Old 11-09-2021, 05:17 PM #1
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
Anyone added the TRD Start button to their 4Runner?
Disclaimer: I know its 'ricey' and expensive.. but seeing the Meso one, Id rather the authentic TRD one. This would be for the vehicles with keyless start, not adding keless start to a vehicle without.
Looks like the Hilux model fits plug and play:
Part # MS422-00003
5th Gen Toyota 4Runner (2014-21) Push Engine Start/Stop Red TRD Button – KTJO 4x4
Anyone tried it?
MGordo is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 06:30 PM #2
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
I definitely wouldn't for $145
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 06:45 PM #3
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
Part # MS422-00003
Anyone tried it?
Different from what you're wanting to do, but I did add one to my 2017 4Runner non-smart key just as a push to crank button. Had the button from my other truck, so figured why not
https://www.toyota-4runner.org/2824361-post17.html
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 02:51 AM #4
mrkothegigolo's Avatar
mrkothegigolo mrkothegigolo is offline
mrkothegigolo is on a distinguished road
Part # MS422-00003
Anyone tried it?
Not sure if you're commited to the TRD logo but AJT has one. It says for the Tacoma but I think it fits the 4Runner as well. I don't have it yet but I've been eyeing it. Have their Key Fob and I like it.
Products | ajt-design
98 Limited - SOLD
22 MGM ORP
If you're gonna be dumb, you gotta be tough
mrkothegigolo is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 04:21 AM #5
PierreP4 PierreP4 is offline
PierreP4 is on a distinguished road
I have the red Meso one in mine. It’s not the TRD one, just red with the normal start button verbiage. It’s much cheaper than buying the whole assembly. I fits just fine and looks good to me.
PierreP4 is offline   Reply With QuoteReply With Quote
Old 11-11-2021, 09:55 PM #6
Well I ended up ordering the TRD button and installed it tonight, looks good and took about 5-10mins to install.
Anyone added the TRD Start button to their 4Runner?-20211111_185431-jpg
Old 11-03-2023, 10:47 AM #7
sbhill5739 sbhill5739 is offline
sbhill5739 is on a distinguished road
Wanted to see how you actually removed the old start button? Which panels did you have to remove to do this?
sbhill5739 is offline   Reply With QuoteReply With Quote
Old 11-06-2023, 04:29 PM #8
Humble Leader's Avatar
getting to that panel is not difficult just a lot of steps
- driver's side door sill needs to be removed (held in place using plastic clips)
- trim piece near parking brake needs to be removed (one plastic screw near the dead pedal and then pull out)
- kick panel under steering wheel can be partially removed. there are two bolts (m6 thread) that need to be removed and then you can GENTLY pull and unclip the kick panel
- left AC knob trim near radio needs to be removed
- you MAY need to remove the steering wheel plastic trim. I'm not 100% sure. car in ON position, turn wheel to left, unscrew the screw right in front of you. do the same for the right side. unclip the plastic it comes out in two pieces
- now you can pull out the push to start button trim and get to work
now you can probably do this without partially removing the steering wheel trim / steering wheel kick panel but doing so will give you more room. reassemble in reverse order
this video is for a trailer brake install but it shows you how to remove the various components. if you're new to panel popping get some extra plastic clips and a good panel tool
HOW TO | TOYOTA 4RUNNER BRAKE CONTROLLER INSTALL - YouTube
adding , keless , start , trd , vehicle
3rd Gen 4Runner Push Button Start System JWaldz 3rd gen T4Rs 77 11-06-2017 09:35 PM
TRD Push Button Start....can it be added? TOY2G General Discussions 20 10-20-2017 01:04 AM
push button start for non limited 4runner retrofit mrblah 5th gen T4Rs 8 03-09-2017 12:57 PM
Just added remote start, need help with clicker over ride spoiler900 3rd gen T4Rs 3 03-07-2013 11:16 AM
RFID Keyless Entry, Push Button Start and Remote Start BFLAN 5th gen T4Rs 41 04-17-2012 09:36 PM
