructions are pretty clear and relatively easy as I successfully completed that part of the install.
I installed the pump and drilled a pilot hole for where a supply line has to go. I connected the pump to the inter-cooler. REMEMBER! There is a plug on the radiator that needs to be removed(you can see one in the picture) and I almost cut one leg of the hose too short. I am having a bit of a problem figuring out the remaining hoses as there is a description for the hose routing but no pictures in the instructions. But it is late and a beer is calling
URD Supercharger 5th gen-pb212891-jpg  URD Supercharger 5th gen-pb212892-jpg
Old 12-04-2021, 05:45 PM #29
Turfboy's Avatar
Turfboy's Avatar
Supercharger is done!
At Mechanic for a week, install time about 16 hrs. Most of issues came from external fuel surge tank install coupled with huge external filter. Feedback from the Mechanic was the kit is very well built but the instructions were a bit confusing at times.
My first impression is that I can see the engine again.
I am currently in the learning phase for the piggyback ECU and transmission. No 4x4 burnouts yet.
URD Supercharger 5th gen-pc032900-jpg  URD Supercharger 5th gen-pc032898-jpg  URD Supercharger 5th gen-pc032899-jpg
Old 12-10-2021, 11:49 AM #30
Turfboy's Avatar
Turfboy's Avatar
Driving Impressions first quarter of tank:
1) MPG at 19.6 (everything reset during build). This is my normal winter gas mpg so no change.
2) Fuel Surge tank is still noisy. The trigger for the surge tank relay is 100% all the time. The lift pump in the tank is controlled by the ECU so the Surge Tank may be running at less than 100% full. More research is needed. One solution is to have the Surge tank controlled by the ECU and have the tank pump at 100%. PWM control by the ECU of the fuel pump causes headaches for duplication of signal.
3) Idle noise from the Supercharger is noticeable in drive at stops. If I have it in neutral, no noise. I am not sure if Whipple uses Helical Gears on the supercharger drive unit.
4) Still in learning mode for the transmission and piggyback ecu so I have not been on the gas much. The few times I did it was great!
detonation , engine , fuel , supercharger , urd
WTB: 4th Gen V6 Supercharger who done it Want to Buy/Trade 1 05-21-2020 09:23 AM
FS: Supercharger Dynamic Tensioner Bracket for 3.4L Supercharger - $75 shipped - Gads mcaz5 For Sale: T4R Items 3 02-01-2018 11:46 PM
Supercharger!!! mirraman 3rd gen T4Rs 1 02-28-2014 01:29 PM
Supercharger decals w/ no Supercharger(poser?) LuvmyRunner1980 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-20-2013 05:13 PM
Supercharger 99Grunner Classifieds - buy & sell (no commercial ads please) 0 05-09-2010 09:20 PM
