11-05-2021, 03:21 AM
Fire extinguisher on a molle panel. Is it safe?
I currently have my extinguisher in the little storage space on the right side. When I have my camping gear packed, it's buried and would be hard to grab in an emergency. I looked into mounting it under the passenger seat, but it seems that every mount for that spot will limit the ability to slide the seat forward. I see a lot of people using a molle panel on the rear side window to store the extinguisher. Looks like a great spot, but is there a way to do this that will be safe in an accident? I don't want that thing hitting me or my kids in the head. I see a lot of panels and mounts out there, but are they strong enough to be safe?
11-05-2021, 11:30 AM
This how i have mine mounted. I feel like the 3 points that secure the molle panel and the fact that my shelf now ties the panel to the opposing panel should provide a very stout mounting in the event of an accident or rollover.
11-05-2021, 11:40 AM
I have mine strapped with an extra velcro strap that is easily removed. It is a little car sized one. Nothing too big.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
11-05-2021, 11:56 AM
Real Name: Chris
Real Name: Chris
I have mine mounted to my molle panel, it's been there for at least 3 years and I've had no issues. I have it in reach of the rear of the vehicle so it's easily accessible incase of an emergency, the last thing I wanted was for it to not be reachable when needed
11-06-2021, 01:43 AM
I keep marshmallows, hersheys bar and some grahm crackers ready in the door pocket at all times.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
11-06-2021, 04:55 PM
LOL
11-06-2021, 07:39 PM
Hahaha!
What is “safe” is subjective. However I considered the placement as best I could for access and just if a crash occurred… where it might fly. Ended up mounting it driver’s side as low as possible, low enough the first point of contact is the back of the passenger seat…
And ya I know passenger side would probably be better as I’m solo most days.
11-06-2021, 08:35 PM
Originally Posted by DriftingOverland
Hahaha!
Perhaps mounting it vertically and using two mounts to hold it in place? The horizontal mount looks like it's armed to fly.
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
11-06-2021, 11:21 PM
Real Name: MURDERED TRD
11-07-2021, 09:32 AM
Hahaha!
Seems like the shovel would be just as dangerous if not more so than the fire extinguisher let alone the hatchet
11-07-2021, 07:35 PM
I’m not the OP… everything you see is secured and clamped with rivnuts and 5/16 bolts The fire extinguisher is in a metal mount with rivnuts/bolts too.
11-07-2021, 07:52 PM
While not a subject matter expert, I took linear momentum into consideration… shovel/axe secured with quick-fist clamps, rivnuts and 5/16 bolts. Note the axe is upside down… mass is lowered. Good enough for me.
11-08-2021, 10:50 AM
I'd recommend a minimum extinguisher size of 5lb. Those smaller ones have little chance of putting out anything serious like an engine fire. Even a 5lb might not do the job.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
11-08-2021, 04:24 PM
Originally Posted by wcjeep
Ok, so these look pretty legit. I love that they have a long burn/output time.
I've certainly seen enough independent video's for me to think they're reliable.
Pricing seems a bit steep for something you might never use, but then again, I have a CRAP-tonne of money into this 4runner at this point, so what's another $80.00 right?
