Old 05-29-2022, 10:30 PM #61
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
Originally Posted by rayofsi View Post
I have the regular URD exhaust installed, have a spec u sitting in my garage... along with a borla... and a magnaflow...
i don't know why i bought them all.
More dollars than sense?
On another note, it has been raining and I wanted to see what happens if I "lead foot" it. Weeeeellll, the nanny cpu cut power and I did not get the expected result it did accelerate though. So I turned off the monitoring and powered up again. The wheel spin was so fast there was no acceleration. The wheel just spun and the T4R went no where. It was very interesting. I wanted to try 4WD but chickened out.
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 03:44 PM #62
Cej255 Cej255 is offline
Cej255 is on a distinguished road
Installed my kit a few months ago and it's exceeded my expectations.
Cej255 is offline   Reply With QuoteReply With Quote
Old 09-18-2022, 02:59 PM #63
Turfboy's Avatar
Turfboy's Avatar
Are you going to put an oil catch can on it?
Old 09-21-2022, 07:25 PM #64
Probably not, just going to run it as designed.
Old 01-09-2024, 11:40 PM #65
eagleoffury eagleoffury is offline
eagleoffury is on a distinguished road
I thought I update what the top looks like. Not sure if you can see it but it also shows where the seventh injector sits. It is the black box to the left of the URD Supercharged label.
She's a beaut, I enjoyed reading your journey to getting the URD charger. I am on the waitlist until they are back in stock. Thanks for sharing.
eagleoffury is offline   Reply With QuoteReply With Quote
Old 01-10-2024, 12:00 AM #66
everytime this thread pops up, I want a S/C for the minivan. thanks
Old 02-18-2024, 06:21 PM #67
Turfboy's Avatar
Turfboy's Avatar
So I figured out the relay trigger I had to the fuel tank that ran the surge tank pump was draining the battery. It appears that functionally Toyota is triggering the fuel pump when the ignition is off. Maybe something to do with the fume purge tank. IDK
Symptoms were the Surge tank pump running when it was parked (no key in ignition) and the battery being drained when sitting in the garage for an extended period.
I moved the relay trigger point to run off the Supercharger intercooler pump. The red relay wire is power to pump. This relay is triggered by the ignition system (URD designed) As a side benefit as I understand things, If the car is in an accident, battery power is cut to the ignition system. Thus the fuel pump will stop running when ignition system is powered down.
If there is anyone with better knowledge on this safety setup please let me know. In other news MPG is down to 18.7 in the city on winter gas . The supercharger makes gear pulse noise when stopped at a light and I don't think I will be getting a gen 6 when they come out
URD Supercharger 5th gen-20240218_150722-jpg
Old 02-19-2024, 07:27 AM #68
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
Great research. I had the same issue years ago with my URD. When I was driving the 4R every day it wasn't a problem. However I travel extensively and once upon returning from a long trip the battery was dead. Thank goodness I had a second battery and also carried a Noco. That issue got worse and worse as it sat and we worked on other things. The supercharger was great but it's living on another 4R in SoCal now.
Sent from my Pixel 8 Pro using Tapatalk
4rNCMTNs is offline   Reply With QuoteReply With Quote
detonation , engine , fuel , supercharger , urd
WTB: 4th Gen V6 Supercharger who done it Want to Buy/Trade 1 05-21-2020 09:23 AM
FS: Supercharger Dynamic Tensioner Bracket for 3.4L Supercharger - $75 shipped - Gads mcaz5 For Sale: T4R Items 3 02-01-2018 11:46 PM
Supercharger!!! mirraman 3rd gen T4Rs 1 02-28-2014 01:29 PM
Supercharger decals w/ no Supercharger(poser?) LuvmyRunner1980 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-20-2013 05:13 PM
Supercharger 99Grunner Classifieds - buy & sell (no commercial ads please) 0 05-09-2010 09:20 PM
