Old 12-19-2021, 10:20 AM #46
I cannot wait till we supercharge ours.
the transmission article is neat. a lot of guys used to go to level 10 in my Titan days.
Old 01-10-2022, 07:20 PM #47
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
Went in for emissions test today.
Visual inspection of
Air Injection: Pass
Catalyst: Pass
Gas Cap: Pass
On Board Diagnostic system:
Overall Result: Pass
So with this post a small driving update: Winter road conditions were slushy and now have dried out. My MPG has fallen off 20 and is now running 18. I now feel comfortable merging into smaller openings as the power between 1800 rpm and 2500 rpm is vastly improved. Cold starts are where I loose the bulk of my MPG. Once things are warmed up my average starts to climb however most trips are short. The radium surge tank is noisy and because of the trigger for the relay it runs well after the car is shut down (but it works). Once the weather warms up I will look for another relay trigger or try out a solid state relay hooked up to the regular pump signal.
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 03:45 PM #48
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Originally Posted by Turfboy View Post
So I went Xmas tree hunting in the Forrest today. Took some screenshots of hill climbs. I do not think the Closed Open loop is registering correctly.
I thought someone indicated you could roughly calculate HP from the Mass Air Flow. I wish there was a Fuel Air or Lambda that worked for this app. Temp was 36%, Elevation 3750 ft.
Light acceleration up the hill, Moderately heavy acceleration, Heavy acceleration
Thanks for sharing more info. The "Boost" sensor must be in Manifold Absolute Pressure. So, whatever it reads, subtract the atmospheric pressure (~14.7 psi or a little less since you are in some elevation).
So, you are actually still at ~-4 psi vacuum in first shot, and +7 psi boost in the third. This aligns. I agree it should show open loop at full throttle, weird it shows closed.
Great news regarding emissions!
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 01:27 PM #49
Turfboy's Avatar
Turfboy's Avatar
6k update.
City driving MPG 18. Feels a little less than what I was getting prior to the mod. Some of that is due to driving in the snow/slush which killed me.
Did a quick trip to the coast over two Mtn Passes. Blues and Snoqualmie. Prior MPG prior to the URD Supercharger it was 20.11 to 21.22 MPG. Post Mod was 20.51 MPG. The MPG post mod was more consistent.
The rig seldom down shifted unless on a steep grade. Below are some screen shots from Ultragauge blue during the trip. All photos are Cruse control set to 70 MPH. The first is level ground. The second is on Snowqalmie prior to kick down and the third is post kick down on same hill. Note the RPM to MAF (Mass air Flow). HP is 10 x MAF or so I am told.
URD Supercharger 5th gen-screenshot_20220327-151923-png  URD Supercharger 5th gen-screenshot_20220327-100406-png  URD Supercharger 5th gen-screenshot_20220327-100415-png
Old 04-12-2022, 10:41 PM #50
Turfboy's Avatar
Turfboy's Avatar
I thought I update what the top looks like. Not sure if you can see it but it also shows where the seventh injector sits. It is the black box to the left of the URD Supercharged label.
URD Supercharger 5th gen-urd-engine-jpg
Old 04-13-2022, 09:06 AM #51
Brandonium's Avatar
Brandonium Brandonium is offline
Real Name: Brandon
Brandonium will become famous soon enough
Brandonium's Avatar
Real Name: Brandon
I am confused. I am not seeing where URD sells this supercharger anymore. When you go to their website they sell Magnuson.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
Brandonium is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 10:46 AM #52
Turfboy's Avatar
Turfboy's Avatar
I had to get on a waiting list. They are currently out of stock. I got a email letting me know when they were going to get some (heads up type thing). The superchargers were sold out in a day or two.
URD Supercharger Kits - Underdog Racing Development
The Magnuson units do tend to be more available. I think the issue may be the adapter between the Whipple W140AX and the 1GR-FE Heads. When I got mine it appeared to be machined out of a solid block of aluminum as I could see some tooling marks. The remaining parts all appeared to be off the shelf type stuff that is available on the open market.
Old 04-19-2022, 11:35 AM #53
Brandonium's Avatar
Real Name: Brandon
Brandonium's Avatar
Real Name: Brandon
I messaged them and yup you are correct. I am curious since I am not seeing a lot of URD posts nor anything on the web regarding them on the 4Runner.. do you have any concerns regarding longevity and reliability vs the Magnuson since these do pump out significantly more HP and Torque? I remember seeing a set of videos on youtube regarding the install of a URD setup on a 5Gen but they have since vanished. All I can find anywhere is Magnuson stuff.
Old 04-23-2022, 10:13 AM #54
Turfboy's Avatar
Turfboy's Avatar
The rig drives the same unless I need the power (less than 5% of the time and just because I have it). When I start towing big stuff I plan on changing fluids more but I would do that anyway. So the short answer is, I have no concerns regarding longevity nor reliability in any respect vs stock or Magnuson.
In severe stress testing I do believe that I got the supercharger belt to slip on hard acceleration up a very long steep hill. That same hill with no supercharger, stock would just gear down and rev really high. I probably got the same HP from the engine... just different ways to get there.
Old 04-23-2022, 08:55 PM #55
Steve40th396 Steve40th396 is offline
Steve40th396 will become famous soon enough
Have you monitored oil and trans temp before and after install?
Steve40th396 is offline   Reply With QuoteReply With Quote
Old 04-25-2022, 09:15 AM #56
Turfboy's Avatar
Turfboy's Avatar
Prior to the mod I have looked at em via the Ultragauge Blue. I have not seen any significant difference after the mod. The Whipple supercharger uses an internal reservoir of oil that is independent of the regular systems.
Old 05-25-2022, 10:30 AM #57
Turfboy's Avatar
Turfboy's Avatar
Looks like they are available to order now.
Old 05-25-2022, 10:51 PM #58
shipping on or before July 1 too.
also, did you see his new Spec-U exhaust???????? wish i saw that before i did the URD y pipe and magnaflow muffler swap.
Old 05-27-2022, 09:20 AM #59
Turfboy's Avatar
Turfboy's Avatar
I like it but I think it runs through the area where I have my surge tank(in front of the gas tank).
Old 05-27-2022, 09:42 AM #60
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
I have the regular URD exhaust installed, have a spec u sitting in my garage... along with a borla... and a magnaflow...
i don't know why i bought them all.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
detonation , engine , fuel , supercharger , urd
WTB: 4th Gen V6 Supercharger who done it Want to Buy/Trade 1 05-21-2020 09:23 AM
FS: Supercharger Dynamic Tensioner Bracket for 3.4L Supercharger - $75 shipped - Gads mcaz5 For Sale: T4R Items 3 02-01-2018 11:46 PM
Supercharger!!! mirraman 3rd gen T4Rs 1 02-28-2014 01:29 PM
Supercharger decals w/ no Supercharger(poser?) LuvmyRunner1980 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-20-2013 05:13 PM
Supercharger 99Grunner Classifieds - buy & sell (no commercial ads please) 0 05-09-2010 09:20 PM
