Old 11-18-2021, 02:43 PM #16
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
Originally Posted by BADCLOWN View Post
I don’t want to be regreasing stuff every few thousand miles. I’m looking for a “set it and forget it” set of UCAs that I can have installed and not have to think about.
I’m doing UCAs to avoid having my CV boots torn due to the lift. I had a 3 inch toytec lift on my old 3rd Gen with stock UCAs and ended up having torn boots
I chose Ironman ProForge UCAs for that reason.
They're not adjustable like the SPCs and others, they have built in camber and then the alignment shop just adjusts the LCA appropriately like normal.
They use an OEM spec ball joint, so it's just normal, no additional greasing or maintenance required.
As others have said, UCAs will not help with your CV axle angle. Really that comes down to your overall lift height. The higher the lift, the higher the CV angle, the more stress on the joints. A diff drop will help, but not much in my experience, and that moves the stressor slightly off the CV axle and onto the differential pinion since the diff is now lower.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 11-18-2021, 03:10 PM #17
Rastamind's Avatar
Rastamind Rastamind is offline
Rastamind is on a distinguished road
Rastamind's Avatar
I really hafta agree with the JBA UCA's, they are solidly built, awesomely responsive customer service. I pair with the Toytec lifts, it's the preferred setup I install. I also like the way the red looks up in there.
Good UCA recommendation-lift07-jpg
21 TRD ORP -Mag Grey|
3in Toytec BOSS ALUMA 2.0 + JGA uca + BFG KO2 275/70R17 |
Pioneer NEX4500/maestro rr2+ infinity kappas + kicker hideaway sub+ NVX Silicon baffles+80/50 mil Kill Mat |
TRD skid plate + Heritage grill+ Rhino Rack X-Tray basket+ ABS Nerf bars+bull bar+ 20” led + DD amber fogs + BD+CL Ditch Lights
Rastamind is offline   Reply With QuoteReply With Quote
Old 11-18-2021, 08:43 PM #18
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I have the JBA's in mine. I had SPC's in a Tacoma a few years back and never cared for the way the ball joint mounted in them. Only had them about a year and sold the truck. I probably have 40k on the JBA's and no issues. Hit them with a grease gun every oil change and they are good to go. If I ever wipe out a ball joint it's a regular GM part I could easily get local.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 11-18-2021, 09:17 PM #19
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Which UCA’s offer the most positive caster adjustment?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 11-21-2021, 07:07 PM #20
BADCLOWN's Avatar
BADCLOWN BADCLOWN is offline
BADCLOWN is on a distinguished road
BADCLOWN's Avatar
Ah, well I thought UCAs helped with the suspension geometry and keeping the CVs more aligned. My bad.
Sounds like JBA or SPC are the top choices.
Has anyone installed the toytec diff drop? It says that the TRD skid plate may need bigger spacers. Anyone have experience if this is true or is the diff drop kit plug and play with no figment issues on the skid plate?
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, OE LED fogs, AJT, black TRD shifter, 33inch light bar, K&N, CanvasBack, Toytec 2 inch lift, 34 inch tires, 2021 TRDP wheels, URD
BADCLOWN is offline   Reply With QuoteReply With Quote
inch , lift , rear , spring , tires
Need recommendation for good HID/HIR or LED headlight system Dirtrider216 4th Gen T4Rs 25 10-11-2018 11:53 PM
Anyone have a good LTL Freight Recommendation? cgrigsby79 5th gen T4Rs 11 07-09-2018 08:19 PM
Need a recommendation for a good shop to do my daystar life in Phoenix Jon148 4th Gen T4Rs 0 02-21-2013 02:41 AM
Need a good radio replacement recommendation. JohnnyT Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-17-2012 07:58 PM
Good all around tire recommendation... live4swell Engines / Suspension / Wheels / Tires / Audio / Accessories 13 04-11-2005 08:45 AM
