11-08-2021, 11:34 PM
#16
Originally Posted by TRDHULK
But they still look flimsy and they are 2 piece. They don't seem much different than stock and do not offer much coverage.
Arks are very sturdy and one piece with max coverage.
Sir!!!! You are a true facilitator.
ORDERED!!!!
11-09-2021, 07:13 PM
#17
Post from back in 2017 when I made my own. I actually sell the template if people don't want to take the time to make there own. Made a lot for the 2nd Gen tacoma guys.
Upgraded my inner fender splash shields
2016 SR5 4 Runner - SCS Ray10 17x8.5 -10 offset, BFG ko2 - 265/70/17, Tint, Magnaflow 12256.
2015 SR5 Tacoma - Method NV 17x8.5 -0 offset, BFG ko2 - 265/70/17, Tint, Magnaflow 12246.
11-09-2021, 10:18 PM
#18
Originally Posted by Gclark949
My Rad rubber are all cracked and falling apart. Surprised no one else mentioned this.
Two of mine are cracking. I think the template was messed up as there is a bit to much bendiness in the each of the rears, the front of the wheel are “fine”. Not super happy with them as I have only had them on for a bit over a year, not a lot of activity during that time, and those two need to be replaced already. They might not like our dry climate either.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
11-09-2021, 11:08 PM
#19
so just let me get this straight, there isn't any real benefit to this, unless your splash guard is already deteriorating or missing?
Asking for a friend
11-09-2021, 11:42 PM
#20
nope, not in this dirtbags opinion, spend the money on new clips, some rubber washers and the rest on a fkn big box of wine not whine
2013 TE w/ KDSS Nav
11-09-2021, 11:47 PM
#21
yup my buddy basically stopped me from buying it. He said its not an upgrade, but a replacement if you need it.
11-10-2021, 11:42 AM
#22
exactly. mine were missing.... for reasons.
11-10-2021, 12:50 PM
#23
11-10-2021, 06:06 PM
#24
Originally Posted by Inv4drZm
that is beautiful!!! I wonder why there isn't more companies making it. I"m pretty sure there is a demand for it, and if not, you just "make" the demand" via social media these days.
11-10-2021, 10:31 PM
#25
Agree. That's very cool. Nice work.
11-11-2021, 01:04 PM
#26
I made aluminum ones for my truck. If you've got the right tools its pretty easy. Page 56 of my build thread.
Right!
Side note I have seen the, with vent cuts for errr... jeeps.
2013 TE w/ KDSS Nav
11-11-2021, 06:41 PM
#27
Right!
Don't forget animal motifs like spiders, thats next level jeep bling.
11-12-2021, 12:23 AM
#28
got my Ark splash guards on today. went on as expected. 2 small spots needed a quick trim with a razor blade. otherwise no real issues. I expect one rivet to pull out as its pretty tight due to the KDSS lines. If it happens, i'll just drill a hole in the splash guard and use one of the holes on the KDSS bracket/guard ting.
11-13-2021, 08:35 PM
#29
Is it the stock "splash Shields" or just the clips that hold them that are failing? I need to replace the clips on my 2018 Turd, but the rubber is fine.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
11-13-2021, 08:46 PM
#30
mine were ripped. most of the clips were fine.
